Hi-end AVI SL-300, 300 mm (12") SUBWOOFER DRIVER...........
Results 1 to 1 of 1
  • Short URL:  http://modifika.si/236942
    Cool Hi-end AVI SL-300, 300 mm (12") SUBWOOFER DRIVER...........
    Hi-end AVI SL-300, 300 mm (12") SUBWOOFER DRIVER..................
    APPLICATIONS This is a subwoofer driver for high performance sound systems.
    Suggested operating range is 27 to 400 Hz.
    PERFORMANCE 21 to 1080 Hz at -10 dB points, in optimum enclosure.
    27 to 400 Hz at -3 dB points, in optimum enclosure.
    500 watts music program material.
    250 watts AES pink noise rating.
    128 dB typical, in vehicle, with rated power.
    102 dB typical, at 1 watt, in vehicle.
    93 dB average, at 1 watt and 1 meter, in half space.
    4 ohm nominal, 3.2 ohm minimum.
    FEATURES Cast aluminum frame with cavity vents, black finish.
    Extended and vented pole piece with integrated bottom plate.
    Both top and bottom plates with CNC and black absorbing finish.
    Yellow HX type woven fiberglass cone with linearity damped composite rubber edge.
    Heavy duty gold plated brass terminals.
    1995 g (70.3 oz) magnet.
    65 mm (2.5") copper ribbon voice coil, OFC edge wound.
    PHYSICAL 312 mm (12.3") overall diameter.
    138 mm (5.4") overall depth.
    272 mm (10.7") cut out hole diameter.
    125 mm (4.9") mounting depth.
    6.5 Kg (14.3 lbs) weight.
    cal
    081282357888
  2. 13th January 2011, 10:29
    Reason
    SPAM
NGK Busi Tekiro
  1. WTS: Dynaudio driver 15W75 dan subwoofer 30W100XL
    By xraydriver in forum Speaker - SubWoofer
    Last Post: 28th November 2012, 17:07
  2. Round Audio Subwoofer Driver
    By Ninafeng in forum Speaker - SubWoofer
    Last Post: 15th June 2012, 10:38
  3. Replies: 69
    Last Post: 7th September 2011, 23:18
