stuborn and give up...
Results 1 to 10 of 11
  • Short URL:  http://modifika.si/241955
    solved..thanks
    facebook.com/3Steps
    3 Wks 5 Days 3 Hrs 47 Mins 16 Secs
    kalau bener swirlmark, pake SwirlX harusnya bisa bersih
    btw, mobilnya apa nih bro? kondisi gimana (bekas repaint?)
    4 Days 5 Hrs 24 Mins 48 Secs
    Coba ivory + woolpad + 2200rpm... Kalo g ilang brarti defect below CC.. Btw swirlx ama uc emang bs di rotary? Gw test dimobil temen baru 2x pass udh garing
    Quote Originally Posted by 3s3s3s View Post
    sierus bro ga ilang, mobil mercedes benz c200 97 black, cat orisinil, kl dibilang eropa clear coatnya keras masa di honda jazz yg catnya empuk ga ilang juga swirlnya pake alat yg sama.
    i spent a lot of money in this product,please suggest bro...
    Quote Originally Posted by KIOS3R View Post
    defect below CC sama swirl marks beda loh yah bro..kl swirl marks emang jelas baret halus melingkar lingkar.berarti kan di atas CC ato di CC nya itu sendiri. mau wet sanding tp serem.
    no swirlx pake rotary speed 1700 lama kok bro..keadaan panel dingin bgt tanpa prime.kl UC iyah lengket di rotary, tp swirlx good jg di rotary, good di play time tp ga good di resultnya.
    kalo 205 di rotary di honda mah masi marring, ga tau kalo swirlX,,, bisa difotoin aja bos kaya gmn?
    jangan 2 malah yg dimaksud tuh marring,,,
    kl maring sih kayanya ga deh bro maksudnya buffer trail kan ato hologram, ini bener2 swirl marks bro baret halus melingkar, sampe stres ini, lama2 gw wet sand jg neeeh...
    kayanya ga mungkin kalo swirl di honda ga ilang pake UC,,,
    kemungkinan besar defect below CC,,, gw jg perna ngadepin wagonR yang gini,, udh gw hajar pake DC1500 + wool tetep ga ilang,, akhirnya si empunya mobil ngomong "itu swirl ada pas udah beres repaint,, saya coba ilangin jg ga pernah berubah sedikitpun".
    coba lo fill pake glaze, ngisi gak dia
    Pati JATENG
    2 Days 20 Hrs 5 Mins 4 Secs
    Yang 2x pass ngga garing pake yg prof line ya boss? Yang mana itu, apa ultra cut compond?
    gw megs cm ada m80 doank bos,, tp perna coba d151, 105, m86, gak ada yg kering,,, 105 emang cepet kering namanya jg kompon,, tp jauh lah dari uc
  1. SQL Stuffs.. give up hobby
    By 3VO7 in forum Power Amplifier
    Last Post: 1st March 2012, 15:07
  2. Replies: 7
    Last Post: 7th April 2011, 12:36
  3. [ask]HELP me!!!!give me info....
    By eBBoZZ in forum Diskusi Subwoofer
    Last Post: 31st March 2010, 13:57
  4. please give me advice...
    By eternity in forum Diskusi Speaker
    Last Post: 3rd July 2007, 11:58
