SEAS EXCEL W12CY-001 4.5" Magnesium Cone Woofer Rp.3.250.000/Pair #NEW#
  • Short URL:  http://modifika.si/226367
    INDONESIA
    1 Hr 12 Mins 41 Secs
    SEAS EXCEL W12CY-001 4.5" Magnesium Cone Woofer.
    The W12CY001 is a 12cm (4,5) cone driver developed for use as a high fidelity woofer/midrange unit. The extremely stiff, yet light cone gives tremendous bass precision and midrange detail.
    Precision cast and surface treated magnesium cone coupled to a natural rubber surround showing no sign of midrange (edge) resonances.
    Heavy copper rings mounted above and below the T-shaped pole piece reduce non linear and modulation distortion and increase overload margin.
    An extra large magnet system for good sensitivity and transient response. Copper plating of the top and bottom plates and a solid copper phase plug, which enhance the performance of the copper rings and improve heat conduction away from the pole piece.
    Extremely stiff and stable injection moulded metal basket keeps the critical components in perfect alignment.
    Large windows in the basket both above and below the spider reduce sound reflexion, air flow noise and cavity resonance to a minimum.
    Outside diameter 120.4mm
    Cut out 95.8mm
    Depth 58.5mm
    Harga : Rp.3.250.000/Pair
    Kondisi : 100% Baru
    Terimakasih.
    Regards,
    TokoSpeaker.com
    INDONESIA
    SEAS EXCEL W12CY-001 4.5" Magnesium Rp.3.250.000/Pair #NEW#
    Uploaded with ImageShack.us
Tekiro Mega Glodok Kemayoran
  1. Replies: 3
    Last Post: 16th November 2010, 01:32
  2. SEAS EXCEL MILLENIUM 4" midrange w12cy-001 (sold,thanks modcom....)
    Last Post: 14th February 2010, 07:41
  3. Seas Lotus RM 110 and Seas Excel W12CY 4,5"
    By julsjazz in forum Diskusi Speaker
    Last Post: 4th April 2007, 01:36
