Scan-Speak Illuminator 15WU/4741T-00 5" Woofer (sold,thanks modcom..)
Results 1 to 7 of 7
  • Short URL:  http://modifika.si/237546
    Scan-Speak Illuminator 15WU/4741T-00 5" Woofer, 4 ohm....sold
    Scan-Speak Illuminator 15W/4741T-00 5" Woofer
    * Paper cone
    * Cast frame
    * Neodymium motor
    * Underhung voice coil
    * long excursion
    The Illuminator woofers are based on compact under-hung motor systems with large neodymium ring magnets. The patent pending motor offers a very long linear excursion together with a very high force factor. The top plate is shaped to “guide” the backside airflow around the motor and with the very open cast aluminum chassis design the driver is virtually free from compression.
    Electrical Data
    Nominal Impedance Zn 4 ohm
    Minimum Impedance Zmin 4.7 ohm
    Maximum Impedance Zo 41.3 ohm
    DC Resistance Re 3.2 ohm
    Voice Coil Inductance Le 0.5 mH
    TS Parameters
    Resonance Frequency fs 34 Hz
    Mechanical Q factor QMS 3.47
    Electrical Q factor QES 0.25
    Total Q factor Qts 0.23
    Force Factor Bl 6 Tm
    Mechanical Resistance Rms 0.8 Kg/s
    Moving Mass Mms 13 g
    Suspension Compliance Cms 1.69 mm/N
    Effective Piston Area sd 92 cm^2
    Equivalent Volume Vas 20.1 ltrs
    Sensitivity 2.83V/1m 85.9 dB
    Power Handling
    100h RMS noise test IEC 80 W
    Long-term Max Power IEC 18.3 150 W
    Short Term Max power IEC 18.2 200 W
    Voice Coil and Magnet Parameters
    Voice Coil Diameter 42 mm
    Voice Coil Height 8 mm
    Voice Coil Layers 4
    Height of the Gap 20 mm
    Linear Excursion +/- 6 mm
    Max mech. excursion +/- 12 mm
    Diameter of Magnet 90 mm
    Height of Magnet 4 mm
    Weight of Magnet .13 Kg
    Suggested box sizes:
    Sealed box of 0.15 cubic feet for an F3 of 115Hz
    Vented box of 0.2 cubic feet with 1.5" diameter vent by 6" long for F3 of 56Hz
    call
    081282357888
    Bexazi ..
    wuuuhhh ... ngiler nih
    hehehe,bis aja nic bos lebay......
    1 Mth 1 Wk 4 Days 5 Hrs 26 Mins 12 Secs
    Duh tau ada brg ma'nyus gini,kmrn gw tukerin deh dyn nya heheheheheheh
    hehehe,bisa aja nich bos siung.................
    3 Mths 1 Wk 11 Hrs 33 Mins 45 Secs
    pls pm nettnya donk bos, tks
    sorry bos eka,sudah sold bos..
  1. SALE: Scan speak 15WU Illuminator (Sold)
    By ace911 in forum Speaker - SubWoofer
    Last Post: 25th May 2010, 11:10
  2. scan-speak illuminator 15wu
    By blue andry in forum Diskusi Speaker
    Last Post: 14th December 2009, 12:43
  3. Replies: 13
    Last Post: 27th October 2009, 01:36
  4. WTS Tweeter Scan Speak Illuminator <--- SOLD (Tnx-Modcom)
    By Birdsongs in forum Speaker - SubWoofer
    Last Post: 5th October 2009, 14:15
  5. Replies: 2
    Last Post: 1st August 2009, 07:48
