Cuci Gudang (Sparepart for sale)
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/243636
    Lenteng Agung, Jakarta Selatan
    3 Wks 4 Days 3 Hrs 59 Mins 29 Secs
    Wink Cuci Gudang (Sparepart for sale)
    Modcomers,
    Hasta sedang melakukan cuci gudang. Parts dibawah ini di diskon 50% (harga dibawah belum termasuk diskon). Bukan barang second/bekas, namun lambat berputar. Yg berminat silahkan kontak 021-7806-752/7820-578, jam kerja, dg sdr Ujang/sdri Erna. (akan diupdate dg merek dan part lainnya)
    Thanks!!
    Note: Silahkan dikonfirmasi terlebih dahulu. Kesalahan ketik bisa terjadi
    Notasi:
    (merek)(tipe) (tahun/cc-bila ada) (no part) (nama part) (quantity) (harga)
    DAIHATSU CHARADE 17801-87703-000 AIR CLEANER 1 92,000
    DAIHATSU CHARADE 13514-87782-000 BELT TIMING 3 302,500
    DAIHATSU CLASSY 48520-87724-000 ABSORBER SHOCH FR LH 1 1,375,000
    DAIHATSU CLASSY 04495-87703-000 BRAKE SHOE 1 107,800
    DAIHATSU CLASSY 04495-87704-000 BRAKE SHOE 1 107,800
    DAIHATSU CLASSY 90-96 31219-87711-001 COVER CLUCTH 1 245,000
    DAIHATSU DELTA 04494-87310-008 BRAKE SHOE 2 319,000
    DAIHATSU DELTA 31250-87306-000 DISC CLUTCH 1 467,500
    DAIHATSU ESPASS 48530-87Z09-001 ABSORBER,SHOCK 2 291,500
    DAIHATSU ESPASS 17801-87Z04-.001 AIR CLEANER 3 78,000
    DAIHATSU ESPASS 95 31210-87514-001 COVER CLUCTH 1 250,000
    DAIHATSU ESPASS 95 31210-87Z01-001 COVER CLUCTH 1 250,000
    DAIHATSU ESPASS EFI 17801-87518-000 AIR CLEANER 2 297,000
    DAIHATSU F050 Taft 80-83 31340-87612-000 CABLE CLUCTH 1 101,200
    DAIHATSU F050 Taft 80-83 23303-87307-000 FUEL FILTER ELEMENT 1 121,000
    DAIHATSU F061 FEROZA 93-97 53630-87603-001 CABLE KAP MESIN 1 58,300
    DAIHATSU F061 FEROZA 93-97 16100-87185-000 PUMP WATER 1 781,000
    DAIHATSU F500 Taruna 99-2004 04474-87609-000 CYLINDER KIT 1 209,000
    DAIHATSU F500 Taruna 99-2004 23030-87606-001 FUEL FILTER 2 47,300
    DAIHATSU F500 Taruna 99-2004 81560-87Z02-001 LAMP REAR COMB LH 1 253,000
    DAIHATSU F500 CX Taruna Carb 99-2004 76626-87z02-001 MUDGUARD REAR LH 1 53,900
    DAIHATSU F500 CX Taruna Carb 99-2004 76626-87z02-001 MUDGUARD REAR RH 1 53,900
    DAIHATSU F500 Taruna Carb / Feroza 99-2004 19101-87601-000 CAP DISTRIBUTOR 1 258,500
    DAIHATSU F500 TARUNA CARBURATOR 99364-91271-001 BELT-AC TARUNA 1 71,500
    DAIHATSU F500/501Taruna s/skrg 31340-87z11-001 CABLE CLUTCH 3 165,000
    DAIHATSU F500/501Taruna s/skrg 83710-87z25-001 CABLE SPEEDOMETER 2 137,500
    DAIHATSU F501 Taruna EFI 2001-2007 23300-87403-000 FILTER FUEL 1 390,500
    DAIHATSU F501 TARUNA EFI2001-2007 99364-91291-001 BELT AC TARUNA(EFI) 1 70,400
    DAIHATSU F501/500 Taruna EFI/Carb99-2007 9004A-91017-001 BELT V-RIBBED 1 44,000
    DAIHATSU F70 Taft 84-95 31340-87626-001 CABEL CLUCTH 3 88,000
    DAIHATSU F70 Taft 84-95 83710-PD 601-001 CABLE SPEEDOMETER 1 80,300
    DAIHATSU F70 Taft 84-95 31250-87314-001 DISC CLUCTH 1 462,000
    DAIHATSU F70 Taft 84-95 31230-87604-001 HUB CLUCTH BEARING 1 363,000
    DAIHATSU F70 Taft 84-95 04491-60060-001 PAD KIT 1 324,500
    DAIHATSU F70 TAFF 94-95 99332-10786-001 BELT POWERSTEERING 1 30,800
