WTS: Home Audio KEF & Whaferdale
Page 1 of 26 12345 ... LastLast
Results 1 to 10 of 256
  • Short URL:  http://modifika.si/237726
    Jakbar
    6 Hrs 33 Mins 22 Secs
    Jual Speaker Home display toko:
    1. Speaker KEF Q Compact
    Specifications:
    Design: 2 way bass reflex
    Drive Units: MF: 130 mm (5") UNI-Q with
    HF:19 mm (") aluminium dome
    Frequency Response at 15
    horizontally off axis 3 dB: 50 Hz - 27 kHz
    Crossover Frequency: 2.8 kHz
    Amplifier Requirements: 10 - 100 W
    Sensitivity (2.83V/1m): 89 dB
    Maximum Output (SPL): 109 dB
    Impedance: 8Ω
    Dimensions: 180mm Width
    280mm Height
    250mm Depth
    Weight: 3.9 kg
    2.Speaker Kef C3
    Specifications:
    Drive Units: LF: 130mm (5.25”)
    HF: 19mm (") aluminium dome tweeter
    horizontally off axis 3 dB: 54Hz - 40kHz
    Crossover Frequency: 2.5kHz
    Amplifier Requirements: 10 - 125W
    Sensitivity (2.83V/1m): 88dB
    Maximum Output (SPL): 108dB
    Impedance: 8Ω
    Dimensions: 177mm Width
    290mm Height
    256mm Depth
    Weight: 4.4kg
    [IMG]http://i53.tinypic.com/20uztx3.jpg[/IMG
    3.Speaker Surround KEF Q2 Ds
    Specifications:
    Drive Units: LF: 130mm (5 ")
    MF: 2x165mm (6 ") UNI-Q with
    HF:19mm (") aluminium dome
    horizontally off axis 3 dB: 80Hz - 27kHz
    Crossover Frequency: 220Hz - 3kHz
    Amplifier Requirements: 15 - 120 W
    Sensitivity (2.83V/1m): 91 dB
    Maximum Output (SPL): 111 dB
    Impedance: 8Ω
    Dimensions: 442mm Width
    220mm Height
    210mm Depth
    Weight: 7.7kg
    4.Subwoofer KEF PSW1000
    Specifications:
    Drive Units: 200mm (8")
    Frequency Response: 38Hz - 150Hz
    Amplifier: 100W
    Maximum Output (SPL): 106dB
    Internal Volume: 15.4 litres
    Dimensions: 320mm Width
    345mm Height
    360mm Depth
    Weight: 14.7kg
    5.Subwoofer Whaferdale Diamond SW150
    WHARFEDALE DIAMOND SW150 SUBWOOFER SPECIFICATIONS
    Amplifier power (watts):150 RMS
    Controls: Adjustable frequency roll-off (10Hz steps between 35 and 85 Hz) and volume, phase reverse
    Auto mute/power:Switchable auto-standby
    Magnetically shielded?:No
    W x H x D (mm): 330 x 330 x 370
    Weight (kg): 20
    Frequency response (Hz):35 - 110
    Connections: High-level (speaker) and low level (line phono/RCA) inputs
    Drivers:250mm, forward-firing bass driver
    Finish:Black
    Supplied accessories: Removable grille
    Extra: Matching hifi and surround speakers available too
    Info PM aja
    atau Call/SMS ke 021-98903636
    FS :
    - Tru Tech A Class 28jt
    - Sub Crescendo Etude 3.12" 2.5jt nett
    - Kabel2 Audience
  2. clickbet88.com
    Jakbar
    uppppppppppppppp
    FS :
    - Kabel2 Audience
  4. 17th January 2011, 13:43
    Reason
    spam
  5. #3
    2 Days 23 Hrs 39 Mins 16 Secs
    bro PMin harga sub kef n wharfedalenya yah
  6. #4
    Jakbar
    pm sent,,,,,,
    FS :
    - Kabel2 Audience
  7. #5
    Jakbar
    upppppppppp
    FS :
    - Kabel2 Audience
  8. #6
    Jakbar
    upppppppppppppp
    FS :
    - Kabel2 Audience
  9. 20th January 2011, 14:34
    Reason
    SPAM
  10. #7
    Jakbar
    uppppppppppppp
    FS :
    - Kabel2 Audience
  11. #8
    Jakbar
    uppppppppppppp
    FS :
    - Kabel2 Audience
  12. #9
    sub kef and wharfedale
    bro minat sama subnya... tolong pm sama sms (jarang ol) ke 081802153584 untuk nett pricenya...ditunggu tks
  13. #10
    Jakbar
    Quote Originally Posted by iraindra View Post
    dah di sms bro. tq
    FS :
    - Kabel2 Audience
Datsun 300x250 Venom 300x250
  1. Home Theater and Home Audio ( update foto )
    By vian11 in forum Speaker - SubWoofer
    Last Post: 23rd May 2010, 00:51
  2. Home Theater and Home Audio ( update foto )
    By vian11 in forum Power Amplifier
    Last Post: 23rd May 2010, 00:28
  3. Home Theater and Home Audio ( update foto )
    By vian11 in forum Bursa Audio Lainnya
    Last Post: 23rd May 2010, 00:27
  4. Home Theater and Home Audio ( update foto )
    By vian11 in forum Head Unit & Processor
    Last Post: 23rd May 2010, 00:25
