K SPORT COILOVER KIT
Page 1 of 50 12345 ... LastLast
Results 1 to 10 of 491
  • Short URL:  http://modifika.si/22665
    Website:
    www.ksportusa.com
    Tentang Coilover Kit KSPORT:
    - 1 set 4 buah shock breaker depan & belakang + 4 buah per depan dan belakang
    - bisa adjust/setting tinggi & rendah (manual dengan kunci khusus)
    - bisa adjust/setting keras & empuk sebanyak 36 klik settingan (manual dengan alat khusus)
    - perlengkapan dalam 1 set termasuk 2 buah kunci untuk setting tinggi rendah dan 4 buah kunci untuk setting keras empuk)
    - materialnya terbuat dari bahan berkualitas alumunium 6061 dengan tingkat kekuatan alumunium T6
    - untuk beberapa tipe kendaraan akan dilengkapi dengan pillow ball uppermount untuk penyetelan sudut kemiringan/chamber roda
    Sedikit Lebih Jauh Tentang KSPORT:
    Ksports Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. Made from high quality 6061 Aluminum with T6 for increased hardness.
    Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
    Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
    The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavitations are a lot less common in a Monotube design, which results in a better ride.
    The Ksport control Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
    1. 36 levels of adjustable dampening
    2. Made from high quality 6061 aluminum with T6 for increased hardness
    3. Compression/Rebound adjustable
    4. Adjustable spring perch for height adjustment
    5. Adjustable body allowing maximum suspension travel
    6. Pillowball top mount with adjustable camber (not available for some models)
    7. Monotube high pressure design reduces oil leakage
    8. Electroplated body for protection from corrosion and rust
    9. One year limited warranty
    waiting orders from you guys..
  2. Giias 2018
    Jkt
    3 Mths 3 Wks 2 Days 6 Hrs 36 Mins 49 Secs
    boleh beli uppermountnya aja bos? :smt005
    Quote Originally Posted by std aja de
    sori, gak bisa bos.. Satu set aja bos. hehehe
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    Medan
    2 Days 3 Hrs 59 Mins 39 Secs
    bs buat mobil apa aja neh bos?
    Quote Originally Posted by sueryach
    Bisa di order untuk mobil apa aja bos.. Listing daftar mobilnya banyak banget..
    By order aja bos. Buat mobil apa ya?
    CP : Coki Siboro
    Medan
    kalo ferio kena berapa yah?
    Jkt
    Quote Originally Posted by coki.de auto
    kirain boleh bos :smt005
    klo boleh sekalian mau pesen rear swaybarnya cattman buat nissan a32 nih bos :smt005
    iya bos.. ribet kalo ambil upper mount aja.. hehehe
    CP : Coki Siboro
    Jkt
    kan ada di price listnya jg bos :smt005 nunggu kiriman lain jg gpp d, dp dl jg gpp :smt005
    oke deh.. nanti ada kiriman dikbrin deh bos..
    ngebet amat nih sama upper mount. hehehe
    CP : Coki Siboro
  1. FOR SALE COILOVER HKS V SPORT 2ND
    By Eby D in forum Per & Shockbreaker
    Last Post: 22nd September 2012, 19:40
  2. WTS : Coilover 2nd Suzuki Sport for Swift
    By B26_7DM in forum Per & Shockbreaker
    Last Post: 5th January 2011, 13:51
  3. [WTB]D2 Racing Sport Coilover RS D2-H119-1 for GE8
    By dianton in forum Bursa Kaki Lainnya
    Last Post: 28th April 2010, 13:49
  4. FS Used K sport coilover for 2007 + Golf Vw Mkv
    By EPwerkz in forum Per & Shockbreaker
    Last Post: 25th November 2009, 22:52
  5. For sale: USED K Sport Coilover for Vw GTI MKV
    By EPwerkz in forum Bursa Kaki Lainnya
    Last Post: 6th February 2009, 14:49
