+++ power monobloc hdt dan memphis +++
  • Short URL:  http://modifika.si/237488
    2 Days 6 Hrs 54 Mins 16 Secs
    permisi agan agan semua, mau numpang jualan power monoblok
    Harmonic Drive xp 1200.1
    spec
    ▪ digital Class-D linkable mono block amplifier
    ▪ Double sided through hole epoxy PCB
    ▪ Stable into 1 ohm load workable
    ▪ Daisy - chain through output RCA
    ▪ Two amplifier linkable function : output master and input slave
    ▪ Rated Power Output : 1200W x 1Ch
    ▪ Low Pass Crossover : 35Hz ~ 300Hz
    ▪ Frequency Response : 10Hz ~ 350Hz (+/-dB)
    ▪ Input Sensitivity : 200mV ~ 6V (+/-5%)
    Memphis pr1.1000
    spec
    # Power Reference Series Class D Monoblock Car Amplifier
    # RMS Power Rating:
    * 4 ohms: 300 watts x 1 chan.
    * 2 ohms: 600 watts x 1 chan.
    * 1 ohm: 1000 watts x 1 chan.
    # Remote bass level input (remote level control sold separately)
    # LED power and protection indicators
    # Tuned Bass EQ (0-18 dB bass boost at 45 Hz)
    # Preamp RCA outputs
    # Internal cooling-fan
    # RCA level inputs
    # Variable low-pass filter (50-350 Hz, 24 dB/octave)
    # Subsonic Filter (20-50 Hz)
    # Frequency response: 10-400 Hz
    # Dimensions: 12.6"L x 10"W x 2.3"H
    penampakan
    fast response 0817455236
    bandung
    12 Hrs 54 Mins 11 Secs
    boleh minta di pm harga nett nya?
    3 Wks 2 Days 6 Hrs 57 Mins 5 Secs
    Bro tolong PM in harga kedua power di atas, thanks
Venom 300x250
  1. Replies: 8
    Last Post: 8th December 2011, 08:19
  2. POWER MEMPHIS (USA) 5ch, 4ch, 2ch, Monoblock
    By AB1971KE in forum Power Amplifier
    Last Post: 28th September 2011, 09:29
  3. Replies: 6
    Last Post: 23rd September 2011, 22:07
  4. Replies: 36
    Last Post: 11th April 2010, 13:21
  5. WTS:MEMPHIS CAR AUDIO..
    By de_reds33 in forum Power Amplifier
    Last Post: 11th March 2010, 09:52
