WTS STD SUSPENSION
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/237466
    indonesia
    WTS STD SUSPENSION
    PERMISI MAU NUMPANG JUALAN SUSPENSION NRH TIPE MODEL ADA DIBAWAH INI
    http://technikartracebreed.blogspot.com/
    S1 Suspension System - More than a basic suspension
    With Std Standard you get the comfort you deserve even with our entry level suspension systems. It is possible to lower the height of your car without affecting the travel of the suspension. Our suspension systems retain more stroke, so your handling will not be affected by the inconvenience of a shortened stroke drop such as a shock & lowering spring combo kit or a cheap coil over system, which are found on many well know brands. This suspension system offers a higher level of suspension for the same price. A Std S1 system is made with the same manufacturing processes and technology as all our other suspension systems. As well, all our suspension systems have a separate ride height and pre-load adjustments which is something that even some of the better known brands cannot claim.
    Std exclusive scaled system for easier installation
    Full length adjustment system on lower mount
    Separate ride height and spring pre-load adjustments
    Forged aluminum top mount for double wishbone applications
    Steel lower mounts on some applications
    Aluminum alloy construction for spring seat and locks
    FULL LENGTH ADJUSTMENT SYSTEM
    Our full length adjustment system from the lower mount allows separate ride height and spring pre-load adjustments to increase performance while keeping the comfort. You can decide on your desired height first without affecting the spring pre-load, and afterwards you can set the pre-load.
    SCALED SUSPENSION SYSTEM FOR AN EASIER INSTALLATION (NEW)
    To facilitate your installation, the cylinder of the suspension system has a reference graduated scale. It's simple and it is proof of how well the product has been developed. As far as we know, we are the only brand in the world to provide our suspension systems with a scale system.
    R1 Suspension System - The perfect street suspension
    The Std R1 suspension system is the best choice for a conventional car driven on a day to day basis. You can lower your vehicle without affecting the travel of the suspension. Moreover you can easily adjust the damping force to increase the performance of the suspension in order to deal with different road types and conditions. This suspension system provides performance without sacrificing comfort; it provides everything you need to enjoy driving your car in the street and on the track without the added confusion of too many adjustments.
    * Adjustable dampening force (compression and rebound) *
    * Std exclusive scaled system for easier installation
    * Full length adjustment system on lower mount
    * Separate ride height and spring pre-load adjustments
    * Forged aluminum top mount for double wishbone applications
    * Steel lower mounts on some applications
    * Aluminum alloy construction for spring seat and locks
    * Compression and rebound: Each application has a different number of manual damping adjustments
    DAMPING FORCE ADJUSTMENT
    All the suspension systems from the R series provides a multi-positional manual damping force adjustment. Each application has a specific number of adjustments. To increase rigidity, you turn clockwise, whereas to decrease rigidity, you turn counter-clockwise. Set your handling and ride as comfortably as you like.
    AFFORDABLE
    R3 Suspension System - Weekend racer
    The Std R3 suspension system has an enhanced forged front pillow-ball top mount to increase steering response. The R3 suspension system also includes an adjustable top mount camber plate for McPherson vehicles. This suspension system is perfect to use on the road and on the track for time attack or drifting and can even be used on a real race car.
    * Front top mount includes an adjustable camber plate*
    * Front suspension is mounted on pillow ball
    * Adjustable dampening force (compression and rebound) **
    * For cars equipped with front strut type suspension (McPherson).
    ** Compression and rebound: Each application has a different number of manual damping adjustments
    R5 Suspension System - Weekend racer
    he STD R5 suspension system features the same advantages offered with the R3 suspension system and in addition it includes both front and rear pillow-ball top mounts.
    ** Compression and rebound: Each application has a different number of manual damping adjustments.
    R7 Drift Suspension System - Life is so much better sideways
    Std R7 Drift suspension system features spring rates, damping force and racing fluid for a stable initiation and increased car control during a drift. With this feature, you will feel a greater difference in damping force adjustment every time you make a damping adjustment.
    * Increased damping force and racing fluid for drift use
    * Front and rear suspensions are mounted on pillow ball
    *For cars equipped with front strut type suspension (McPherson).
    **Compression and rebound : Each application has a different number of manual damping adjustments.
    R7 Time Attack Suspension System - Beat the clock
    STD R7 Time Attack suspension system features increased damping force and racing fluid for racing use. With this feature, you will feel a greater difference in damping force adjustment every time you make an adjustment.
    BORNEO
    4 Hrs 27 Mins 25 Secs
    Cuma mau nanya satu bos, toko nya dimana ya...?
    indonesia
    Quote Originally Posted by kerupukulit View Post
    untuk dijakarta bisa contact
    std jakarta
    jalan paseban no. 32a
    atau advance motorsport buat informasi bisa hubungi alamat atau contact person yg ada di signature
    indonesia
    Uppppp uppp
    19 Hrs 8 Mins 56 Secs
    uat altism2004 jlan sehari hari, bagusnya pake yg mana y bos..?pmin hrga skalian y bos
MBtech GT Radial
  1. WTB: Air suspension
    By dmoy in forum Per & Shockbreaker
    Last Post: 19th October 2012, 14:33
  2. info bengkel rekondisi air suspension/ hydrolik suspension
    By indosamili in forum Diskusi Kaki-Kaki
    Last Post: 19th September 2012, 00:05
  3. Replies: 0
    Last Post: 25th January 2012, 01:23
  4. Air Suspension E39 '97
    By E36 in forum Per & Shockbreaker
    Last Post: 4th April 2010, 16:34
  5. WTS : AIR SUSPENSION Second
    By HOLI in forum Bursa Kaki Lainnya
    Last Post: 30th May 2009, 14:32
