K SPORT Big Brake Kit
Page 1 of 15 12345 ... LastLast
Results 1 to 10 of 150
  • Short URL:  http://modifika.si/23340
    K SPORT BIG BRAKE KIT
    WEBSITE:
    http://www.ksportusa.com
    http://www.ksport.co.uk
    KEY FEATURES:
    1. Aluminum Piston Calipers
    2. D.O.T. Compliant Stainless Steel Brake Lines
    3. Machined Aluminum Hats
    4. Carbon Steel Brackets
    5. Large Ventilated Discs
    6. High Quality K SPORT Brake Pads
    FRONT Big Brake Kit Availability:
    6 Pot Piston Calipers With 286mm Disc Rotor Diameter (Minimum Velg R15in)
    6 Pot Piston Calipers With 304mm Disc Rotor Diameter (Minimum Velg R16in)
    6 Pot Piston Calipers With 330mm Disc Rotor Diameter (Minimum Velg R17in)
    8 Pot Piston Calipers With 330mm Disc Rotor Diameter (minimum Velg R17in)
    8 Pot Piston Calipers With 358mm Disc Rotor Diameter (minimum Velg R18in)
    12 Pot Piston Calipers With 380mm Disc Rotor Diameter (minimum Velg R19in)
    12 Pot Piston Calipers With 400mm Disc Rotor Diameter (minimum Velg R20in)
    Big Brake Kit Package:
    - Caliper Piston 4 Pot to 12 Pot
    - Disc Rotor Diameter 286mm to 400mm (Min. Velg 15in to 20in)
    - PCD Rotor Compatible with OEM Rotor
    - Bracket Caliper
    - Brake Line
    - Brake Pads
    NOTE:
    1. Masing-masing item dalam 1 kit sepasang untuk depan
    2. Plug & Play instalation
    3. Kebanyakan mobil tidak memerlukan modifikasi apapun pada Brake Kit ataupun pada kendaraan
    REAR Big Brake Kit Availability:
    4 Pot Piston Calipers With 286mm Disc Rotor Diameter (Minimum Velg R15in)
    4 Pot Piston Calipers With 304mm Disc Rotor Diameter (Minimum Velg R16in)
    6 Pot Piston Calipers With 358mm Disc Rotor Diameter (minimum Velg R18in)
    8 Pot Piston Calipers With 380mm Disc Rotor Diameter (minimum Velg R19in)
    8 Pot Piston Calipers With 400mm Disc Rotor Diameter (minimum Velg R20in)
    - Caliper Piston 4 Pot to 8 Pot
    - Bracket Caliper
    - Brake Line
    - Brake Pads
    NOTE:
    1. Masing-masing item dalam 1 kit sepasang untuk belakang
    3. Tidak perlu ubahan apapun pada Brake Kit ataupun pada kendaraan
    DESKRIPSI
    Ksport big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
    Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
    Most applications utilize the 2-piece floating disc assembly, which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance.
    HARGA MULAI DARI 13,500,000 rp.- dst
    awaiting orders from you guys..
    up
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    13 Mins 36 Secs
    kalo buat fd1 ada gak, hrgnya brp? thx
    Quote Originally Posted by vi View Post
    Cek PM Bos. Tq
    CP : Coki Siboro
    Quote Originally Posted by Cristopher View Post
    yang paling murah BWat yaris brapa bro harganya?
    Brake Kit KSPORT yg paling murah untuk depan paling pake yg 4 Pot. Item dalam kitnya Califer 4 Pot, Disc Rotor 320mm, Brake Pad, Brake Line dan Bracket yang kesemua itemnya sepasang untuk depan.
    Order antara 7-10 hari. Thx
    CP : Coki Siboro
    Jakarta, Indonesia
    5 Days 6 Hrs 28 Mins 27 Secs
    Boss,
    kalo buat swift brapa harganya?
    Thx
    Quote Originally Posted by D.T. View Post
    Boss,
    Thx
    Brake Kit KSPORT yg paling murah untuk depan paling pake yg 4 Pot. Item barang dalam kitnya Califer 4 Pot, Disc Rotor 320mm, Brake Pad, Brake Line dan Bracket yang kesemua itemnya sepasang untuk depan.
    Thx
    CP : Coki Siboro
    didalam mobilQu tercinta..
    3 Days 7 Hrs 44 Mins 50 Secs
    Om,kalo buat familia brapa om?!?
    trus kalo misalnya mau ganti matahari yg cocok pake apa ya?!?keras dikit ga masalah..
    1 Min 25 Secs
    Manteeeeeebbbbbb...
    Gue nungguin yang ini jadi murah aja deh Cok... hueheheheheheh
    Bantu up lagi dulu deh yaaaa....
    Quote Originally Posted by paculbo View Post
    matahari apaan nih? maksudnya kopling apa brake kit?
    kalo kopling bisa coba pake exedy plat dan dekrup. gak bisa beli dekrupnya aja, harus 1 set bos.
    CP : Coki Siboro
Wuling GT Radial
  1. FS : SMART FORTWO BIG BRAKE KIT K-SPORT GERMANY
    By SSCAR in forum Bursa Kaki Lainnya
    Last Post: 22nd July 2012, 16:04
  2. =Turbo Timer,Brake,Jok,Stir,Tacho,Indiglo,Lugnut,Sport Cap,Emblem,Racing Accs=
    By Saga Speed in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 3rd March 2011, 23:17
  3. Replies: 1
    Last Post: 5th February 2011, 17:05
  4. Replies: 64
    Last Post: 20th March 2009, 11:43
  5. BMW sport brake pedalnya ni...
    By hadis in forum Bursa Kaki Lainnya
    Last Post: 24th January 2008, 09:33
