Good Stuff by ZAPCO
Results 1 to 10 of 11
  • Short URL:  http://modifika.si/239673
    2 Days 8 Hrs 36 Mins 13 Secs
    Good Stuff by ZAPCO
    For Sale GOOD STUFF by ZAPCO
    ZAPCO Power Amplifier DC Reference Type DC350.2
    Specifications :
    Stereo, 4 ohms: 2 x 100 Watts
    Stereo, 2 ohms: 2 x 170 Watts
    Bridged, 4 ohms: 1 x 350 Watts
    T.H.D. + Noise: <0.015% @ 4 ohms
    Features :
    - 2 Channel Amp with On-Board Digital Processing
    - SymbiLinkT Balanced Inputs
    - On-Board, Full Function DSP
    - Intelligent Rail Voltage Control
    - Plays from ½ ohm to 4 ohm Stereo Loads
    - USB Input for PC Control
    - Optional DRC-SL In-Dash Remote Control
    - Optional Digital Programming Network
    - Ducted Flow Cooling
    - Heavy-Duty, High-Current, Insulated Terminal Blocks
    - Space Saving Flush Wiring Connections
    - Heavy-Duty Mini ANL Fuse
    - Bridgeable
    - Three-Channel Capable
    - Gate Drive Boost Circuit
    - High-Current Bipolar Outputs
    - Optically Isolated MOSFET Power Supply
    Pict:
    http://img227.imageshack.us/img227/7230/img00021201101171204.jpg
    http://img683.imageshack.us/img683/879/img00018201101171203.jpg
    ZAPCO Power Amplifier DC1000.4
    Specifications :
    Stereo, 4 ohms: 4 x 150 Watts
    Stereo, 2 ohms: 4 x 250 Watts
    Bridged, 4 ohms: 2 x 500 Watts
    T.H.D. + Noise: <0.017% @ 4 ohms
    Features :
    - 4 Channel Amp with On-Board Digital Processing
    - Bridgeable
    Pict:
    http://img833.imageshack.us/img833/4537/img00020201101171204.jpg
    PIONEER DEH-P80RS
    . Audiophile-speci? cation in all areas delivers the very best sound quality
    . MOSFET 50 x 4 channels high power output built in
    . Auto Time Alignment and Auto EQ automatically set up your system
    to suit your car's acoustic characteristics
    . State of the art DSP (Digital Signal Processing) lets you set a number
    of different listening environments to suit your music or your mood
    . 3 pairs 5V RCA preouts
    . Front-panel auxilliary input for portable music players
    . Easy connection for iPodR and Bluetooth devices via adapter.
    Pict: Menyusul
    Speaker by Vifa:
    ---Tweeter DX25SC---
    Specifications : Tweeter 25mm, 4 Ohm
    Parameters from manufacturer:
    Voice coil & magnet parameters
    Reference efficiency @ 2.83 V / 1 m 93.5 dB/2.83V/m
    Nominal impedance 4 ohm
    Voice coil resistance Re 2.75 ohm
    Voice coil diameter 25.0 mm
    Voice coil inductance Le 0.00 mH
    ---Midbass PL18---
    Midwoofer 180mm, 8 Ohm
    Power handling Pe 100 W
    Reference efficiency @ 1 W / 1 m 87.0 dB/W/m
    Nominal impedance 8 ohm
    Voice coil resistance Re 5.80 ohm
    Voice coil diameter 40.0 mm
    Voice coil height 14.0 mm
    Voice coil inductance Le 0.85 mH
    Max linear excursion Xmax (+/-) 4.00 mm
    SubWoofer ---Xtant 1044---
    Parameters X2.1044
    Fs: 37.19 Hz
    Qms: 7.60
    Cms: 0.077 mm/N
    Mms: 239.20 g
    Rms: 7.34 kg/s
    Vas: 0.560 ft³ (15.86 liters)
    Encl. Displ.: 0.10 ft³ (2.83liters)
    Xmax: 0.670 in (17.02 mm)
    D: 8.677 in (220.40 mm)
    Sd: 59.41 in² (383.23 cm²)
    Vd: 39.61 in³ (0.65 liters)
    Qes: 1.10
    Re: 1.33 Ω
    Bl: 8.20 Tm
    Prms: 600 Watts
    Qts: 0.950
    ηο: 0.072 %
    SPLo: 80.74 dB
    SPL 2.83V/1m: 88.49 dB
    Pict:
    http://img829.imageshack.us/img829/1740/img00017201101171155.jpg
    http://img146.imageshack.us/img146/1192/img00016201101171155.jpg
    ALL in Very Good Condition. PRICE ===BEST OFFER===
    NO PM !!!
    Please Call 081230073838 / PIN: 219688FO
    Thank's...
  2. SbcAgent
    2 Wks 6 Days 23 Hrs 25 Mins 59 Secs
    nongolin pic ya bro...
    sekalian pm harga plss...
    thanksss...
    TANGERANG
    5 Days 5 Hrs 59 Mins 19 Secs
    POWER MANTAP INI GAN
    [QUOTE=michael_andry_s;8258481]nongolin pic ya bro...
    thanksss...
    Thank's bro... Btw gimana cara nongolin pict yach? Itu ada Contact Person nya... bukan milik sy bro...
    UP lageeeeeeeeeeeee................
    TANGERANG
    Boss Jombank kasih harga bagus utk DC1000.4 nya buat temen DC1000.4 saya.
    Thx U
    TANGERANG
    Power maut ini klo harga cocok mau ambil 1 lagi. Bisa tt dg DC360.4 boss? Pm yak tx
    TANGERANG
    Angkat power top ayo diborong
    Quote Originally Posted by Blue-X View Post
    Ini yang jual 'wong njombang' ?
    Jakarta Utara
    4 Days 14 Hrs 51 Mins 27 Secs
    Mantabz diangkat ah buat bos yang ngaku kuli dari surabaya
    Wakakakak pis yah bro
    From your brother in names
    Yung yung
  1. WTS: Zapco IFORCE 4.100 mulus,segel,good quality amp
    By AudioArt in forum Power Amplifier
    Last Post: 22nd October 2012, 14:32
  2. Replies: 28
    Last Post: 11th May 2011, 17:09
  3. Midbass DYNAUDIO MW150, Power Amp ZAPCO Z200, good condition!!!
    By ed_create in forum Speaker - SubWoofer
    Last Post: 5th May 2011, 12:58
  4. W.T.S Toyota Corona Twincam EFI 91 (Good Stuff)
    By b4t4kj4w4 in forum Merk Lainnya
    Last Post: 23rd April 2010, 17:23
  5. C 200 TH 2001 Good Stuff
    By godzilla2099 in forum Merk Lainnya
    Last Post: 8th June 2009, 14:11
