::::::::::::::: AUDISON BIT ONE ::::::::::::::::
Page 1 of 5 12345 LastLast
Results 1 to 10 of 50
  • Short URL:  http://modifika.si/230565
    BAndunG
    1 Mth 1 Wk 3 Days 2 Hrs 2 Mins 38 Secs
    ::::::::::::::: AUDISON BIT ONE ::::::::::::::::SOLDDDDD
    For SAle ::
    Processor AUDISON BIT ONE
    MULUZZZZZ LENGKAP DUSSSSSS
    TECHNICAL SPECIFICATIONS
    Power supply
    Voltage 11 ÷ 15 VDC
    Idling current: 0.5 A
    Switched off <0.04 mA
    Remote IN voltage 7 ÷ 15 VDC (1 mA)
    Remote OUT voltage 12 VDC (5 mA)
    Distortion - THD @ 1 kHz, 1 V RMS Output 0.002 %
    Bandwidth 4 ÷ 22 kHz
    S/N ratio @ A weighted 102 dBA
    Channel Separation (1 kHz / 10 kHz) 75 dB / 60 dB
    Input sensitivity (Low Level Inputs) 0.13 ÷ 3.5 VRMS
    Input sensitivity (High Level Inputs) 1.2 ÷ 32 VRMS
    Max Output Levels 4.0 VRMS
    Input impedance (Low Level Inputs) 24 k
    Input impedance (High Level Inputs) 5 k
    Inputs Low level (Pre In): Ch1÷Ch6, AUX1 L & R, AUX2 L & R
    High Level (Spk IN): Ch1÷Ch8, Phone IN
    Electrical and Optical S/PDIF(Max 192 kHz/24 bit)
    Outputs Low level (Pre Amp Out): Ch1÷Ch8
    Digital Out: AD Link (Ch1÷Ch8 S/PDIF)
    Crossover Filter type 12 / 24 / 36 / 48 dB Linkwitz
    6 / 12 / 18 / 24 / 30 / 36 / 42 / 48 dB Butterworth
    Crossover Mode Hi Pass / Low Pass / Band Pass
    Equalizer Filter type 31 Band, ISO 1/3 Oct, 20 Hz÷20 kHz
    Equalizer Gain +/- 12 dB
    Delay 0÷22 ms (748 cm / 294.5 inch)
    Size: B (Base) x L (Lenght) x H (Height) mm/inch 225 x 150 x 32.3 / 8.85” x 5.90” x 1.27”
    Weight kg/lb 1.345 / 2.965
    SOLDDDDDDDDDDDDDD
    WhatsApp *0855 21888 18*
  2. SbcAgent
    BAndunG
    Up................................
    BAndunG
    angkattttttt..............................
    57 Mins 14 Secs
    Bantu Up deh ...
    BAndunG
    up.....................................
    the city of presidents
    1 Wk 1 Day 16 Hrs 53 Mins 10 Secs
    ini yang generasi ke berapa Bang-T
    BAndunG
    Quote Originally Posted by Leogun View Post
    yang baru , bit one . 1 bosss.......................
    Bintaro Sonoan Dikit
    5 Days 5 Hrs 56 Mins 34 Secs
    Bantu up lagi sekalian nabung
    BAndunG
    Quote Originally Posted by AReM View Post
    TQ Bossssssss........................
    bandunk
    20 Hrs 16 Mins 30 Secs
    sadis uyyy barang2nya
    bantu up bossssssss
  1. ******jual satu pasang Audison VR 209 sama Audison VR 404 XR **********
    By audiocarsundajaya in forum Power Amplifier
    Last Post: 8th October 2012, 19:06
  2. Replies: 64
    Last Post: 9th June 2011, 23:07
  3. Replies: 0
    Last Post: 16th February 2011, 08:41
  4. Replies: 2
    Last Post: 14th February 2011, 22:37
  5. Replies: 21
    Last Post: 25th December 2009, 00:08
