WTS: Dan Gan 89 4G63 engine conversion MURAH!
  • Short URL:  http://modifika.si/242036
    3 Days 21 Hrs 17 Mins 56 Secs
    Brothers, jual dan gan modif MURAH nih cuma 30jt (nego dikit)
    SOLD!!! Thanks Modcom
    Spek nya Sbb:
    - Mobil repaint putih
    - Engine swap to 4G63 (Eterna)
    - Header 4-1
    - Piston ARIAS hi comp oversize 50
    - Porting polish + balanced (balanced by karya wisesa)
    - Cometic Head Gasket 1.2mm
    - Injector 380cc by injector clinic.
    - Kabel busi magnecor
    - Walbro fuel pump, 255 lt/hour
    - Fuel Pressure Regulator Aeromotive
    - Lightened crank pulley
    - Adjustable cam gear
    - Ecu stand alone megasquirt by Techno ELectronic (NURIK)
    - Interior re-trim
    - Radiator koyo rad full aluminium
    - Velg rep rs watanabe 15" inch
    - Kaki - kaki baru
    - Per/shock baru, modifikasi utk drag
    - Bushing full teflon
    HP belum pernah di dyno
    Mesin standard tinggal short block. STNK Mati bulan Des 2010. BPKB duplikat tangan pertama.
    PR yang masih perlu diperbaiki:
    - Kabel shifter ada yang putus
    - Plafon blm dirapihin
    Peminat serius dan yang ngerti mesin silakan tel/sms di 0813 8000 1717, HARGA SANGAT NEGO!!
    http://www.modifikasi.com/pb/s-i1179/f-albums/x388/hakimputratama/FPR_Small.jpg
    http://www.modifikasi.com/pb/s-i1179/f-albums/..._bay_small.jpg
    http://www.modifikasi.com/pb/s-i1179/f-albums/x388/hakimputratama/dome_small.jpg
    http://www.modifikasi.com/pb/s-i1179/f-albums/...00713-1138.jpg
    http://www.modifikasi.com/pb/s-i1179/f-albums/x388/hakimputratama/interior2-1.jpg
    http://www.modifikasi.com/pb/s-i1179/f-albums/x388/hakimputratama/interior1.jpg
    BJAmodified Bandung
    6 Days 18 Hrs 39 Mins 17 Secs
    Kunaon dijual kang?syg bgt euy
    Quote Originally Posted by RETROtuning View Post
    Mau nyoba merk lain atau Mitsu tapi yang berdesis kang....hahahaha...
    BJAmodified Bandung
    Mantaf dahhhhhh.....hehe
NGK Busi GT Radial
  1. Replies: 119
    Last Post: 30th May 2013, 22:23
  2. Jual Murah Engine 4G63 (eks singapore) +ECU (sepaket)
    By EvoYe in forum Jual Beli Mesin Lainnya
    Last Post: 14th February 2012, 10:13
  3. WTB: 4G63 N/A engine
    By hputratama in forum Jual Beli Mesin Lainnya
    Last Post: 26th January 2010, 15:44
  4. 800hp 4g63 engine for sale
    By sudjono in forum Diskusi Mesin
    Last Post: 5th February 2009, 12:14
