PHASS HP-100 PREMIUM SERIES AMPLIFIER.........5,5jt
Results 1 to 9 of 9
  • Short URL:  http://modifika.si/231913
    Exclamation PHASS HP-100 PREMIUM SERIES AMPLIFIER.........5,5jt
    Performance-driven high-end SQ amplifiers featuring the finest in solid-state amplifier design. Sleek and sophisticated appearance that offers more power for performance-based sound quality application with a distinctive clear and musical sound quality. The HP series offers elegant design and high power, all in a small and compact package for ultimate ease of installation. Using only the best quality parts, these amplifiers are assembled by hand by skilled technicians.
    Rated Power: 2x100 W /4ohms@12.5 V 0.05%THD
    Idling Current: 1.1A
    Fuse: 90A
    S/N Ratio: >100 DB
    Distortion: 0.05%
    Damping Factor: >200
    Input Impedance: >10Kohms
    Input Sensitivity: 0.2-4.0 V RMS
    Frequency Response: 10-80,000 Hz
    Load Impedance: 1ohm, 2ohm, 4ohm, 8ohm
    Dimensions: W390mm*H63mm*D233mm
    Low-Pass Filter: 50-125Hz
    Subsonic Filter: 20Hz
    Profile
    *Circuitry; Capable Mosfets for switching power supply, high efficiency audio stages use fully complementary mirror image transistor.
    *Pulse width modulated power supply
    *Excellent audio stage design.
    *Reliable control pots.
    *Fully protection circuit.
    *Bridgeable power out put.
    *Variable low pass filter: 50 - 125 Hz
    *Subsonic filter
    *Phase switch
    *Bass booster
    *High class Toroid core to ensure high efficiency and minimize interference.
    *High class capacitors
    This bridgeable 2 channel power amplifier based on the AP series adopts double power supply, has more powerful outputs, and 1 ohm stable drive.
    A variable low pass filter with a phase switch for subwoofer and a subsonic filter for front speaker system are also equipped.
    This new model of the previous HP100 has been redesigned to offer better performance as well as a sleek and elegant appearance.
    call
    081282357888
    klaten
    ngileerr dulu boss...
    hehehe,bisa aja nich bos danny,saya juga ikutan ngiler dech bos danny,soalnya masih ini masih punya temen nitipjadi kita ngiler bareng2 dech bos dany,hahaha....
    thanks yach bos danny.....
    1 Wk 2 Days 6 Hrs 27 Mins 49 Secs
    Bantu upp ya ko chris
    thanks yach dhan...........
    3 Wks 1 Day 9 Hrs 16 Mins 55 Secs
    UP UP UP
    thanks yach bos andry............
    angkatttt terussss......
    UP UP UP.....
GT Radial Venom 300x250
  1. Replies: 10
    Last Post: 6th December 2011, 00:07
  2. WTS : Phass HP 100 Premium
    By jazzanatic in forum Power Amplifier
    Last Post: 2nd August 2011, 02:02
  3. WTS: Jual amplifier PHASS HP100 PREMIUM
    By jindraya in forum Power Amplifier
    Last Post: 25th March 2011, 15:03
