[WTS] Ducati Monster 695
  • Short URL:  http://modifika.si/233453
    10 Hrs 4 Mins 46 Secs
    CLOSED DULU DAH.
    Engine
    Type L twin cylinder, 2 valve per cylinder Desmodromic, air cooled
    Displacement 695 cc
    Bore x Stroke 88 x 57.2 mm
    Compression Ratio 10.5:1
    Power 53.7 kW - 73 HP @ 8500 rpm
    Torque 61 Nm - 6,2 Kgm @ 6750 rpm
    Fuel injection Marelli electronic fuel injection, 45 mm throttle body
    Exhaust 2 aluminum mufflers
    Emissions Euro 3
    Transmission
    Type 6-speed Gearbox
    Ratio 1st 32/13, 2nd 30/18, 3rd 28/21, 4th 26/23, 5th 22/22, 6th 24/26
    Primary drive Straight cut gears; Ratio 1.85
    Final drive Chain; Front sprocket 15; Rear sprocket 42
    Clutch APTC wet multiplate with hydraulic control
    Chassis
    Frame Tubular steel trellis frame
    Wheelbase 1440 mm / 56.7 in
    Rake 24
    Front suspension Marzocchi 43 mm upside-down fork
    Front wheel travel 130 mm / 5.1 in
    Front wheel 3-spoke light alloy 3.50 x 17
    Front tire 120/60 ZR 17
    Rear suspension Progressive linkage with preload and rebound Sachs adjustable monoshock
    Rear wheel travel 148 mm / 5.8 in
    Rear wheel 3-spoke light alloy 4.50 x 17
    Rear tire 160/60 ZR 17
    Front brake 2 x 300 mm discs, 2-piston caliper
    Rear brake 245 mm disc, 2-piston caliper
    Fuel tank capacity 14 L (of which 3 L reserve) / 3.6 US gal (of which 0.8 US gal reserve)
    * Dry weight 168 Kg / 370 lbs
    Seat height 770 mm / 30.3 in
    Max height 1212 mm / 47.2 in
    Max length 2100 mm / 82.7 in
    Instruments Electronic panel: speedometer, rev counter, warning light for low oil pressure, indicators for high beam, fuel reserve, turn signals, LCD clock, immobilizer
  2. Hokinusa
    padang >< pekanbaru><medan
    1 Day 6 Hrs 20 Mins 25 Secs
    pm nett boss.tq
    -JKT-
    13 Hrs 54 Mins 41 Secs
    saya mau juga donk di PM'in super nettnya..
    thx.
    The man who removes mountain started by removes a stone...
