CLEARANCE |S|A|L|E|
Results 1 to 10 of 60
  • Short URL:  http://modifika.si/224995
    1 Wk 3 Days 2 Hrs 57 Mins 2 Secs
    CLEARANCE |S|A|L|E|
    Parts2 berikut on |S|A|L|E| dengan kondisi 100% BRAND NEW & ORIGINAL
    Kontak,
    ::Coki Siboro::
    0815 1330 1978
    TURBONETICS TURBO GTK-350
    |S|A|L|E| Price : SOLD OUT
    HKS BLOW OFF VALVE SSQV3-DIESEL
    WORKS ENGINEERING OIL COOLER KIT - UNIVERSAL
    KANSAI EXHAUST MAZDA 2 421 HEADER
    A simple way to release your true Mazda 2 power and response. Direct bolt on with no modification needed on the installation.
    Harga Normal : 2.470.000 > |S|A|L|E| Price : 1.500.000 rp.
    A'PEXi POWER INTAKE KIT
    "The Power Intake is the premier air filter designed to create pure horsepower. The intake funnels used in racing machines take advantage of a characteristic where air travels along the side of the side of surfaces. However, the center portion of the funnel is virtually unused. It is this concept that gave birth to the Dual Funnel design. A primary funnel on the top portion of the air cleaner was inserted to channel the air flow directly into the lower funnels at the base of the cleaner. This design was a huge success on the former Super Intake model. The Power Intake took this design and improved the flow characteristics. New funnel design, element material and air flow channeling characteristics make the Power Intake one of the most efficient air cleaners on the market today. By constructing the upper and lower funnel from a highly durable injected resin, engineers were able to construct the ideal shaped funnel previously not possible with the stainless steel material. Funnel shapes focused on increasing air speed without changing the flow direction of the intake air. The result is a high speed and smooth flow of air into the intake. The lower funnel has been engineered at a 14 degree curve for maximum efficiency. Also, the lower funnel position has been made even closer to the base of the cleaner to reduce drag and eliminate any _dead spots” within the cleaner.
    The Power Intake incorporates a newly developed material (layer filter of dry density fibers) which improves the element density. This allows maximum protection from foreign materials entering the engine. Compared with past model, the Power Intake has also succeeded in decreasing its ventilation resistance by about 10% (pressure loss) for maximum performance and protection. The Power Intake is dry-type filter and is trouble free. Some of the problems associated with wet type cleaners, such as oil sticking to the air flow meter, are a thing of the past. The Power Intake is basically maintenance free. Filter replacement, when necessary, can be done at a very low cost.
    CONCEPT: Air filter with minimal air-flow restriction
    CHARACTERISTICS: Dual funnel filter system minimizes intake turbulence
    HONDA CIVIC EK9 B16A TYPE-R
    Harga Normal : 2.700.000 > |S|A|L|E| Price : 1.750.000 rp.
    HONDA ACCORD/PRELUDE BB1 H22A
    Harga Normal : 3.000.000 > |S|A|L|E| Price : 1.750.000 rp.
    A'PEXi POWER INTAKE PANEL FILTER
    Some manufacturers of performance air filters make aggressive claims about their filter's ability to make power, but leave out the fact that their filters are not effective at filtering dust and dirt. Consider the wear and tear that will result from insufficient filtration.
    The Apex Power Intake filter element is engineered to minimize air flow restrictions without compromising its ability to filter contaminants from the induction air stream. We proudly expand the usage of the Power Intake filter element by incorporating it into a line of drop-in, factory-replacement filters. A little TLC for your daily driver.
    The filter can be cleaned by blowing compressed air through the filter, opposite the direction of inbound airstream. This filter is designed for use as a dry-type filter. Do not apply filter oil to this filter as it was not designed to utilize such oils. Water, cleaning solvents, and other liquids may damage the filter and must not be used to clean the filter.
    PRODUCT FEATURES:
    - Progressive-density filter element improves power and efficiency, without compromising ability to filter dust and dirt
    - Dry-type filter element requires no oiling, and will not foul air flow sensors
    - Ideal for light-tune cars, and cars that develop problems with idle and throttle response issues when the factory air box is removed
    - Factory replacement filter installs in minutes
    - Easy Cleaning and maintenance
    TOYOTA YARIS & NEW VIOS
    Harga Normal : 700.000 > |S|A|L|E| Price : 475.000 rp.
