[FS] Mirror Switch & Relay OEM Honda
Results 1 to 7 of 7
  • Short URL:  http://modifika.si/235269
    Cempaka Putih
    4 Days 2 Hrs 24 Mins 36 Secs
    Mirror switch & relay OEM Honda
    500rb
    cempaka putih
    -baskara-
    0818263600
    081227263600
    Cempaka Putih
    nemu di inet......
    I started with the Left Mirror hooking up the wires. You have to cut the factory connector off and splice up or solder in the JDM connectors. You must also do the same for the pass side and the OEM Mirror Switch
    'A' WHT/Silver dots to 'B' WHT/Silver dots on Right side mirror and BLU/RED on the Relay (5)
    'B' BLK to 'A' BLK on Right side mirror and BLU on the Relay (1)
    'C' YEL/BLK to YEL/BLK On the factory harness you cut
    'D' YEL/RED to YEL/RED
    'E' YEL/WHT to YEL/WHT
    Relay connections
    (2) WHT/BLU to 12V
    (3) BLU/YEL to BLU/YEL on the Switch (A)
    (4) BLK to Ground
    JDM Switch
    You have to cut the factory connector off and splice up or solder in the JDM connector.
    (3) BLU/BLK to BLU/BLK on the cut factory harness
    (4) YEL/BLK to YEL/BLK
    (5) YEL/WHT to YEL/WHT
    (6) BLU/GRN to BLU/WHT
    (7) YEL/RED to YEL/RED
    (9) BLK/YEL to BLK/YEL
    (10) BLK to BLK
    Right Mirror
    'A' should already be connected to 1 on the relay and B on the driver's mirror
    'B' should already be connected to 5 on the relay and A on the driver's mirror
    'C' BLU/BLK to BLU/BLK on the cut factory harness
    'D' BLU/GRN to BLU/GRN
    Then you just have to neaten up the wires with zipties, secure the Relay, reconnect the door jam connectors and reinstall the doorpanels
    Cempaka Putih
    bump...bump..
    082141213500 www.professional-motorsports.com / www.stabilisermobil.com
    5 Mths 6 Days 21 Hrs 26 Mins 13 Secs
    wuih barang mantap nih.. cocok untuk yang mau rectracable mirror... up...up...up...
    Cempaka Putih
    Quote Originally Posted by GD1 View Post
    thx bro....cek kulkas
    Cempaka Putih
    ayoooo.......ayooooooooo..........
    Cempaka Putih
    naekin lagiii.......
  1. [FS] Switch + Relay OEM Honda used..
    By memok in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 14th June 2011, 12:29
  2. Replies: 3
    Last Post: 31st January 2011, 13:57
  3. WTS : Suis & Relay retrac side mirror eg6/eg9 dan ek
    By removeauto in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 17th January 2011, 00:01
  4. [WTS]..Mirror switch corolla..
    By twincamers in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 21st October 2010, 06:46
  5. SOLD: SPION RETRAC FERIO JDM komplit switch relay
    By Japanese STOCKER in forum Bursa Eksterior Lainnya
    Last Post: 20th April 2010, 17:25
