VIPEC product
Thread: VIPEC product
  • Short URL:  http://modifika.si/237464
    indonesia
    VIPEC product
    TECHNIKARTRACEBREED.BLOGSPOT.COM
    permisi mau jualan barang2 dibawah ini neh
    V44 Model ECU
    The ViPEC V44 is our budget model. Despite this, the V44 is very capable with control of up to four variable cams, support for engines up to twelve cylinders. Software has very flexible options over how the inputs and outputs are controlled, and allows the user to design their own functions to control all sorts of devices. Precise control of injectors and ignition angle are guaranteed at very low or high RPM or manifold pressures. A very high level of protection from interference and tolerance of trigger input errors has been built into this ECU, ensuring a smooth running engine even under the most demanding conditions.
    Motor Sport features include: Antilag, Flatshift, Launch control and traction control in first gear.
    Individual Cylinder Knock control, when external digital knock amplifier used.
    Peak and hold injector drivers. Both the peak Amps and hold Amps can be set separately in the software for optimum injector control.
    Closed loop control of idle speed and boost pressure makes for a "factory" idle speed stability, and precise control of boost pressure. Boost control can be setup to provide a different boost in each gear or switch between boost control tables.
    Feature Comparison for V44, V88 and plug-in ECU
    HARDWARE:
    Main Connector 34 Pin waterproof.
    USB data link connector plus CAN
    Case, silver extruded aluminum, 142 x 172 x 42 mm (overall).
    40 MHz Specialized Automotive Microprocessor.
    Ignition control to 0.1 degree, fuel to 0.01 ms -
    32 Bit Calculation -
    10 Bit ADC Resolution
    Max 20000 RPM
    ECU to PC data link operates at up to 57600 baud for fast data update an logging using PC logger
    High efficiency power supply & output drivers for reduced power consumption and reduced self-heating.
    Four ignition outputs. Sequential to 4 cylinders and wasted spark up to 8 cylinders. Support for engines up to 12 cylinders with distributors.
    Software selectable dwell or O/P pulse duration modes possible.
    Four coil dwell, software selectable.
    Four low current injector outputs. Optional Peak and Hold drivers available.
    Spare injector and ignition outputs can be used for output control.
    8 Auxiliary Outputs
    4 Digital Inputs
    4 Analog Voltage Inputs
    2 Temperature Inputs
    3 Load Inputs (MAP, TPS, MAF)
    2 Trigger Inputs (Reluctor, Optical or Hall Sensors)
    Camshaft & crankshaft sensor inputs individually software configurable for hall effect & reluctor sensor types. Response speed is also software configurable for improved noise immunity.
    Four general purpose digital Inputs with logic level sensitivity & pullup to +5volts. Useable for speed, switch input and camshaft position measurement.
    Variable Camshaft control for up to four camshafts. VANOS and other VVT and VVT-i supported.
    NTC or PTC air temp sensors, software selectable.
    Internal 4 bar map sensor. External map sensor support.
    Internal baro sensor. Corrections for barometric changes in real time.
    Stepper motor idle control, two and three wire idle control.
    Support for air flow meters.
    Tacho & Diagnostic outputs.
    Communication with PC software via USB cable. (No need for Serial to USB adapters)
    Kit includes:
    2 Meter Harness
    Air and water temperature sensors.
    USB Cable
    Manual
    SOFTWARE:
    Tuning tools, QuickTune Mixture Table, Maths Key.
    Launch Control (two step rev limiter based on vehicle speed).
    Flatshift (change gears without clutch at WOT using standard gearbox).
    Antilag (keep turbocharger on boost during gear changes) with turbo cooldown function.
    Selectable ignition tables.
    Up to 440 Zone Fuel Table with configurable load and RPM centres. MGP, MAP and load options.
    5D Fuel Mapping.
    Many correction tables for precision fuel & ignition adaption.
    Digital Trigger Decoding.
    Reluctor, Optical or Hall Sensors.
    Programmable filtering and arming thresholds.
    Configurable trigger patterns or preset triggering options, such as, Multi tooth, missing tooth, Subaru, Nissan, Mitsubishi, Ford, Mazda, GM, Suzuki and Toyota triggers. Software selectable trigger angle.
    Support for up to four rotor engines with ignition split.
    Dedicated idle control with additional settings for better adaption to changing operating condition and a more stable idle.
    Open loop boost control, switch boost pressures, different boost in each gear.
    A/C compressor control.
    Closed loop narrow band.
    Closed loop wideband at WOT.
    Tacho and speedo sweep function.
    Cooling fan control.
    General purpose control modules for O/P control. (use for variable fuel pump, power steering, inlet manifold air valves, extra temperature control devices etc) some of these are capable of PID feedback control.