    DAIHATSU F70 TAFF 94-95 99332-10761-001 BELT POWERSTEERING 3 31,900
    DAIHATSU F70 TAFF 94-95 83710-87615-001 CABLE SPEEDOMETER 2 80,300
    DAIHATSU F70 TAFF 94-95 83710-PD601-001 CABLE SPEEDOMETER 1 80,300
    DAIHATSU FEROZA 93-97 90048-31005-000 BELT V RIBBED 2 75,900
    DAIHATSU FEROZA 93-97 90048-31005-001 BELT-V POWERSTEERING 6 75,900
    DAIHATSU FEROZA 93-97 83710-87633-001 CABLE SPEEDOMETER 2 86,900
    DAIHATSU G100 Charade CX 87-90 45400-00000-001 MUDGUARD RR 1 176,000
    DAIHATSU G102 Classy 90-96 45200-00000-001 MUDGUARD,FR FDR SET 1 220,000
    DAIHATSU G102 CLASY 90-96 83710-87713-001 CABEL SPEEDOMETER 2 69,300
    DAIHATSU G102 CLASY 90-96 83710-87713-000 CABLE A SPEEDOMETER 1 209,000
    DAIHATSU G102 CLASY 90-96 31340-87722-000 CABLE CLUTCH 1 286,000
    DAIHATSU G10R Charade 78-80 04491-87702-000 PAD KIT 1 429,000
    DAIHATSU G10R Charade XG1000CC 78-80 83710-87703-000 CABLE SPEEDOMETER 1 187,000
    DAIHATSU HI JET 1000 17801-87506-000 AIR CLEANER 5 63,800
    DAIHATSU HIJET 1000 31250-87703-001 DISC CLUTCH 1 269,500
    DAIHATSU S088 Zebra 1.0 86-89 31340-87560-001 CLUCTH CABLE 588 1 59,400
    DAIHATSU S088 Zebra 1.0 86-89 16100-87795-000 PUMP WATER 1 568,700
    DAIHATSU S089 Zebra 1.3 90-94 85221-87502-008 BLADE WIPER RUBBER 1 17,600
    DAIHATSU S089 Zebra 1.3 90-94 46400-87523-001 CABLE REM TANGAN 1 148,500
    DAIHATSU S089 Zebra 1.3 90-94 23300-87503-001 FUEL FILTER 1 36,300
    DAIHATSU S091/S092 Zebra 1.3/16 95-2007 19901-87554-008 CORD SET,PLUG 1 313,500
    DAIHATSU S091/S092 Zebra 1.3/16 95-2007 16572-87z08-001 HOSE RADIATOR 1 50,600
    DAIHATSU S092 Zebra Esspas1.6 96-2002 53896-87z02-001 MUDGUARD REAR 3 26,400
    DAIHATSU S092 Zebra Esspas1.EFI 96-2002 23300-87519-000 FILTER FUEL 1 401,500
    DAIHATSU S88/ZEBRA 86-89 78180-87546-001 CABLE ACCELERATOR 1 44,000
    DAIHATSU S88/ZEBRA 86-89 83710-87563-001 CABLE SPEEDOMETER 3 86,900
    DAIHATSU S88/ZEBRA 90-94 78180-87553-001 CABLE ACCELERATOR 1 41,800
    DAIHATSU S91/S92 95-2007 90048-32048-001 BELT V 1 22,000
    DAIHATSU S91/S92 95-2007 90048-32050-001 BELT V 2 22,000
    DAIHATSU S91/S92 95-2007 78180-87z10-001 CABLE ACCELERATOR 2 36,300
    DAIHATSU S91/S92 95-2007 33540-87z01-001 CABLE SELECT 1 159,500
    DAIHATSU S91/S92 95-2007 83710-87z14-001 CABLE SPEEDOMETER 1 86,900
    DAIHATSU S91/S92 95-2007 33530-87z01-001 LEVER SHIFT 1 165,000
    DAIHATSU TAFF 17801-87304-008 AIR CLEANER 11 98,600
    DAIHATSU TAFF 04494-87601-008 BRAKE SHOE 1 165,000
    DAIHATSU TAFF 31210-87604-01 COVER CLUCTH 1 540,000
    DAIHATSU TAFF 15601-87309-001 OIL FILTER 3 41,800
    DAIHATSU TAFF 85220-87607-008 WIFER BLADE 3 46,200
    DAIHATSU TAFF INDEPENDENT 48510-87Z05-001 ABSORBER,FR 2 242,000
    DAIHATSU V82 DELTA4Ban82-86 83710-87340-001 CABLE SPEEDOMETER 2 86,900
    DAIHATSU ZEBRA 47410-87507-008 BRAKE SHOE 4 72,600
    DAIHATSU ZEBRA 31210-87703-001 COVER CLUCTH 1 210,000
    DAIHATSU ZEBRA 13568-87308-001 BELT TIMING 1 385,000
    DAIHATSU ZEBRA 1,3 31250-87531-001 DISC CLUTCH 4 308,000
    DAIHATSU ZEBRA 1,6 31250-87548-001 DISC CLUTCH 1 275,000
    DAIHATSU ZEBRA 84-89 13514-87705-000 BELT TIMING 3 335,500
