Eton Symphony 4-200
Results 1 to 10 of 11
  • Short URL:  http://modifika.si/233868
    the city of presidents
    1 Wk 1 Day 16 Hrs 53 Mins 10 Secs
    Eton Symphony 4-200
    Ada yang pernah coba ngga ya speaker ini,
    kalau dilihat dari built quality sih sangat bagus
    tapi suara siapa yang tahu
    another sexy picture
    Eton 4-200/A8 Symphony, 4" Mid/Bass with Aluminum Former
    4” 3-layer Hexacone sandwich diaphragm mid/bass, rigid and stiff
    Excellent as midrange in multiple-way system or small 2-way
    Smooth and extended response curve
    Aluminum former
    Frequency 90Hz-6kHz
    Flange 116mm
    Cut-out 96mm
    Depth 62mm
    Products Specifications
    Znom 8 ohm
    Re 6.0 ohm
    Le@1kHz 0.42 mH
    fs 78 Hz
    Qms 2.35
    Qes 0.51
    Qts 0.42
    Mmd 6.26 g
    Cms 0.47 mm/N
    Sd 55 cm2
    BL 6.47 N/A
    Vas 2.0 ltrs
    Xmax 2 mm peak
    VC 25 mm
    Sensitivity 1W/1m 88 dB
    Nom. Power DIN 50 W
    Net weight 1.1 kg
    5 Days 8 Hrs 47 Mins 5 Secs
    mo di jadiin midrange?
    specnya sih yahud...di boxin gede cut di 150 buat midrange keknya bagus tuh...bs2 ga perlu midbass kalo pake sub suara bersih kek ss atau mp
    Quote Originally Posted by frostbitez View Post
    betul sekali bro frost, mo jadiin midrange
    di sini ada distributor nya ngga ya?
    TANGERANG
    5 Days 5 Hrs 59 Mins 19 Secs
    Bagus boss sy pernah denger eton 4" hexacone dijadiin midrange suara tebal mantaps !penampakan yg kayak gini ?
    3 Wks 22 Hrs 29 Mins 43 Secs
    ugh.. speaker mantapss...
    ngeces mode = ON
    Harga cukup resonable
    made in Germany berharga 2.5 jeti blom ongkir
    bandunk
    20 Hrs 16 Mins 30 Secs
    4" ato 5" neh om?
  1. wts: power symphony
    By leon9 in forum Power Amplifier
    Last Post: 15th October 2011, 01:20
  2. Replies: 31
    Last Post: 5th February 2010, 06:09
  3. SALE: Eton Discovery & Eton Adventure
    By ace911 in forum Speaker - SubWoofer
    Last Post: 25th December 2009, 08:40
  4. FS quantum symphony
    By nney in forum Bursa Audio Lainnya
    Last Post: 27th July 2009, 23:23
  5. Ask: Power Symphony
    By d_calvin in forum Diskusi Power Amplifier
    Last Post: 19th September 2006, 12:28