    SUZUKI SWIFT 04-12
    HKS SUPER HYBRID FILTER
    PRODUCT FEATURES:
    - 3 layered filter divides, collects intake air and smoothes air flow. It enables quick response that is required for sport filter
    - Newly developed Non-woven fabric is the first layer that collects large dust. Second layer polyurethane filter collects small dust
    - Joining of each layer was changed from flame lamination to net type joining that does not affect intake air flow
    - High strength double frame, strong frame can be used for high horsepower
    - Separate shield frame is cushion type that does not require rubber gasket and easily disposable after use
    HONDA CIVIC ESTILO/GENIO
    Harga Normal : 750.000 > |S|A|L|E| Price : 375.000 rp.
    MITSUBISHI LANCER CB4 GLXi
    Harga Normal : 850.000 > |S|A|L|E| Price : 400.000 rp.
    Harga Normal : 875.000 > |S|A|L|E| Price : 450.000 rp.
    SUZUKI SWIFT 04-12
    Harga Normal : 900.000 > |S|A|L|E| Price : 475.000 rp.
    ACL DURAGLIDE MAIN & ROD BEARINGS HONDA B16A/B20B STD SIZE
    ACL Bearing offers the unique combination of design, metallurgy and engineering come together to deliver what drivers expect from high performance Tri-metal engine bearings.
    ACL Bearings allow engine builders to have a choice when choosing bearings for a rebuild. Whether you're looking to get your daily driver back on the road or need to make your bottom end bullet proof, ACL will have a bearing to meet your needs.
    Harga Normal : 1.850.000 > |S|A|L|E| Price : 1.500.000 rp.
    COMETIC MLS ENGINE HEAD GASKET HONDA K20A/K24A 89MM & .030" (0.76MM)
    Cometic Multi-Layer Steel MLS gaskets are designed to give you the best possible seal for your naturally aspirated, boosted or nitrous fed engine. The head gaskets are made from three to five layers of spring stainless steel, offering you a stronger base material than standard head gaskets. The outer layers are Viton coated stainless steel providing a superior seal not available with other steel or copper gaskets. The gaskets offer excellent rebound characteristics and are made to resist corrosives. MLS head gaskets reduce bore distortion but still can withstand extreme cylinder pressures.
    Harga Normal : 1.750.000 > |S|A|L|E| Price : 1.250.000 rp.
    SUPERTECH VALVE SPRING & TITANIUM RETAINER KIT HONDA D16A SOHC NON-VTEC
    Supertech performance valve springs are made with premium Superclean Chrome Silicon Vanadium Steel Alloy for higher performance and durability. Computer designed to ensure that wire stress levels do not overpass the limits for long durability under extreme conditions and harmonics are well under control.
    And the Titanium Retainers prevent valve float and strength up your valvetrain. Retainers are CNC machined from 6AL4V grade titanium.
    Harga Normal : 4.950.000 > |S|A|L|E| Price : 4.000.000 rp.
    SUPERTECH DUAL VALVE SPRING SET HONDA B16A/B18C DOHC VTEC ALL MOTOR
    Supertech valve springs are made with premium Superclean Chrome Silicon Vanadium Steel allowing for higher performance, durability and better memory at high rpms. Computer designed to ensure that wire stress levels do not overpass the limits of stress defined in the diagrams of fatigue for excellent durability under extreme conditions.
    Computerized engineering also allows Supertech to make sure that the harmonics are well under control.
    Harga Normal : 2.400.000 > |S|A|L|E| Price : 2.000.000 rp.
    GUDE BULLFROG HCCS-21 CAMSHAFT & DUAL VALVE SPRING SET HONDA B16A/B18C DOHC VTEC
    Gude Performance Bullfrog and Stinger Cams are ground to precise tolerances, and are of the famous Gude profiles.
    Gude poured out all 30 plus years of experience into designing cam profiles that are stable at extreme high rpm with stock or light valve spring loading, thus increasing horse power and engine reliability (high valve spring loading can cause excessive wear and result in total valve stem failure destroying an expensive engine).