    Mapping via manifold pressure, throttle position, manifold and throttle or manifold.
    V88 Model ECU
    The ViPEC V88 is our most advanced ECU. This ECU has many features which allow it to be setup to suit various types of engine configurations. It has very flexible options over how the inputs and outputs are controlled, and allows the user to design their own functions to control all sorts of devices. Precise control of injectors and ignition angle are guaranteed at very low or high RPM or manifold pressures. A very high level of protection from interference and tolerance of trigger input errors has been built into this ECU, ensuring a smooth running engine even under the most demanding conditions.
    Variable camshaft control for up to four camshaft. Control of camshaft position is very precise and time taken to advance from full retard to full advance is less the 1 second. Support for VVT and VANOS systems.
    Closed loop control of idle speed and boost pressure makes for a "factory" idle speed stability, and precise control of boost pressure. Boost control can be setup to provide a different boost in each gear.
    Individual Cylinder Knock control, with support for two sensors. Knock control is user definable with flexible settings to allow precise knock control.
    E-Throttle (Electronic Throttle Control).
    Peak and hold injector drivers are 10 amp. Both the peak Amps and hold Amps can be set separately in the software for optimum injector control. See setup screen.
    HARDWARE:
    Main Connector 2 x 34 Pin waterproof.
    Case, silver extruded aluminium, 169 x 172 x 42 mm (overall).
    40 MHz Specialised Automotive Microprocessor.
    Max 20000 RPM
    ECU to PC data link operates at up to 115k baud for fast cal down load & Log file upload (19sec typ for 112k bytes). 112k logging memory.
    Internal Diagnostic light & optional remote light.
    Eight ignition outputs. Secquential to 8 cylinders and wasted spark up to 16 cylnders.
    Software selectable mappable dwell or O/P pulse duration modes possible.
    Eight coil dwell, software selectable.
    Eight high current injector outputs.
    10 Auxiliary Outputs
    11 Digital Inputs
    4 Temperature Inputs
    11 Analog Inputs
    2 Knock Inputs
    Support for Reluctor and Hall effect crank and cam sensers.
    Eleven general purpose digital Inputs with logic level sensitivity & pullup to +5volts. Useable for speed measurement. Switch I/Ps. Four are useable for Camshaft position measurement.
    Individual Cylinder Knock with support for two sensors.
    External 2.5 bar or 7 bar map sensor, software selectable.
    Support for most idle valve type including 2 wire, 3 wire & stepper possible. Stepper pins can be used for spare outputs if not used for idle control.
    Internal barometric pressure sensor.
    E-Throttle (DBW, Fly by wire) option. No external controller required. The throttle control is built into the V88.
    SOFTWARE:
    Tuning tools, QuickTune, Mixture Table, Maths Key.
    5D Fuel Mapping.
    Configurable trigger patterns or preset triggering options, such as, Multi tooth, missing tooth, Subaru, Mazda, Nissan, Suzuki, Mitsubishi, Ford and GM and Motronic.
    Support for two, three or four rotor engines with ignition split.
    Fly by wire throttle control will full control over the settings and operation.
    Plug-in ECU.
    Vipec has produced replacement ECU boards and adaptors for the original ECU on Mitsubishi EVO 1,2,3,4,5,6,7,8 and 9. Subaru WRX 1995-96, 1997-98, 1999-00 and 2001-2007. Mazda MX5 and RX7. Toyota GT4 and MR2. Nissan SR and RB engines.
    The original motherboard and connector are removed from the ECU case, and the ViPEC motherboard and connector, clips or screws into the case. The original harness plugs in and the job is done, no wiring and all original sensors are used. External view of ECU case and connector is unchanged from its stock appearance.
    Most plug-in ECU have an internal 2.5 bar map sensor. Optional 7 bar map sensor available. External map sensors also supported.
    Considerable gains in power across the complete RPM range can be achieved with these boards. Both road car and Group N rally car versions available.
    Allows full control over fuel, ignition timing, boost pressure and all other engine functions. All boards have QuickTune software and optional Anti-lag.
    All boards are supplied with base programs are available. Some final tuning will be required.
    3 Days 17 Hrs 55 Mins 51 Secs
    wihh,, serem,,
    yg V44 brapaan bos??, kalo buat mbl jepang 4 cylinder..
    kalo yg v88 lebih advance ya..
    indonesia
    Quote Originally Posted by bagja_nugraha View Post
    wihh,, serem,,
    yg V44 aja uda bisa buat 12 cylinder n uda ada feature telemetry jd kita bisa ngerubah tuningan mobil dr pit kalo yg v88 bisa activin activ suspension buat ngeliet logger suspension dll
    indonesia
    Uppppp uppppp
MBtech Venom 300x250
