ScanSpeak 23W/4557T-02, 9" Aluminum Cone Subwoofer...sold
Results 1 to 10 of 15
  • Short URL:  http://modifika.si/237553
    ScanSpeak 23W/4557T-02, 9" Aluminum Cone Subwoofer, Black Cone...sold
    Same model as 23W/4557T, except with a black cone.
    The Scan-speak 23W/4557T is a very high end subwoofer, designed to be used with a passive radiator in a small enclosure. This sub has a very rigid aluminum cone, low loss rubber surround and cast frame. The passive radiator is similar, but with a weight attached to the bass of the cone. The 23W/4557T is using the SD-1 motor system. There are gold plated binding posts and the woofer is covered by a decorative rubber cap.
    Frequency response with the passive is down to 25Hz. One cubic foot sealed has an F3 of 33Hz.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 82 dB
    Free air resonance Fs 20.5 Hz
    DC resistance 3.45 ohm
    V.C. inductance 0.45 mH
    Power 225 W
    Effective cone area 232 cm2
    V.C. diameter 50 mm
    VC height -
    Air gap -
    Lin. & max. excursion 13 / 20 mm
    Air gap flux density -
    Force factor BL Product 9.3 Tm
    Moving mass incl. air 101 g
    Net weight 4.6 kg
    Vas 45.6 ltrs
    Qms 4.8
    Qes 0.52
    Qts 0.47
    Outside diameter: 255mm
    Cut out: 225mm
    Depth: 135mm
    25.4mm = 1" = 2.54cm
    call
    081282357888
  2. 36Goal.com
    klaten
    keluar lg barang2 ajib...
    4 Days 8 Hrs 1 Min 15 Secs
    Bos christ PM ya special price nya ama kondisinya hehehe..
    hehehe,bisa aja nich bos danny.....
    sms sent yach bos ricky,thanks....
    32 Mins 49 Secs
    Boss, tlg pm pricenya ya.
    32 Mins 49 Secs
    Boss, tlg pm pricenya ya. Trus apa bedanya ama yg warna biasa ya?
    2 Days 16 Hrs 39 Mins 19 Secs
    Bos Kris, tolong pm harga. Thanks.
    the city of presidents
    1 Wk 1 Day 16 Hrs 53 Mins 10 Secs
    ngikut bos chris
    minta pm harga nett
    2 Wks 2 Days 19 Hrs 37 Mins 6 Secs
    TECHNICAL DATA:
    Power 225 W
    V.C. diameter 50 mm
    VC height -
    Air gap -
    Net weight 4.6 kg
    Vas 45.6 ltrs
    Qms 4.8
    Qes 0.52
    Qts 0.47
    Cut out: 225mm
    Depth: 135mm
    call
    081282357888
    woow...sq banget kayanya...pm in nettnya ya boss
    2 Hrs 24 Mins 45 Secs
    ikutan minta nettnya dong bos chris...
Venom 300x250 MBtech
  1. ScanSpeak 23W/4557T 9" Aluminum Cone Subwoofer, Silver Cone
    By bang-t in forum Speaker - SubWoofer
    Last Post: 27th January 2011, 23:56
  2. ScanSpeak 23W/4557T Rp.2.850.000/Pcs #NEW#
    By TOKOSPEAKER in forum Speaker - SubWoofer
    Last Post: 14th November 2010, 01:55
  3. Replies: 13
    Last Post: 16th January 2010, 09:15
  4. Replies: 51
    Last Post: 14th November 2009, 06:29
