FS: Advan Neova Ad07 195/55/15 kondisi 90% ke atas (2 pc)
Results 1 to 10 of 25
  • Short URL:  http://modifika.si/230989
    Move to Solo
    1 Day 10 Hrs 1 Min 34 Secs
    SOLD SOLD SOLD
    Move to Solo
    The ADVAN Neova AD07 is the Extreme Performance Summer tire member of Yokohama's global family of ADVAN performance tires developed for sports car, sports coupe and performance sedan enthusiasts who love sport driving. Used as Original Equipment (O.E.) on the Lotus Elise, the ADVAN Neova AD07 is designed to provide high levels of traction, responsive handling and driving control in dry and wet road conditions. The ADVAN Neova AD07 is not intended to be driven in near-freezing temperatures, through snow or on ice.
    The ADVAN Neova AD07 molds a "fine particle" Micro Silica (MS) tread compound (to provide greater road surface adhesion) into a directional tread pattern that features massive tread blocks with rounded edges to increase cornering stability and steering response while promoting more even wear. Five large circumferential and multiple directionally aligned lateral grooves resist hydroplaning and enhance wet traction. The tire's structure includes two wide steel belts reinforced by spirally wound nylon to provide strength and uniform ride quality and high-speed capability while the sidewalls are tuned to resist lateral deflection providing handling control and cornering stability.
    Like the motorsports tires this Extreme Performance street tire has evolved from, the ADVAN Neova AD07 radial's construction and compounds have been tuned to maximize the tire's traction and performance within a specific range of ambient temperatures. Therefore, unlike less highly-tuned tires, Yokohama's care instructions specify that due to its compound characteristics, ADVAN Neova tires must be used and stored at temperatures above -10 degrees Celsius (14 degrees Fahrenheit) to maintain its performance and avoid tire damage.
    Move to Solo
    Bump bump bump
    Move to Solo
    Upppppp..
    Move to Solo
    Made in japan
    Move to Solo
    Mint condition
    Jakarta dulu aja deh
    Wuih galak amat jualannya bro. Wkwkwkwkwk
    Kenapa dijual cuman 2pcs bro? Hehehehehehe.......
    Msh inget gw ga bro?
    Move to Solo
    Hahahahaha, ngga galak kok tp mls buang waktu aja.. Masa sm dedengkot ngga inget?hehehe.. Iya cuma 2 nih, soalnya yg spasang lg beda merk (toyo r1r) dan udah tipis,hehehe..
    Hahahahahha. Yg dedengkot kan lu bro.
    Ane mah masih baru gan.
    Jazz nya makin keren aja nih. Join ke jfc dunks bro
    Move to Solo
    JFC? Minder bro kalo join disana.. Hehehe.. Lagipula kan jazz item gw udah laku lama, hehehe..
  1. Replies: 3
    Last Post: 25th January 2013, 01:21
  2. Replies: 23
    Last Post: 11th March 2012, 21:11
  3. Replies: 10
    Last Post: 25th February 2010, 09:44
  4. Replies: 17
    Last Post: 19th June 2009, 16:32
  5. FS> 4pcs Advan Neova AD07 195/50R15 kondisi 99,8% display doank
    By tz-klpgdg in forum Bursa Kaki Lainnya
    Last Post: 31st May 2009, 17:11