    Product Features:
    - A Package of (Pair) Camshaft Intake & Exhaust + (Dual) Valve Spring Set
    - Minimum of 11.5:1 Compression
    - Duration : Intake 296deg & Exhaust 258deg
    - Lift : Intake 11.303mm & Exhaust 10.287mm
    Harga Normal : 12.000.000 > |S|A|L|E| Price : 9.500.000 rp.
    OGURA RACING CLUTCH KIT HONDA B-SERIES
    OEM ACURA INTEGRA DC5 K20A2 TYPE-R OIL PUMP
    KTUNED SHIFTER PLATE HONDA CIVIC EG K-SERIES SWAP
    The K-Tuned shifter mounting plate is designed for use with K-swapped EG/EK/DC2 vehicles. It is constructed using 3/16” thick billet aluminum and is anodized black for a great looking and durable finish.
    Key features:
    - Unique steel template is included which greatly improves cut out accuracy
    - Custom made grommet seals cables perfectly
    - The factory shifter is held firmly to the plate with studs and custom fit billet aluminum bushings
    - Very easy to install with complete instructions and template provided
    - Silver zinc plated hardware to resist rust
    - Lightweight aluminum design
    Harga Normal : 2.250.000 > |S|A|L|E| Price : 1.250.000 rp.
    OEM HONDA CIVIC FD1 R18A OIL PAN/CARTER
    Untuk yang mau bangun turbo di Honda Civic FD1 R18A, tapi tidak mau mengorbankan OEM Oil Pan nya di modifikasi untuk jalur balik oli dari turbo. Atau yang mau standarin Oil Pan nya, atau yang kena musibah Oil Pan nya pecah/sobek karna kena batu dll.
    Harga Normal : 1.950.000 > |S|A|L|E| Price : 1.250.000 rp.
    RUNSTOP FRONT OVERSIZE DISC ROTOR TOYOTA FORTUNER 350MM (NO BRACKET)
    Untuk yang mau upgrade pengereman Toyota Fortuner nya, Runstop Front Oversize 350mm Disc Rotor Slot & Drill ini dapat menjadi solusi yang tepat. Diameter lebih besar membuat jarak pengereman menjadi lebih pendek, karna momen inersia pusat putaran lebih jauh dibanding disc rotor ukuran standar.
    Minimum penggunaan velg untuk disc rotor oversize 350mm (OEM=297mm) ini adalah 18inch. Braket Caliper tidak tersedia, jadi harus dibikin/custom lagi.
    Harga Normal : 7.500.000 > |S|A|L|E| Price : 3.750.000 rp.
    RUNSTOP BRAKE REAR CONVERSION KIT HONDA JAZZ GD3 IDSI 2 POT CALIPER 285MM ROTOR
    HONDA JAZZ GD3 IDSI Rear Brake Conversion Kit from Drum to Disc Brake System (also compatible for Honda New City GD8 IDSI)
    1 Set Rear Brake Conversion Kit Includes :
    Slot & Drill Disc Rotor 285mm (min. 15inch wheel required)
    2 Piston Caliper - Red
    Brake Pads
    Brake Lines
    Bracket & All Necessary Hardware
    Harga Normal : 7.500.000 > |S|A|L|E| Price : 5.750.000 rp.
    PROJECT MU B-SPEC FRONT BRAKE PAD TOYOTA ALTIS 02-07 & TOYOTA VIOS 02-06
    Designed for all types of sport driving including circuit use. They provide dependable braking and improved anti-fading performance. They are rated up to 500 degrees Celsius.
    Product Features :
    - Asbestos Free Material
    - Carbon Metal Material
    - 0-500C Rotor temperature range
    - 0.32-0.45mu friction coefficient
    Harga Normal : 1.600.000 > |S|A|L|E| Price : 900.000 rp.
    PROJECT MU LEVEL MAX900i FRONT BRAKE PAD SUZUKI SWIFT 04-12
    ENERGY SUSPENSION PERFORMANCE PU COMPONENTS
    - HYPER FLEX MASTER SET HONDA CIVIC EK 96-00
    Master Set includes:
    Front control arm bushings, front shock bushings, front and rear sway bar bushings, front and rear coil spring isolators, rear trailing arm bushings, transmission shifter stabilizer bushings (Manual transmission only), rack and pinion bushings, front ball joint and tie rod end boots.
