Fostgate P400-4 for SQ
Results 1 to 7 of 7
  • Short URL:  http://modifika.si/226413
    2 Hrs 49 Mins 14 Secs
    mohon bantuannya
    mau pasang speaker infinity kappa
    spek:
    # 6-1/2" Kappa Series 2-way Component Speakers System
    # Power Handling:
    * Peak: 540 watts per set / 270 watts each side
    * RMS: 180 watts per set / 90 watts each side
    # Woven glass fiber cone woofer
    # Rubber surround
    # Edge driven UHF dome tweeter
    # Unipivot patented rotating tweeter allows tweeter to be directed at the listener's location
    # Direct connect computer-optimized, voice-matched outboard passive crossover for superb detail and accuracy
    # Tweeter level adjustment on passive crossover to add or subtract 3 dB output
    # 2 ohms impedance
    # Top-mount depth: 2-7/16"
    Dengan RF P400-4
    # 4-channel car amplifier
    # 50 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
    # 200 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
    # CEA-2006 compliant
    # Dynamic Thermal Management cooling system
    # Variable high- and low-pass filters (50-500 Hz, 12 dB/octave)
    # Variable bass/treble boost (0-18 dB at 45 Hz, 0-12 dB at 12,000 Hz)
    # Optional wired remote bass/treble boost
    # Class-AB amplifier design
    # MOSFET power and output stages
    # 4-gauge power and ground leads and an 80-amp fuse recommended — wiring and hardware not included with amplifier
    # No on-board fuses — when installing multiple amps in a system, an additional 80-amp in-line fuse between the distribution block and the amplifier is recommended
    Rencana Sub
    Rockford Fosgate p2-2ohm 400w + Alpine MRP M500 Amplifier
    HU:
    Alpine 9887 atau Kenwood 7016
    Kira2 amplifier P400-4 cocok g klo mau maen SQ.
    1 Wk 14 Hrs 4 Mins 39 Secs
    Quote Originally Posted by predz91 View Post
    mohon bantuannya
    spek:
    # Power Handling:
    # Rubber surround
    # 2 ohms impedance
    Dengan RF P400-4
    Rencana Sub
    HU:
    Setau ane klo yg namanya RF bukan power buat maen SQ..btw itu split infinity yg di tembak pake RF 4 chanel brarti maen full aktif yah..bole jg sih tp lebih bagus jgn pake RF..takutnya ga sesuai di kuping ente..mungkin bisa dicoba power merk audison or arc audio..dua2nya power class A
    08999942533, 02140389555; MGK Kemayoran Lantai 6 Blok E5 No. 2; Bursa Mobil Gading - Kelapa Gading
    1 Yr 9 Mths 3 Wks 6 Days 21 Hrs 51 Secs
    Rockford Fosgate aliran SPL bgt, 180 derajat bertolak blkg
    Pke sub JL W3 aj
    Quote Originally Posted by dewakeren View Post
    ARC Audio class A nya yg seri apa suhu? Wah... boleh juga nih.
    Mega Glodok Kemayoran Lantai 6 Blok D8 No.5 021-70050050
    7 Hrs 46 Mins 38 Secs
    p 400.4 bisa koq bro buat maen sq tapi bukan yang kelas audiophile sekali ya, saya sudah beberapa kali dengar settingan sq yang pakai p.400.4 lumayan bagus koq walau pun suaranya gak sebagus kalau mungkin pakai audison atau yang sekelasnya yah, dengan settingan yang tepat pasti bisa kok p 400.4 nya dapat hasil yang maksimal.
    Sidoarjo - Jogja
    3 Hrs 42 Mins 5 Secs
    Aq prnah denger, rf p400-4, enak kok dibuat SQ, suaranya lbh cruncy, bersih jg, menurut q...
    Tinggal settingannya jg sih...
    Kembali lagi ke selera,
    4 Days 9 Hrs 9 Mins 52 Secs
    ROCKFORD kalo mau di pake SQ cari yg tipe T / POWER suara bersih & betenaga tuh bos.......
    saya sendiri pake T600.4 buat midrange seas exsel 12m tw R 7000 midbas seas exsel 8inch power pake T600.2 suara bersih puuuueeeeenak tenan bos hehehe
GT Radial Venom 300x250
  1. JUAL POWER ROCKFORD FOSGATE P400.4 (4Chanel)), SUB P212S4
    By sauber88 in forum Power Amplifier
    Last Post: 30th July 2012, 18:02
  2. Replies: 6
    Last Post: 3rd May 2012, 13:13
  3. Replies: 4
    Last Post: 3rd May 2012, 13:11
  4. dijual power 4chanel rockford seri P400-4
    By diver in forum Power Amplifier
    Last Post: 30th April 2012, 09:37
