Permisi mau numpang jualan....
SEMUA BARANG SAYA BELI DARI BARU, DAN BELUM PERNAH RUSAK ATAU DI SERVIS APALAGI DIBONGKAR.....
Barangnya Berupa :
Spoiler for AUDISON SRX4: Show
Spoiler for waktu masih menempel di mobil: Show
Spoiler for kondisi sekarang saat akan di upload: Show
Spoiler for SAAT FOTO BERSAMA: Show
Spoiler for FEATURES: Show
Front/rear or front/sub amplifier with built-in crossover. Front channels filter can be hi-pass or full range, rear channels one can be hi-pass, lo-pass or full range. SRx 4 can be used as a 4/3/2 channel amplifier. When you choose 2 channel configuration (left/right), you can use hi-pass, lo-pass or full range functioning. There are 'speakers-in' front/rear inputs and a bypass output.
* RMS Outputs:
o 4 x 60 Watt at 4-ohms
o 4 x 85 Watt at 2-ohms
o 2 x 60 + 1 x 190 Watt at 4-ohms
o 2 x 85 + 1 x 170 Watt at 2/4 ohms
o 2 x 170 Watt at 4-ohms
* Bridgeable 4 / 3 / 2 Channel Output
* 2 Ohm Stable
* High Level Speaker Input
* Built in Cooling Fan
* High Pass Crossover
* Low Pass Crossover
* RCA Input
SRX-4 - Audison SRX4 4 Ch Amplifier
Spoiler for KONDISI DAN HARGANYA: Show
[Masih berjalan normal
kondisi fisik 90%
kondisi kinerja 100% tidak bermasalah
masih ada dus, buku, obeng bawaannya.
HARGA RP 2.500.000,- Neti
Spoiler for PUNCH P3001: Show
Spoiler for SAAT AKAN DI UPLOAD: Show
Spoiler for MAU MASUK KANDANG: Show
Spoiler for BOX: Show
Spoiler for SPESIFICATION: Show
[Number of Channels 1
Rated Power
(RMS Continuous Power) 150 Watts x 1 @ 4-Ohms
300 Watts x 1 @ 2-Ohms
Total Power
(Sum of Rated Power) 300 Watts
Bridgeable No
Crossover Controls High-Pass (HP): 40-400Hz 12dB/octave Butterworth
Low-Pass (LP): 40-400Hz 12dB/octave Butterworth
Tone Controls Bass: 0dB to +18dB @ 45Hz
Signal Input Low level: 1 RCA pair
Signal Output Low level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Punch Bass EQ (included with cable)
Visual Indicators Power On
Signal Level
Thermal Status
Speaker protection
Circuit Topology Class Class-bd
Frequency Response 20Hz to 20kHz +/- 0.5 dB
Shipping Weight 11.5 Lbs.
(5.2 Kg.)
Dimensions (HxWxL) 2.4 x 11 x 11.7 (in)
6.1 x 27.9 x 29.7 (cm)]
Spoiler for KONDISI DAN HARGA: Show
Kondisi fisik 85% ada baret di bagian chrome nya
kinerja 100% normal
bas knop masih baru dan masih segel gak pernah dipake
dus, buku manual ada semua
Harga 1,5jt neti
Spoiler for SPEAKER SEAS ORCHESTRA DAN CELLO MG10: Show
Spoiler for CELLO MG10: Show
KONDISI FISIK 90%
KINERJA 100% NORMAL BELUM PERNAH SEVIS
SPEAKER INI UKURAN 3' COCOK UNTUK MIDRANGE
HARGA 700RB]
Spoiler for SEAS ORCHESTRA: Show
Spoiler for TWEETER: Show
Spoiler for MID BASS: Show
MID BAS ADA PESOK DI BAGIAN TENGAHNYA TAPI GAK PENGARUH KE SUARA KOK
Spoiler for PASIVE X OVER BAWAAN SEAS: Show
PASIVE BGAK PERNAH DIPAKAI KARENA SY BUAT CUSTOM
Spoiler for BONUS: Show
KALAU BELI 3WAY SAYA BONUSIN CUSTO PASIF BY BOS HWELY BERIKUT KABEL KIMBER UNTUK TWEETER DAN MIDRANGENYA @SEKITAR 2M]
Spoiler for HARGA: Show
KALAU BELI 3 WAY 3JT
KALAU CUMAN SEASNYA DOANG 2,5JT
Spoiler for SUB P1: Show
KONDISI FISIK 85%
FUNGSI MASIH NORMAL
HARGA 750K
Spoiler for CAP. BANK MAS ENGINERING 2F: Show
MASIH BERFUNGSI SEMESTINYA.
HARGA 750K
Spoiler for KABEL-KABEL, DISTRIBUTION BLOCK, RCA PHOENIX GOLD: Show
SEMUA KABEL YG SAYA PAKAI LUMAYAN SEMUA.
HARGA 750K
BUAT YG MINAT HUB 081 394 9999 78
PIN BB by request buat yg serius.
BARANG ADA DI BANDUNG.
THANKS