    Color Option : Black & Red
    Harga Normal : 2.850.000 > |S|A|L|E| Price : 1.650.000 rp.
    - MOTOR MOUNT INSERT HONDA CIVIC EG 92-95 (MANUAL TRANS)
    Jumlah Engine Mounting : 3 Set
    Color Option : Black Only
    Harga Normal : 950.000 > |S|A|L|E| Price : 600.000 rp.
    - TRANSMISSION SHIFTER STABILIZER HONDA CIVIC 88-00 (MANUAL TRANS)
    Harga Normal : 300.000 > |S|A|L|E| Price : 170.000 rp.
    POWER ENTERPRISE Kevlar Timing Belt - Toyota 4AG16 & 4AG20
    The pioneer of Kevlar timing belt. The original Kevlar timing belt developed by POWER featured 4-times durable against stretching compared to the stock belts. The new Kevlar Timing Belt features increased in heat resistance, improved in bending flexibility.
    Application :
    Toyota 4AG-16
    Toyota 4AG-20
    Harga Normal : 2.250.000 > |S|A|L|E| Price : 1.500.000 rp.
    Fidanza Lightweight Flywheel (Aluminum) - Toyota Corolla Altis
    Fidanza built to fly Aluminum Flywheel are made from the highest quality 6061 T6 aluminum. The material is fantastic for strength, heat dissipation and of course reduction in weight. The friction surface used is an incredibly strong 1050 steel. The plates are milled to meet Fidanza'a high specifications. A Fidanza flywheel can mate with any type of clutch material, including organic, kevlar, ceramic, metallic and sintered iron. Fidanza attaches the friction surface with military grade aerospace fasteners. The ring gears used are also made from 1050 steel and are heat treated for durability. The gears are heated then pressed on and secured with grade 8 button screws. Fidanza was the first to utilize a stepped dowel system in most of their flywheel applications. This doweling method ensures that once the pressure plate is installed the dowels cannot be removed because they become locked into place. Fidanza designs and builds flywheels with extreme precision, giving tuners, racers and builders the high performance and unmatched power they're seeking.
    Fidanza Flywheels help:
    Any street or race engine produce more usable horsepower!
    Any street or race engine lasts longer due to less stress on the crankshaft and bearings!
    Weight : 4,5 KG (OEM +/- 8 KG)
    Application :
    Toyota Corolla Altis 1.8L 1ZZ-FE
    Toyota Celica 1.8L 1ZZ-FE
    Toyota MR2 1.8L 1ZZ-FE
    Harga Normal : 5.750.000 > |S|A|L|E| Price : 4.500.000 rp.
    WORKS ENGINEERING Rear Strutbar 2 Point Honda New Jazz GE8
    DEFI BF RACING GAUGE METER 60MM BLACK FACE - WHITE LED
    B&M LAUNCH CONTROL
    COMP CAMS CAMSHAFT DEGREE KIT
    COMP Cams universal camshaft degree kits dial in all your vehicles accurately!
    Degreeing your cam means better performance and COMP Cams universal degree kits offer precision results. These kits include the necessary components to work with the cylinder heads on including an easy-to-read and clean COMP Cams Sportsman 9 in. degree wheel plus foam-lined storage case. Kits are ready to fit your most popular engines and positions your camshaft for top performance with COMP Cams universal camshaft degree kits.
    Harga Normal : 2.950.000 > |S|A|L|E| Price : 2.000.000 rp.
    TRICK FLOW CAMSHAFT DEGREE KIT
    These Trick Flow® cam degreeing kits will help you dial in your camshaft accurately. The kits can also be used to check piston-to-valve clearance, flywheel run-out, crankshaft end play, and ring gear backlash. The kits have two low-tension checking springs, a wire pointer, a top dead center stop, an 11 in. black degree wheel with laser etched marks, three adapter bushings, a flat washer, a magnetic base, a dial indicator, and a carrying case.
    Harga Normal : 2.500.000 > |S|A|L|E| Price : 1.750.000 rp.
    MICKEY THOMPSON ET DRAG SLICK 24.5/8.0-13 - SOLD 2 PCS
    Mickey Thompson ET drag slicks are designed, engineered, and built for outstanding performance, run after run. Real-world research and development give Mickey Thompson ET drag tires the edge over competing brands! They are engineered for maximum traction and consistent ETs with superior construction and compounding for nearly every sport compact drag race application.
