Monoblock Phoenix Gold Xenon 1200 Watt
Results 1 to 10 of 32
  • Short URL:  http://modifika.si/238475
    1 Wk 3 Days 15 Hrs 55 Mins 7 Secs
    Sold, thank u
  2. Autopro
    1 Wk 14 Hrs 4 Mins 39 Secs
    pertamax........
    berapa nih harga pasnya bos?
    ada remote bass nya ga?
    kondisi nya gimana..pernah servis?
    pm ya bos
    1 Hr 6 Mins 10 Secs
    Quote Originally Posted by dewakeren View Post
    pertamax........
    pm ya bos
    pertanyaan saya sama dgn yg ini bos,,,,pm nettnya bos thx
    3 Wks 2 Days 6 Hrs 57 Mins 5 Secs
    Pertanyaan sama dengan yg di atas, PM in harga nya bro thanks
    pertamax........
    pm ya bos
    Quote Originally Posted by KurazAtaKada View Post
    Quote Originally Posted by Dede Freddy View Post
    blm pernah servis, remote tidak ada, harga di pm, thanks
    solo
    2 Hrs 51 Mins 27 Secs
    Pm harganya bro, thx
    surabaya
    Quote Originally Posted by edwin_sasmito View Post
    Mao jual monoblock phoenix Xenon 1200 Watt
    Spesifikasi :
    200 Watt Power Amplifier
    High efficiency (greater than 80%) Class D Operation
    Xe.load™: optimized for any impedance load
    Xe.tune™: 24dB Linkwitz-Riley subsonic and low pass crossovers
    Xe.flow™: variable thermal feedback controlled fans
    Buffered RCA full range thru output
    Remote Monitoring Display (RMD) port
    Low Pass Level control ready (LPL-44)
    1200W x 1 (4-1 ohm)
    Built-in Crossovers
    Optional Remote Voltage Display
    Optional Remote Low-Pass Level Control
    Variable input sensitivty
    0 - 18dB Bass Boost at 45Hz
    CEA-2006 Compliant
    Dimensions: 18.25" L x 10.6" W x 2.5" H
    Number of Channels 1 - Mono
    RMS Power (4 ohms) 1200 watts x 1 channel
    RMS Power (2 ohms) 1200 watts x 1 channel
    RMS Power (1 ohm) 1200 watts x 1 channel
    Total RMS Power Output 1200 watts
    Peak Power Output 2400 watts approx.
    Minimum Impedance Unbridged 1 ohm
    THD at Rated RMS Power <1.0%
    Speaker Level Inputs No
    Preamp Outputs 1 pair
    Built-in Crossover N/A
    Signal-to-Noise Ratio >90 dB
    Bass Boost 0 - 18dB(45Hz)
    Fan Cooled Yes
    Fuse Rating 100A
    Untuk gambar bisa email ke edwin_sasmito@yahoo.com.au nanti di reply, harga bisa pm atau sms ke 0818107889
    Pmin harga netnya gan....
    uuupppp..............
    uuuupppp.................
    1 Wk 4 Days 12 Hrs 42 Mins 20 Secs
    Ppm juga netnya bro.thanks
  1. SALE!!! mono phoenix gold xenon 1200 & JL sub
    By a_ghost in forum Power Amplifier
    Last Post: 1st July 2011, 16:50
  2. WTS : Monoblock Phoenix Gold Xenon 1200W
    By edwin_sasmito in forum Power Amplifier
    Last Post: 7th September 2010, 00:56
  3. Replies: 1
    Last Post: 11th June 2010, 16:32
  4. Replies: 3
    Last Post: 9th June 2010, 08:59
  5. Replies: 2
    Last Post: 10th April 2010, 22:08
