Ada yg pernah pake dan tau kualitas submoofer ini --> Peerless 830876 10" XXLS Subwoofer 4 Ohm? Kalo dibandingkan dengan Vifa MA26 kira2 bagus mana yah?
Please share ya bro/mas/gan...
Ini description-nya (gw ambil dari sebuah website):
Peerless 830876 10" XXLS Subwoofer 4 Ohm - Description
This series of state-of-the-art subwoofers continues to enhance Peerless's reputation for delivering the highest quality components for bass. Called the XXLS—for "Xpanded Extra Long Stroke"—these audio transducers add even more excursion to the Peerless XLS line while completely eliminating distortion. The XXLS 10" driver features a strong yet attractive cast frame, reinforced paper cone, flat spider, and generous under-spider venting. The magnet system incorporates multiple distortion-canceling fixtures. Buyout, limited quantities. Specifications: *Power handling: 175 watts RMS/350 watts max *VCdia: 2" *Le: 1.5 mH *Impedance: 4 ohms *Re: 1.7 ohms *Frequency response: 39-2,000 Hz *Fs: 39 Hz *SPL: 92 dB 2.83V/1m *Vas: 0.83 cu. ft. *Qms: 6.79 *Qes: 0.47 *Qts: 0.44 *Xmax: 12.5 mm *Dimensions: A: 10-5/8", B: 9-3/8", C: 6".
* 12.5 mm of linear excursion
* Cast aluminum frame
* Flat spider and HD rubber half roll surround
* Massive stacked magnet with cosmetic boot
