.:de Auto Motorsport:. GARAGE SALE..!!
Page 1 of 33 12345 ... LastLast
Results 1 to 10 of 327
  • Short URL:  http://modifika.si/224998
    1 Wk 2 Days 19 Hrs 34 Mins 22 Secs
    Parts2 berikut on SALE dengan kondisi BRAND NEW dan quantity tidak lebih dari 2 Set lagi :
    Kontak,
    ::Coki Siboro::
    0815 1330 1978
    HKS BLOW OFF VALVE SSQV3-DIESEL
    Type : SSQV3D
    Application : Universal
    The newly designed SSQV3D uses a "boost drive controller" for positive boost operation.
    This new system can be used on vehicles which have no vacuum signal, such as diesel engines as well as conventional turbo vehicles by wiring into the accelerator pedal position or throttle sensor signal at the ecu.
    An on/off switch allows the SQV to be switched on or off at any time. A trigger switch can also allow the activation of the SQV on demand.
    Harga : 4.500.000
    ENERGY SUSPENSION PERFORMANCE PU COMPONENTS
    - HYPER FLEX MASTER SET HONDA CIVIC EK 96-00
    Master Set includes:
    Front control arm bushings, front shock bushings, front and rear sway bar bushings, front and rear coil spring isolators, rear trailing arm bushings, transmission shifter stabilizer bushings (Manual transmission only), rack and pinion bushings, front ball joint and tie rod end boots.
    Color Option : Black & Red
    Harga : 1.650.000 rp.
    - MOTOR MOUNT INSERT HONDA CIVIC EG 92-95 (MANUAL TRANS)
    Jumlah Engine Mounting : 3 Set
    Color Option : Black Only
    Harga : 600.000 rp.
    - TRANSMISSION SHIFTER STABILIZER HONDA CIVIC 88-00 (MANUAL TRANS)
    Harga : 170.000 rp.
    POWER ENTERPRISE Kevlar Timing Belt - Toyota 4AG16 & 4AG20
    Application :
    Toyota 4AG-16
    Toyota 4AG-20
    The pioneer of Kevlar timing belt. The original Kevlar timing belt developed by POWER featured 4-times durable against stretching compared to the stock belts. The new Kevlar Timing Belt features increased in heat resistance, improved in bending flexibility.
    Harga : 1,500,000 rp.
    Fidanza Lightweight Flywheel (Aluminum) - Toyota Corolla Altis
    Fidanza built to fly Aluminum Flywheel are made from the highest quality 6061 T6 aluminum. The material is fantastic for strength, heat dissipation and of course reduction in weight. The friction surface used is an incredibly strong 1050 steel. The plates are milled to meet Fidanza'a high specifications. A Fidanza flywheel can mate with any type of clutch material, including organic, kevlar, ceramic, metallic and sintered iron. Fidanza attaches the friction surface with military grade aerospace fasteners. The ring gears used are also made from 1050 steel and are heat treated for durability. The gears are heated then pressed on and secured with grade 8 button screws. Fidanza was the first to utilize a stepped dowel system in most of their flywheel applications. This doweling method ensures that once the pressure plate is installed the dowels cannot be removed because they become locked into place. Fidanza designs and builds flywheels with extreme precision, giving tuners, racers and builders the high performance and unmatched power they're seeking.
    Fidanza Flywheels help:
    Any street or race engine produce more usable horsepower!
    Any street or race engine lasts longer due to less stress on the crankshaft and bearings!
    Weight : 4,5 KG (OEM +/- 8 KG)
    Application :
    Toyota Corolla Altis 1.8L 1ZZ-FE
    Toyota Celica 1.8L 1ZZ-FE
    Toyota MR2 1.8L 1ZZ-FE
    Harga : 4.500.000
    WORKS ENGINEERING Rear Strutbar Bar 2 Point for Honda New Jazz GE8
    Material Alumunium, Harga : 850,000 rp.
    AXT TURBO Silicone Radiator Hose Kit 2pcs for Honda Civic FD1 1.8L
    AXT Turbo Silicone 3 layer Radiator Hose Kit 2pcs Upper & Lower Hose holds Hi-Pressure caused by increasing radiator temperature.
    Color : Red
    Harga : 950,000 rp. (Set 2pcs)
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    GARAGE SALE...! While stock last..
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
  1. .:de Auto Motorsport:. Lots of Racing Parts on October SALE.. SALE.. SALE..
    By coki.de auto in forum Jual Beli Mesin Lainnya
    Last Post: 2nd November 2010, 17:27
  2. .::de Auto Motorsport::. Auto Detailing..!
    By coki.de auto in forum Bursa Eksterior Lainnya
    Last Post: 27th May 2010, 20:04
  3. [de Auto Motorsport] SALE - SOLD OUT
    Last Post: 8th July 2009, 23:36
  4. [de Auto Motorsport] SALE: Barang 2nd --> SOLD OUT..!
    Last Post: 6th January 2009, 16:51
