***WTS POWER PHASS***
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/234485
    BOGOR/JABAR
    1 Mth 1 Wk 1 Day 19 Hrs 8 Mins 31 Secs
    PHASS RE 50 sold out
    SPEC RE 50 Stereo amplifier :
    Out power:50W x 2 (1KHz / 10ohms)
    Input sensitivity:0.22V
    Input impedance:10K ohms
    Load Impedance:4-8-16 ohms
    Idling Current:
    Idling time (On, No signal) 3A
    Waiting time (Remote Off) 2mA
    W280 x H74 x D329mm (without terminals)
    Not only RE 2 & 20 but also RE 50 is the unique amplifier which functions as the constant current driving amplifier. RE 50 uses Mos-Fets instead of semiconductors used in the circuit of RE 2 & 20 in the standard type power supply stage, which draws a clear line between this type and S.E.P.P circuit layout amplifiers that are mainstream today.
    RE 50 has a exceptional ability to continue to put the power into speakers under the difficult situation that the speaker impedance is increasing. While S.E.P.P. amplifiers can not put the power constantly to speakers.
    RE 50 simply shows its extraordinary musicality and surprising differences on the combination of the difficult load speakers.
    GAMBARNYA GAN :
    http://www.modifikasi.com/pb/s-i1238/f-albums/ff494/Acepaden/100_4501.jpg
    http://www.modifikasi.com/pb/s-i1238/f-albums/ff494/Acepaden/100_4502.jpg
    http://www.modifikasi.com/pb/s-i1238/f-albums/ff494/Acepaden/100_4504.jpg
    http://www.modifikasi.com/pb/s-i1238/f-albums/ff494/Acepaden/100_4505.jpg
    2 BUAH PHASS HP 100 PREMIUM
    Performance-driven high-end SQ amplifiers featuring the finest in solid-state amplifier design. Sleek and sophisticated appearance that offers more power for performance-based sound quality application with a distinctive clear and musical sound quality. The HP series offers elegant design and high power, all in a small and compact package for ultimate ease of installation. Using only the best quality parts, these amplifiers are assembled by hand by skilled technicians.
    SPEC HP100AMPLIFIER :
    Rated Power: 2x100 W /4ohms@12.5 V 0.05%THD
    Idling Current: 1.1A
    Fuse: 90A
    S/N Ratio: >100 DB
    Distortion: 0.05%
    Damping Factor: >200
    Input Impedance: >10Kohms
    Input Sensitivity: 0.2-4.0 V RMS
    Frequency Response: 10-80,000 Hz
    Load Impedance: 1ohm, 2ohm, 4ohm, 8ohm
    Dimensions: W390mm*H63mm*D233mm
    Low-Pass Filter: 50-125Hz
    Subsonic Filter: 20H
    INI GAMBARNYA GAN :
    http://www.modifikasi.com/pb/s-i1238/f-albums/ff494/Acepaden/100_4519.jpg
    http://www.modifikasi.com/pb/s-i1238/f-albums/ff494/Acepaden/100_4522.jpg
    http://www.modifikasi.com/pb/s-i1238/f-albums/ff494/Acepaden/100_4523.jpg
    http://www.modifikasi.com/pb/s-i1238/f-albums/ff494/Acepaden/100_4524.jpg
    JAKARTA
    1 Mth 3 Wks 3 Days 15 Hrs 49 Mins 9 Secs
    PERTAMAAAAXXXX.......Mantapppp bro!!!
    BOGOR/JABAR
    thx bro uda mampir ke lapak ane
    up..............................................
    mantab nie lapak suhu untap... ngk ade duanye
    bantu up..up..up................
    BOGOR/JABAR
    sold..................................
    thx modcom
GT Radial NGK Busi
  1. WTS: Power Musee. Phass, Spkr Fabolous, Phass Alinco
    By riandya in forum Power Amplifier
    Last Post: 26th September 2012, 23:49
  2. Replies: 4
    Last Post: 28th August 2012, 16:48
  3. Replies: 8
    Last Post: 6th December 2011, 00:12
  4. wts: speaker Phass + power Phass
    By aim189 in forum Speaker - SubWoofer
    Last Post: 30th June 2011, 21:33
  5. Replies: 344
    Last Post: 13th December 2010, 19:47
