Mazda MX6 Indonesia
Page 1 of 5 12345 LastLast
Results 1 to 10 of 44
  • Short URL:  http://modifika.si/238294
    mana kek..
    6 Days 4 Hrs 26 Mins 24 Secs
    Mazda MX6 Indonesia (Original Only)
    Hai2 all..
    Thread ini gue buat untuk sarana komunikasi para MX6 user, owner, lover di Indonesia..
    Hopefully kita bisa berbagi info bengkel, toko spareparts, junkyard dll..
    Spoiler for MX6 brochure & commercial, 56k go bake a cake: Show
    4WS..
    BORKED
    BORKED
    BORKED
    BORKED
    About MX6 1st gen..
    Spoiler for courtesy wikipedia: Show
    The first generation MX-6 appeared in 1988 and lasted until 1992 in the United States. In some markets the model years were from 1987 to 1991. It was based on a series of futuristic sports compact concept cars of the early 1980s. It was a large coupé, based on the Mazda GD platform, and was powered by the I4 Mazda F engines.
    The US market made use of the F2 2.2 L engine, with the base engine produced 120 hp (82 kW), but a 145 hp (108 kW) turbocharged version was available. European and Japanese market versions were shipped with either the F8 1.8 L, FE 2.0 L or FE-DOHC 2.0 L DOHC engines.
    The MX-6 was produced with two transmission options, a 5-speed manual transmission or a 4-speed automatic with overdrive. The MX-6 was also known to be a very reliable car, mechanically.
    This generation was available in several trim levels, which differ depending on the market the vehicle was sold in. In the United States, the MX-6 was available in DX, LX, LE, and GT trim levels:
    DX was the "bare bones" model, offering the base 120 hp (89 kW)/130 lb·ft (176 N·m) F2 2.2 L engine and few options, but most MX-6s sold in the U.S. were equipped with air conditioning.
    LX added power windows, power locks, and power mirrors, as well as an optional electric moonroof.
    LE was a rare "Leather Edition" model that was the same as the LX, but included leather seating surfaces and a leather wrapped shift knob on manual transmission-equipped vehicles.
    GT included all options from the LX, but also stepped up to the F2T 2.2L turbocharged, intercooled engine, which put out 145 hp (108 kW) and 190 lb·ft (258 N·m) of torque delivering a significant performance boost. It also had 4 wheel disc brakes with ABS as optional, and 3 way electronically adjustable suspension, dubbed AAS.
    In 1989, Mazda offered a special four wheel steering (commonly abbrieviated 4WS) option on MX-6 GTs destined for the U.S. This system consisted of an electronically controlled rear steering rack that turned the rear wheels opposite to the fronts at low speeds to improve cornering, and turned the rear wheels with the fronts at high speeds to improve highway lane change maneuvering. This option was available through all years for GT models in other markets.
    European spec vehicles shipped as the 626 Coupé and commonly received either the 1.8 L SOHC F8 or 2.0 L SOHC FE engine in GLX models, or the 2.0 L FE-DOHC engine in their GT models. 4WS was a common option for European 626 Coupés. Australian vehicles were almost always equipped with the 2.2 L turbocharged F2T engine as the US models, as well as 4WS. They also carried the MX6 name of the American models.
    Asian spec vehicles were shipped as the Capella C2 and were available in several trims, most notably GT-R (FE-DOHC and 4WS), GT-X (FE-DOHC and AAS) or GT-S (F8 and 4WS or AAS).
    New Zealand received vehicles in either European spec or Australian spec, selectable on order. As such, NZ GTs can have either the F2T 2.2 L turbocharged engine or the FE-DOHC 2.0 L DOHC, with optional 4WS.
    First generation
    Also called Mazda 626 Coupé
    Mazda Capella C2
    Production 1988-1992
    Platform Mazda GD platform
    Engine(s) North American market
    2.2L 120 hp (89 kW) I4 F2
    2.2L 145 hp (108 kW) I4 F2T
    European market
    1.8L 80 hp (60 kW) I4 F8
    2.0L 112 hp (84 kW) I4 FE
    2.0L 145 hp (108 kW) I4 FE-DOHC (Indonesia Domestic Market)
    Japanese Domestic market
    Wheelbase 99 in (2514.6 mm)
    Length 177 in (4495.8 mm)
    Width 66.5 in (1689 mm)
    Height 53.5 in (1359 mm)
    Fuel capacity 15.9 US gallons (60.2 L; 13.2 imp gal)
    Related Ford Probe
    Mazda 626
    Mazda Capella
    MX6 Indonesia
    Spoiler for beberapa anggota kita: Show
    GROUP FACEBOOK (Indonesia)
    GROUP FACEBOOK (worldwide)
    mana kek..
