Kabel2, RCA, Pasif, BOX sub dll MURAH
Results 1 to 10 of 40
  • Short URL:  http://modifika.si/226107
    5 Days 8 Hrs 47 Mins 5 Secs
    sementara info aja dulu yah keterangan sama barang2nya nanti sy update
    Foto semua
    KABEL2
    CHORD CARNIVAL SILVERSCREEN
    1. 2 Pair X 120CM BIWIRE (isi 4 kabel buat midrange+tweeter ke pasif)
    ukuran biwirenya lebih gede dari batere AA
    2. single 133 cm (isi 2 kabel buat dari Pasif pilar kiri ke ampli di bawah jok kiri)
    3. single 162 cm (isi 2 kabel buat dari Pasif pilar kanan ke ampli di bawah jok kiri)
    kondisi agak debu/ kotor blom di bersihin (sorry guys bersihin sendiri yah ga sempet)
    best speaker cable buat 2008,2009,2010..perlu review? ask uncle google
    buat price pasaran
    http://www.kaskus.us/showthread.php?t=1489319
    harga gua : takes all 450rb aja!
    MOGAMI
    brand ini dipake buat hampir semua studio recording di dunia...
    1. Kabel Speaker Mogami seri 3082 3 piece ukuran 300cm, 380cm, 200cm
    Specifications:
    * Conductoretails: 80/0.18 OFC (8033AWG)Size(mm): 2.03mm (Approx. #14AWG)
    * Insulation:Ov. Dia.(mm): 4.6 (0.181")Material: PVCColors: White
    * Served Shieldetails: 80/0.18 OFC (8033AWG)Size(mm): 2.03mm (Approx. #14AWG)
    * Jacket:Ov. Dia.(mm): 6.50.5 (0.2560.0197")Material: Flexible PVCColor: Black
    * Roll Size: 100m (328Ft) / 200m (656Ft) / 153m (500Ft)
    * Weight per 100m Roll: 7.5kg
    Electrical & Mechanical Characteristics:
    * DC Resistance at 20C: 0.009W/m(0.0027W/Ft) Same value for both internal and outernal/shield conductor)
    * Capacitance at 1kHz, 20C: 253pF/m(77pF/Ft)
    * Inductance: 0.4H/m(0.12H/Ft)
    * Electrostatic Noise: 0.2mV Max.
    * Electromagnetic Noise at 10kHz: 0.2mV Max.
    * Voltage Breakdown: Must withstand at DC 500V/15sec.
    * Insulation Resistance: 100000 MW m Min. at DC 500V, 20C
    * Flex Life: 15,000 cycles
    * Tensile Strength: More than 980N
    * Emigration: Non–emigrant to ABS resin
    * Applicable Temperature: -20C~ +70C(-4F~ +158F)
    * Standard: UL13 CL2 75C
    review coba di google aja
    Karakternya bener2 natural...hampir tidak ada karakter bawaan,
    mo dilepas 225rb aja!
    2.RCA MOGAMI 2534 quad wire/quad Neglex 4 m Pair kepala pake Monster cable, timah solder Audionote
    Salah satu kabel diy yang bener2 worth the money...review baca ndiri d
    http://www.mogamicable.com/category/bulk/microphone/quad/
    daleman rcanya kek gini twisted 2 pair + shielding lagi....rca normal cuma pair aja
    price list luar (per 30cm yah)
    http://www.studiowiring.com/interconnectcables.html
    mau dijual murah aja 275rb!
    MONSTER CABLE
    1. RCA Monster cable XLN 401 (4 channel x 4 mtr) NEW
    * Features QuadHelix construction for extra-low noise music reproduction.
    * Time Correct windings for accurate reproduction of music.
    * Patented 8-cut Turbine, 24k gold RCA connectors resist corrosion and will not vibrate loose over time.
    * XLN construction for rejection of loop area noise and inductive interference.
    * Connector housing is 1/3 the overall length of average RCA connectors for easy installation in tight places
    Boxnya ga ada soalna kalo pake box ongkirnya nambah 1 lb...jadi kena 3 lb
    ga jadi pake tdnya mo pindahin power di bagasi, oh ya bagasi inova dll cuma 3,5mtr aja sampe jadi bisa buat smua mobil sampe bagasi
    jamin asli 100% import sendiri...ini import gara2 liat harga di indo muahall banget 1,2jt++ buat yang 1 pair aja...coba aja check di plaza senayan, atau best denki
    (g abis 1jtan sama ongkir, bea dll) mau lepas 700rb aja!
    nyusul deh yang laen cape ngetiknya
    Mono cable cl2 12 awg
    1. 2 (sepasang)x 200 cm 12 awg
    ini reviewnya
    http://www.bestcovery.com/12awg-cl2-rated-2-conductor-loud-speaker-cable
    POWER
    1. STEQ K202
    review googling ndiri yah
    spec liat dimari
    http://www.steg-america.com/k202.html
    kondisi muluss normal...
    cuma baut buat speakernya pada ilang entah kemana...bs beli atau cari sendiri
    mau di lepas 3 jt aja
    2. Denon DCA 3500 power Class A 5 ch
    Spec : 4 x 40 watt RMS @ 4 ohm + 1 x 160 Watt RMS @ 2 ohm
    Karakter suaranya mirip dengan Power Nakamichi kalem en flat
    [IMG]http://i47.tinypic.com/2dw98bd.jpg[/IMG]
    jual 1 jt ajah
    PASIF
    1. Pasif HI END,
    http://www.modifikasi.com/showthread.php?p=7767648#post7767648
    BOX SUB 12"
    box sub 1cufeet lebih dikit...buat 12"
    udah full treatment busa telor, buatan revealing audio
    kotor dikit tinggal di vaccum ajah
    jual 150rb aja!net
    balik jakarta awal des
    klaten
    bantu up om Han...
    1 Wk 2 Days 6 Hrs 27 Mins 49 Secs
    Kabel2 murahnya berapa bos hehehe
    uppp dulu ada update page 1
    @atas tar malem g pm yah
    Update lg g out of town sampe awal des
    North sumatera,medan
    1 Mth 1 Wk 4 Days 6 Hrs 41 Mins 8 Secs
    Bos,mogami harga ke 3 pcs nya ya,sms ke 081360542322,thx
    JAKARTA
    1 Day 23 Hrs 52 Mins 54 Secs
    bos boxnya brp nett??lokasi dmn??
    kan dah ditulis sibos...150rb net, ga bagus jangan dibayar
    di green garden bos
    JAKARTA
    green garden sebelah mana bos?itu bekas pake brp in sub?ane 12 in masuk gak tapi lubangnya kelihatan lebar depannya boss.
    uppppppppp lagi ayo jgn malu2
  1. Jual bass tube + power + kabel2 murah
    By nandamarcell in forum Power Amplifier
    Last Post: 14th September 2012, 22:40
  2. Replies: 10
    Last Post: 19th April 2012, 15:43
  3. Replies: 10
  4. SALE!! POWER 4CH MAX AUDIO+KABEL2 & SEKRING +SPEAKER SOUNSTREAM MURAH!!
    By aquariuz_boyz in forum Bursa Audio Lainnya
    Last Post: 22nd February 2012, 02:07
  5. Replies: 9
    Last Post: 5th October 2011, 01:59