    Product Features :
    - Tire Size: 24.50 x 8.00-13
    - Wheel Diameter: 13 in.
    - Sidewall Style: Blackwall
    - Tire Type : Non-Radial
    - Tire Construction: Bias-ply
    - Compound : L8 Compound ( Good compound for general use)
    - Production Year : 2013
    Harga Normal (2pcs) : 11.500.000 > |S|A|L|E| Price (2pcs) : 9.000.000 rp.
    KSPORT COILOVER KIT - KONTROL PRO DAMPER/STREET
    Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your vehicle, both on the street or at the track. 36 levels of damping adjustment allow fine tuning of the damper to suit both handling and comfort needs. The damping adjustment alters compression and rebound simultaneously, for more effective and user-friendly setup changes.
    Pillow ball top mounts in the front and rear on some applications allow the vehicle to install and setup to OEM specifications. Ksport’s patented upper pillow ball mount offers the same level of adjustability and performance, but allows for compliance that is often required from high-demand strut applications. On applicable models, the pillowball upper mounts offer camber adjustment, saving the need for a special, separate camber kit. For enthusiasts seeking the ultimate in adjustability, Ksport’s advanced upper pillow ball mount is available on some applications, giving the option for separate camber and caster adjustment.
    Most applications utilize an adjustable lower mount, which means height adjustability without losing suspension travel—a problem found in many coilover systems available today. Since mounts and most pieces in the coilover system are designed from 6061 billet aluminum, the components are lightweight, durable, and rust resistant. Steel shock bodies are electroplated with zinc to resist rust and protect from the elements. The shock or strut valving for each piece is matched accordingly to the spring rate, giving superior ride quality and reliability.
    The Ksport system uses a monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube construction, the monotube design dissipates heat faster and more evenly, allows finer damping adjustments, and requires more expensive design process. Aeration and cavitation issues are a lot less common in a monotube design, which results in a more consistent ride quality.
    MAZDA 2
    Harga Normal : 11.000.000 > |S|A|L|E| Price : 8.500.000 rp.
    NISSAN CEFIRO/MAXIMA A32
    GRAB IT FAST...!
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
  2. clickbet88.com
    updated....!!
    CP : Coki Siboro
    7 Mins 58 Secs
    Boss coki sorry pertanyaan nubie nih.
    Works Engineering buatan mana ya boss?
    Quote Originally Posted by -sempak balap- View Post
    yg saya tau sih kantor nya ada di malaysia bos..
    CP : Coki Siboro
    UTR Lightweight Crank Pulley for Suzuki Swift is SOLD..
    CP : Coki Siboro
    update :
    KSPORT Coilover Kit for Honda Jazz GD3 is SOLD..!
    CP : Coki Siboro
    update :
    Intercooler Piping Upgrade Mitsubishi Evolution 4-6 is SOLD...!
    CP : Coki Siboro
    updated with Forged Racing Aluminum Radiator 2 Row Honda Jazz GD3
    CP : Coki Siboro
    simatupang
    9 Hrs 34 Mins 45 Secs
    Bos radiatornya udh termasuk selang lengkap tutup radiator? Apa aja kelengkapannya bos? Tq
    Quote Originally Posted by sendisurya View Post
    aluminum radiator only bos..
    tidak termasuk selang, tutup radiator dll
    CP : Coki Siboro
  1. CUCI GUDANG - peralatan cuci mobil,shampoo - meguiars, 3m, ice
    By Enxiel in forum Jual Beli Barang Mobil Lain-Lainnya
    Last Post: 7th April 2012, 12:40
  2. cuci gudang
    By soloboy in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 14th March 2012, 11:02
  3. FS: Cuci Gudang
    By afah in forum Jual Beli Mesin Lainnya
    Last Post: 2nd August 2011, 13:30
  4. cuci gudang....
    By MH Motorsport in forum Jual Beli Mesin Lainnya
    Last Post: 14th February 2010, 00:47
  5. CUCI GUDANG [ S O L D ]
    By reffy in forum Bursa Eksterior Lainnya
    Last Post: 26th November 2008, 14:48