    Bengkel Recommended
    Spoiler for bengkel: Show
    JAKARTA
    ANEKA JAYA SERVICE (Duren Sawit) 0816-13111-28 (Pak Asdin)
    bisa engine swap, bikin wiring engine dll, barang2 copotan mazda jg ada
    salah satu kerjaannya, ford champ mesin KF V6
    BOGOR
    BENGKEL REMAP ECU tuk semua boil ada d daerah ciomas - bogor
    pas gw ksana si babe yg punya lg bongkar ECUnya Ford Escape 2008,ex singapore blum ada,harga barunya 14 juta,ama dia cma tambah chip aja 500rb beres
    trus tadi juga lagi cetak koil...
    namanya Pak Dadang..Pak Dadang...
    cp 0877 7036 6226/0251 9713175
    gw juga siap anterin klo agan2 ada masalah ECU or mau remap...
    tambahan dia juga punya bukunya MX-6 n program kompi tuk system errornya MX-6 "
    bersambung...
    Toko Sparepart
    Spoiler for sparepart: Show
    JAKARTA
    UTAMA MOTOR
    Pasar Cipete Blok D/7
    021 - 7392371 / 0816700733
    bisa inden beraneka macam spareparts MX6 kita..
    SINGAPORE MOTOR
    Proyek Senen Blok V Lt 3 Lot C no 18
    021 - 428 02531 / 0813 1468 8989 (Edisson)
    Sedia part copotan untuk mx6 termasuk engine..
    BANDUNG
    KOSAMBI EXPRESS
    Jl. Jendral Ahmad Yani No 86-88
    Bandung, Jawa Barat
    Phone: 022-7305263
    Fax : 022-7312928
    bersambung...
    F.A.Q
    Spoiler for frequently asked question: Show
    Sticker fuse box ruang mesin hilang?
    http://img534.imageshack.us/img534/1452/bodyelectricalsystem4.jpg
    Ecu/airflow rusak & ga nemu copotannya?
    Dengan beberapa rubahan jalur kabel kita bisa pakai ECU & Airflow cronos 2000 (selengkapnya silahkan telpon Pak Asdin)
    PCD MX6 brp sih?
    5x114.3 bisa sih pake mercy (5x112) tapi sebaiknya jangan, tetep aja ada resikonya..
    MX-6 Wiring diagram
    http://www.mediafire.com/?1ibjj67674nb87o
    pass: wiringdiagrams21.com
    MX-6 Parts Catalog
    http://www.mediafire.com/?rtcuye9g6h3hta3
    FE3N Workshop Manual
    http://www.mediafire.com/?hd544ptg7afdb5g
    FE3N ECU Pinouts
    http://www.mediafire.com/?a421p4q6eyt2nc8
    3 Wks 1 Day 16 Hrs 12 Mins 54 Secs
    halo..absen mx-6 item..
    mana kek..
    KOPDAR berikutnya (jakarta dan sekitarnya), MINGGU 2 OKTOBER 2011, 15:00 s/d selesai, di parkiran sebrang ISTORA SENAYAN.. salam 2 pintu!
    Kopdar Perdana Regional Jakarta, Minggu 23 Januari 2011..
    Spoiler for kopdar pertama jakarta: Show
    walaupun baru 5 mobil, kesampaian jg kopdar, thx ya yg udah dateng, ayo2 region lain ditunggu laporan kopdarnya hehee..
    Quote Originally Posted by ordni View Post
    halo su, kayaknya bakalan kita doang ini yg ngoceh.. hahaaa
    iya,sepi disini su..
    mana kek..
    MX6 di negara2 lain
    Spoiler for pics: Show
    autocross build
    MX6 pada balapan
    Spoiler for cekidot: Show
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    lagian lo geblek, beli mobil yg cuma dikit.. susah bikin komunitasnya..
    lu sih ikutan bokap gw.makin geblek kan
    mana kek..
    Quote Originally Posted by jigongemas View Post
    tapi kan gue ngga rombak2 body :p
    3 Days 6 Hrs 50 Mins 4 Secs
    assalamualaikum..
    sholat jumat dulu deh..
GT Radial NGK Busi
  1. Mazda Biante Masuk Indonesia Bermesin 2.0 Liter
    Last Post: 20th January 2017, 16:55
  2. Mazda Biante Resmi Meluncur di Indonesia
    Last Post: 20th January 2017, 16:54
  3. Mazda CX-5 Meluncur Di Indonesia Pada 9 Mei 2012
    By GPS.Autotrack in forum Berita Otomotif Mobil
    Last Post: 16th July 2014, 11:04
  4. Replies: 57
    Last Post: 14th July 2014, 13:52
  5. Replies: 208
    Last Post: 4th December 2012, 11:13