    DAIHATSU ZEBRA 84-90 13568-87708-000 BELT TIMING 8 255,000
    MITSUBISHI 135 PS MB 120476 AIR ELEMENT 1 121,000
    MITSUBISHI L 300 MD 603354 AIR CLEANER 5 66,500
    MITSUBISHI L 300 MB 193297B DISC BRAKE 2 82,500
    MITSUBISHI L 300 MB 193297 B DISC PAD 2 82,500
    MITSUBISHI L 300 DIESEL MD 603446A AIR CLEANER 2 82,500
    MITSUBISHI P 100 DOUBLE ML 162523 LINING SET 2 105,000
    MITSUBISHI P 100 ENGKEL ML 060238 BRAKE SHOE ASSY 2 144,100
    MITSUBISHI PS 100 MB 161555 SOCBREKER 2 154,000
    MITSUBISHI T 120 SS MZS52002 BRAKE SHOE 4 112,200
    SUZUKI CARRY 52210-77300-000 BRAKE SHOE 1 242,000
    SUZUKI CARRY 1000CC 22100-77310-000L CLUCTH COVER 1 379,500
    TOYOTA COROLA AE92 31230-12140 BEARING CLUCTH 33,66 K 1 475,200
    TOYOTA COROLA THN 74-81 04465-12320 PAD KIT 1 478,500
    TOYOTA CORONA ST 191 17801-74020 AIR CLEANER 2 110,000
    TOYOTA DYNA 95 31230-36150 BEARING ASSY,CLUCTH 1 889,900
    TOYOTA DYNA 95 83710-TA611 CABLE SPEEDOMETER 1 136,400
    TOYOTA KIJANG 17801-YZ CO1 AIR CLEANER 5 62,700
    TOYOTA KIJANG 17801-06010 AIR CLEANER 7 62,000
    TOYOTA KIJANG 31230-35090 BEARING CLU 35,36,N 2 630,300
    TOYOTA KIJANG 90082-93003 BELT V(COOLING SYS) 1 20,300
    TOYOTA KIJANG DIESEL 23303-54072 FUEL FILTER 1 312,000
    TOYOTA KIJANG EFI 1.8 23030-13010 FUEL FILTER 1 353,000
    TOYOTA KIJANG KAPSUL 43330-09110 JOIN ASSY LOWER BALL 1 205,700
    TOYOTA KIJANG KF 40/50 31210-12100 COVER CLUCTH 1 410,300
    TOYOTA KIJANG KF 40/50 31250-27070 DISC CLUCTH 1 345,000
    TOYOTA KIJANG KOTAK 83710-90P00 CABLE SPEEDOMETER 1 107,800
    TOYOTA KIJANG SUPER 83244-90P00 GAuGE 1 500,500
    TOYOTA KIJANG SUPER 83243-95G01 GAUGE 1 896,500
    TOYOTA KIJANG THN 86 04494-20110 SHOE KIT 1 345,400
    TOYOTA LC HDJ 100 23303-56040 FUEL FILTER 4 290,000
    TOYOTA LC HDJ 100 23303-640140 FUEL FILTER 1 275,000
    TOYOTA STARLET THN 93-94 31210-10080 COVER CLUCTH 1 650,100
    TOYOTA STARLET THN 93-94 31250-10064 DISC CLUCTH 1 666,600
    TOYOTA AE92 CORONA(TWINCAM) 17801-15060 AIR CLEANER 6 95,500
    Ban DUNLOP:
    UKURAN TYPE QUANTITY HARGA TAHUN
    185/65 R15, 88 H SP 70 E, 1, 712,800 (2009)
    175'70 R13, 82S SP 70 E, 2, 569,100 (2008)
    195/55 R15, 85V LM 703, 4, 1,012,900 (2008)
    HASTA:
    Jalan Raya Lenteng Agung Barat no. 34, Jak-Sel,
    Phone: 021-7806-752/7820-578
    Hours: Senin-Sabtu 8-5, Minggu 8-4 (minggu 1&2 saja)
    About Hasta:
    Bengkel Mesin, Paint & Body Repair, Dyno & Flowbench Test
    KLIK:
    ~Oli Filter K&N, HP Series
    ~K&N Air Filter Replacement
  2. Hokinusa
    Pertamax...
    HASTA:
    About Hasta:
    KLIK:
    Updates....
    HASTA:
    About Hasta:
    KLIK:
    Up, updates di posting pertama...
    HASTA:
    About Hasta:
    KLIK:
    Quote Originally Posted by Toeti Lie View Post
    Modcomers,
    Thanks!!
    Notasi:
    Ban DUNLOP:
    Up Up Up....
    HASTA:
    About Hasta:
    KLIK:
  1. ++++CUCI GUDANG SALE++++
    By nanotec in forum Jual Beli Mesin Lainnya
    Last Post: 14th December 2010, 08:22
  2. Cuci Gudang - Big Sale ...item @Rp.49.999,- (Second)
    By Grandbaret in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 10th November 2010, 10:51
