WTS power, sub, speaker,dll
Results 1 to 10 of 20
  • Short URL:  http://modifika.si/237456
    Permisi mau numpang jualan....
    SEMUA BARANG SAYA BELI DARI BARU, DAN BELUM PERNAH RUSAK ATAU DI SERVIS APALAGI DIBONGKAR.....
    Barangnya Berupa :
    Spoiler for AUDISON SRX4 SOLD: Show
    Spoiler for waktu masih menempel di mobil: Show
    Spoiler for kondisi sekarang saat akan di upload: Show
    Spoiler for SAAT FOTO BERSAMA: Show
    Spoiler for FEATURES: Show
    Front/rear or front/sub amplifier with built-in crossover. Front channels filter can be hi-pass or full range, rear channels one can be hi-pass, lo-pass or full range. SRx 4 can be used as a 4/3/2 channel amplifier. When you choose 2 channel configuration (left/right), you can use hi-pass, lo-pass or full range functioning. There are 'speakers-in' front/rear inputs and a bypass output.
    * RMS Outputs:
    o 4 x 60 Watt at 4-ohms
    o 4 x 85 Watt at 2-ohms
    o 2 x 60 + 1 x 190 Watt at 4-ohms
    o 2 x 85 + 1 x 170 Watt at 2/4 ohms
    o 2 x 170 Watt at 4-ohms
    * Bridgeable 4 / 3 / 2 Channel Output
    * 2 Ohm Stable
    * High Level Speaker Input
    * Built in Cooling Fan
    * High Pass Crossover
    * Low Pass Crossover
    * RCA Input
    SRX-4 - Audison SRX4 4 Ch Amplifier
    Spoiler for KONDISI DAN HARGANYA: Show
    [Masih berjalan normal
    kondisi fisik 90%
    kondisi kinerja 100% tidak bermasalah
    masih ada dus, buku, obeng bawaannya.
    SOLD
    Spoiler for PUNCH P3001: Show
    Spoiler for SAAT AKAN DI UPLOAD: Show
    Spoiler for MAU MASUK KANDANG: Show
    Spoiler for BOX: Show
    Spoiler for SPESIFICATION: Show
    Number of Channels 1
    Rated Power
    (RMS Continuous Power) 150 Watts x 1 @ 4-Ohms
    300 Watts x 1 @ 2-Ohms
    Total Power
    (Sum of Rated Power) 300 Watts
    Bridgeable No
    Crossover Controls High-Pass (HP): 40-400Hz 12dB/octave Butterworth
    Low-Pass (LP): 40-400Hz 12dB/octave Butterworth
    Tone Controls Bass: 0dB to +18dB @ 45Hz
    Signal Input Low level: 1 RCA pair
    Signal Output Low level: 1 RCA pair
    Power Input Connector Block
    Power Wire Gauge 4 AWG
    Speaker Output Connector Screw terminal barrier strip
    Speaker Wire Gauge 8 AWG to 18 AWG
    Heat Sink Type Cast aluminum
    Cooling Convection
    Remote Controls Punch Bass EQ (included with cable)
    Visual Indicators Power On
    Signal Level
    Thermal Status
    Speaker protection
    Circuit Topology Class Class-bd
    Frequency Response 20Hz to 20kHz +/- 0.5 dB
    Shipping Weight 11.5 Lbs.
    (5.2 Kg.)
    Dimensions (HxWxL) 2.4 x 11 x 11.7 (in)
    6.1 x 27.9 x 29.7 (cm)
    Spoiler for KONDISI DAN HARGA: Show
    Kondisi fisik 85% ada baret di bagian chrome nya
    kinerja 100% normal
    bas knop masih baru dan masih segel gak pernah dipake
    dus, buku manual ada semua
    Harga 1,5jt neti
    Spoiler for SPEAKER SEAS ORCHESTRA DAN CELLO MG10 : Show
    Spoiler for CELLO MG10 SOLD: Show
    SOLD
    KONDISI FISIK 90%
    KINERJA 100% NORMAL BELUM PERNAH SEVIS
    SPEAKER INI UKURAN 3' COCOK UNTUK MIDRANGE
    HARGA SOLD
    Spoiler for SEAS ORCHESTRA: Show
    Spoiler for TWEETER: Show
    Spoiler for MID BASS: Show
    MID BAS ADA PESOK DI BAGIAN TENGAHNYA TAPI GAK PENGARUH KE SUARA KOK
    Spoiler for PASIVE X OVER BAWAAN SEAS: Show
    PASIVE BGAK PERNAH DIPAKAI KARENA SY BUAT CUSTOM
    Spoiler for HARGA: Show
    HARGA 2,5JT
    Spoiler for SUB P1 12': Show
    KONDISI FISIK 85%
    FUNGSI MASIH NORMAL
    HARGA 750K
    Spoiler for CAP. BANK MAS ENGINERING 2F: Show
    MASIH BERFUNGSI SEMESTINYA.
    HARGA 750K
    Spoiler for KABEL-KABEL, DISTRIBUTION BLOCK, RCA PHOENIX GOLD UDAH SOLD: Show
    Kabelnya:
    SUDAH SOLD
    BUAT YG MINAT HUB 081 394 9999 78
    PIN BB by request buat yg serius.
    BARANG ADA DI BANDUNG.
    THANKS
    3 Wks 1 Day 1 Hr 14 Mins 46 Secs
    bro.. pm nett speaker set ya..
    2way seas brp? trus kl 3way brp?
    seas nya beli kapan? yg pasif bawaan hebron bukan?
    thanks fyi..
    BASS MEKANIK Bandung
    2 Wks 4 Hrs 9 Mins 55 Secs
    Bdgnya dimana bos? Anne jg di bdg nih Pm nett cello nya + pin bb nya thx
    PM Sent to all....
    MG 10 SOLD.....
    sundul... naik dong.....
    naik dong biar keliatan heheheheheh.....
    naik....naik....ke atas......
    naek lagi ah....
Mega Glodok Kemayoran MBtech
  1. Replies: 9
    Last Post: 12th July 2010, 15:21
  2. Replies: 1
    Last Post: 5th April 2010, 10:54
  3. Replies: 1
    Last Post: 5th April 2010, 08:48
  4. Replies: 0
    Last Post: 5th April 2010, 03:18
