MONSTERS FROM THE PAST !!!
Results 1 to 10 of 115
  • Short URL:  http://modifika.si/228588
    Exclamation MONSTERS FROM THE PAST !!!
    EARTHQUAKE PA-4300
    USAMPS VLX-400....sold
    USAMPS US-250A...sold
    ORION 2250SX
    ORION GS-500
    ORION GS-300
    ORION GS-100....sold
    ORION XTR-100
    ORION HCCA-425
    ORION HCCA-150R
    ORION 280GX
    LANZAR OPTI-2500
    LANZAR OPTI-4150.....sold
    ROCKFORD POWER MOSFET 1000.....sold
    PRECISION POWER 2350DM.....sold
    POWERAMPER XP2400.....sold
    AMA SYSTEM-550 (MARANTZ 750)
    LINEAR POWER 652
    LINEAR POWER 952....sold
    DR.CRANKENSTEIN ZR-400...SOLD
    Poweramper XP-2400 amp
    the XP-2400 should be a dB drag favorite as it puts out over 2400 watts RMS.
    wondered if anyone has heard /used this amp and what they thought ..
    -Power Supply management circuitry adjusts for high current and high voltage operation.
    -Stable into 2 ohms bridged or 1 ohms stereo loads.
    -Full symmetry dual differential high current design.
    -Variable speed fans for optimal cooling.
    -Balance dual differential input circuit.
    -18 dB per octave H/P & L/P crossover.
    -Audiophile grade WIMA caps and 1% metal film resistors.
    -Variable phase (0 ~ 180 degree) and Q, Bass (0 ~ + 18 dB) control.
    -100% QC testing and warm up.
    -Input Sensitivity: 0.2V ~ 5V.
    -S/N ratio: >110dB
    -T.H.D.: <0.02%
    -Bandwidth: 10Hz ~ 80KHz
    Specificaions for XP2400:
    -2 Channel power amplifier
    -2400 watts x 1 mono into 2 ohms
    -1600 watts x 1 mono into 4 ohms
    -1200 watts X 2 into 1 ohms
    -800 watts x 2 into 2 ohms
    -400 watts x 2 into 4 ohms
    -Dimensions: 9"W x 2.3"H x 27.5"L
    ORION 2250sx old school aka. the beast.
    the amp is in a presitine awesome condition i would have to rate it 9.5 or more, and works like no other. it would not be that easy to find another amp like this one in this presitine condition, looking to get 725 with out shipping or pp fees.. here are specs:
    Orion SX2250
    ← home
    A.K.A. "Beast"
    2 x 250W @ 4 ohms (12V)
    2 x 300W @ 4 ohms (14.4V)
    2 x 500W @ 2 ohms (12V)
    2 x 600W @ 2 ohms (14.4V)
    1 x 1000W @ 4 ohms bridged (12V)
    1 x 1200W @ 4 ohms bridged (14.4V)
    THD: 0.03%
    S/N Ratio: 110dB
    Freq. Response: 6Hz ∼ 20kHz (±0.5dB)
    Fuse: 100A
    Dimensions: 23" x 8.5" x 2.25" (58.4cm x 21.6cm x 5.7cm)
    Real world performance is about 1500W (thanks ampguts for the specs and seller who posted it)
    Here it is guys the monster Earthquake amp the PA-4300 Hohmann series.
    This amp does 4 x 300 at 4 ohms and 4 x 550 at 2 ohms.
    Will also run in mono 2 x 1150 at 4 ohms bridged / mono mode..
    It's houses 2 of the pa-2300's.
    THD: 0.015%
    S/N Ratio: 110dB
    Dimensions: 33" x 9" x 2.75" (83.8cm x 22.9cm x 7cm)
    Weight: 25 lb. (11.4 kg.)
    Great condition and the speaker plugs have nice long length still there.
    $900.00.
    This is a mid to late 80's fosgate power 1000 mosfet...
    this amp is an awesome 4 channel amp that does
    4 x 150W @ 4 ohms,
    4 x 250W @ 2 ohms,
    2 x 500W @ 4 ohms bridged
    and is Fused External 100A
    Precision Power 2350DM
    Output POwer at 12V
    2 x 350W @ 4 or 2 ohms (0.02% THD)
    1 x 700W @ 8 or 4 ohms bridged
    Fuse: External 60A
    CALL
    081282357888
    1 Wk 14 Hrs 4 Mins 39 Secs
    Ane pertamax bos..!!!
    Wooww barang2 ajib masih ada aja yah :eek::eek::eek::eek::eek:
    klaten
    gw keduaxx aja dah kalo gt... Emang muantapz kabeh barang2e bos Chris. Gawe ngiler tenan.. Xixixi
    1 Day 19 Hrs 55 Mins 52 Secs
    Ediannnnn....koleksinya ckckckckc. muantapppp bos chris!
    1 Day 3 Hrs 28 Mins 24 Secs
    ampun bos......serem
    thanks yach bos dewa,bos danny,bos agus n bos christy....
    4 Hrs 19 Mins 42 Secs
    Banyak amat monster serem seremnya ?
    bantu sundul untuk barang barang hebat
    Honoured Member
    Smile
    Yang Poweramper berapa nettnya Bro Chris?!
    hehehe,pas kebetulan aja ada barengan bos utomo,soalnya sering ada tapi si monster2nya ga pernah barengan,dateng n perginya masing2 biasanya bos,hehehe....
    pm sent bro wendo,thanks..
    3 Days 14 Hrs 19 Mins 1 Sec
    waduh..buat SPL semua ini yak???
MBtech Venom 300x250
  1. Replies: 16
    Last Post: 31st August 2013, 11:26
  2. CARTOON.COMMUNITY.JAKARTA.PAST AND PRESENT
    By ghulamhussen in forum Auto Club
    Last Post: 3rd December 2012, 14:16
  3. Kidoy 84 Blast From The Past Jogja
    By haloha in forum Toyota
    Last Post: 22nd April 2011, 08:39
  4. JDM... Redefition, a look into the past, present and future
    By sugarfree in forum Diskusi Otomotif Lain-Lainnya
    Last Post: 27th November 2006, 17:32
