- H.P - AEM Water Methanol Injection Kit
Results 1 to 10 of 86
  • Short URL:  http://modifika.si/241343
    Phone: 08179845168 - Klender Jakarta
    4 Days 23 Hrs 46 Mins 8 Secs
    AEM Water / Methanol Injection Kit
    The AEM Water/ Methanol Injection System injects a mixture of water/methanol into the intake of a forced induction engine. Injecting water/methanol allows users to run more boost and ignition timing to gain horsepower and torque. Gains as much as 20% more horsepower and 25% more torque on pump gas are common.
    The AEM Water/Methanol Injection System comes loaded with more STANDARD features and high quality components that any other comparably priced injection system on the market today. The AEM injection kit comes with a 1 gallon tank with built-in low level switch. The "Boost Safe" injection readiness system comes standard in all AEM Water/Methanol Injection Systems. An check valve integrated into the nozzle prevents unintended fluid flow is included standard. One injector and three interchangeable nozzles are included to cover a wide range of potential horsepower levels along with 20 feet of injection tubing to facilitate the system being installed on practically any vehicle.
    Feature:
    - 1 Gallon tank with built in low level switch
    - Boost referenced progressive controller
    - “Boost Safe” readiness safety system
    - Check valve integrated into nozzle to prevent unintended fluid flow
    - One injector and three nozzles to cover a wide range of HP levels
    - High Pressure 200psi Recirculation-style pump
    - Progressive Controller: Start Injection Boost 1-11psi. Full Injection Boost 6-39psi
    - LED dash light for system status and low fluid warning
    - 20 ft. of injection tubing
    Tertarik?
    Boleh reply disini, atau PM atau langsung contact ke 08179845168 (pin: 20CE5B36)
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    J-TOWN
    5 Days 21 Hrs 6 Mins 42 Secs
    Brapaan nih bos??
    Quote Originally Posted by evo3 GTi ijo View Post
    Brapaan nih bos??
    PM sent yaaa...
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Gunung Raya
    1 Wk 3 Days 5 Mins 30 Secs
    brapa harganya om?
    Quote Originally Posted by kliwonz View Post
    brapa harganya om?
    PM Sent yaaaa...
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Cikarang - Jababeka
    4 Days 7 Hrs 47 Mins 34 Secs
    berapaan om ?.. cara pasangnya gimana?
    thanks ya
    Serang_Banten
    22 Hrs 11 Mins 32 Secs
    qlo plus pasang net brp boz?
    jkt
    48 Mins 59 Secs
    Buat NA engine ga bs ya om..?
    jakarta selatan
    2 Wks 18 Hrs 5 Mins 27 Secs
    Quote Originally Posted by Hydra Performance View Post
    Feature:
    Tertarik?
    Thanks,
    tlg PM harga nett + ongkos pasang bos, thx
    Polluted WezT Djakarta
    1 Wk 2 Days 22 Hrs 24 Mins 13 Secs
    Plz pm me price. Tq.
Tekiro MBtech
  1. [WTS] : Water Methanol Injection
    By julle in forum Jual Beli Mesin Lainnya
    Last Post: 24th August 2013, 20:37
  2. +++++++ Water methanol injection ++++++++
    By davys85 in forum Jual Beli Mesin Lainnya
    Last Post: 13th February 2012, 18:06
  3. wts water methanol injection
    By si biru in forum Jual Beli Mesin Lainnya
    Last Post: 2nd February 2012, 10:59
