WTS: Stun Gun Taser [Alat Kejut Listrik]
Page 1 of 13 12345 ... LastLast
Results 1 to 10 of 129
  • Short URL:  http://modifika.si/244173
    Spy Pen Camera, Spy Phone
    Giro Point
    1 Day 8 Hrs 18 Mins 24 Secs
    ANDA BERMINAT??? CALL : 081 22866 9696
    YM : daidova@ymail.com
    HARGA & BARANG LAINNYA ANDA BISA LIHAT DI WEBSITE !!! MataDua.com
    STUN GUN L [ SG - L ] : Rp 400.000
    This StunGunHP camouflaged its resemblance to HP's Nokia, it will not seem like a powerful weapon ..... StunGunHP very suitable to deal with crimes that you meet on the streets, at bus stations, at bus stops, in buses, at school, on campus and wherever you are ....., because:
    - StunGunHP be shocked with a voltage 1.2 million volts (1.200KV)
    - StunGunHP easy to carry because of their small size, only with a length of 10.5 cm, width 4.8 cm and 2.2 cm thick.
    - StunGunHP be in charge (Rechargeable), only charged 2 hours can be used up to 2 days.
    - In addition StunGunHP can also function as a flashlight ......
    Criminals are exposed to shocks StunGunHP will limp even pass out, so you have plenty of time to save themselves.
    HOW TO USE:
    - Charge for 2 hours StunGunHP
    - During the charge, make sure StunGunHP in state Off
    - If you want to enable, there is a slider (rectangular) on the side that can slide in-slide - Slide the slider and above all, the flashlight will glow
    - When the flame torch lights, can not be used for electric shocks
    - Scroll upward 2kali, then the flashlight off and StunGunHP currently active (ready electric shocks)
    - If already active, press the round button above the slider as he touched the body of criminals ......
    STUN GUN N [ SG - N ] : Rp 400.000
    Function :
    >Flashlights AND ELECTRICITY Shock
    > OUTPUT VOLTAGE SOURCE: 2.5 million V
    > Dimension: 142x29x50mm
    > Rechargeable Battery
    STUN GUN H [ SG - H ] : Rp 400.000
    FUNCTION:
    >FLASHLIGHT AND electroshock
    > OUTPUT VOLTAGE SOURCE: 500.000 V
    > DIMENSIONS: 28mm DIAMETER, 165MM LONG
    Giro Point
    met siang... ayo mari belanja...
    dijamin bagus2....
    klo ada pertnyan bs lgs CALL : 081 22866 9696
    thx ^^
    Giro Point
    good nite
    good nite
    good nite
    good nite
    good nite
    Giro Point
    silahkan mampir dan diliat2 yach
    klo ada pertanyaan bisa langsung call ke no 081 22866 9696
    or YM : daidova@ymail.com
    Giro Point
    met malam semua na...
    have a nice day....
    Giro Point
    selamat sore...
    selamat hari minggu...
    silahkan kunjungi lapak ane...
    klo ada yg menarik bs lgs nanya2 ke no 081 22866 9696
    Giro Point
    selamat malam...
    selamat berbelanjaaaa....
    Giro Point
    Selamat Malam ...
    Silahkan dilihat2 dan kunjungi website kami
    Giro Point
    selamat malam...
    silahkan mampir di lapak ane...
    klo ada pertanyaan bs lgs call ke no 081 22866 9696
    krn thread ane byk jd ane ga sempet bales satu satu...
    lgs call or sms aja...
    Giro Point
    selamat malam...
  1. KOLEKSI STUN GUN (ALAT KEJUT LISTRIK) TERLENGKAP - MURAH!!!
    By serbamurahonline in forum Home Electronics
    Last Post: 27th February 2015, 08:34
  2. Replies: 103
    Last Post: 8th September 2012, 13:45
  3. LENGKAP!!! KOLEKSI STUN GUN (ALAT KEJUT LISTRIK) dan PEPPER SPRAY
    Last Post: 29th January 2012, 18:25
  4. Jual : Stun Gun Taser
    By talam in forum Home Electronics
    Last Post: 15th February 2011, 15:37
  5. WTB ALAT KEJUT LISTRIK ( STUNGUN )
    By syurey in forum Home Electronics
    Last Post: 28th August 2010, 09:36
