PAKET PEREDAM PROFESSIONAL HEAT, VIBRATION, NOISE INSULATION
SOUNDPROOFING PACKAGE
"make your car more comfortable with cliport soundproof profesional division"
- Heat insulation
- More silent
- No vibrations
- Absence of distorsion
- Better listening of your mobile phone, navigation, DVD
STEALTH SOUNDPROOF MATERIAL
HEAT | VIBRATION | NOISE
STEALTH VS258
DESCRIPTION :
2mm, Butyl rubber with Alumunium sheet, 50cm x 80cm
VS258 is a lightweight soundproof material using butyl rubber with alumunium sheet which will provides maximum damping performance to reduce noise, vibration, and also very effective to reduce heat in your vehicle. VS258 can be used on any metal interior sheet or fiberglass in your vehicle
APPLICATION :
Door panel, Floor, Trunk, Engine, Roof, and Subwoofer enclosure
STEALTH VS158
DESCRIPTION :
2mm, Bitumen based, 50cm x 80cm
STEALTH VS158 is a bitumen based damping sheet which are manufactured from bitumen with added mineral filters and rubber to form a highly viscoelastic material. The adhesive layer is very agressive and the bond will actually improve over time
APPLICATION :
STEALTH BX 02
DESCRIPTION :
6mm, Closed cell foam with Alumunium sheet, 100cm x 200cm
BX02 is a model of damping to prevent the heat from passing trough. This one uses for hood and roof of a car with 1cm thickness.
APPLICATION :
Engine Hood & Roof
STEALTH GS158
DESCRIPTION :
3mm, Closed cell foam, 50cm x 80cm
GS158 is a composite product that has been engineered to block and reflect high energy, low frequency road noise, an airborne sound, across a wide frequency range. It consists of a closed cell neoprene foam layer that is bonded to a dense foam barrier. The neoprene foam layer creates an "airsping” that allows for the reflection of high energy soundwaves and prevents the sound energy from passing through the dense layer.
APPLICATION :
Door panel, Speaker gasket, and for reduce rattle between plastic and metal parts
Product available @ Cliport Car Audio
For more information please contact our workshop
Cliport Car Audio Division
Adress : Jl. Sumbawa No 60 (BANDUNG)
Office Number : (022) 73404522
Mobile Phone : 081221420030/08987872040
BB PIN : 2303B068
Customer Support@Cliport Car Audio
YM : cliportaudio_cs
broo,list harganya pmin ya. untuk yg STEALTH VS258 sepaketnya+ongkos bongkar pasang brpa? mbl dtinggal brpa lama boss??
System pemasangan peredaman yang paling efektif meredam getaran,meredam suara, sekaligus meredam panas. Ada beberapa tahapan"nya, pertama yang paling kursial adalah untuk meredam getaran itu menggunakan STEALTH VS258 bahan butyl ruber daya rekat nya paling baik dibandingkan bahan aspal dan yang paling penting tidak membuat berat kendaraan, dilengkapi dengan bahan alumunium sebagai pelapis luarnya aplikasi diperuntukan di pintu, plafon, mesin, trunk. lanjut ke proses peredaman lantai menggunakan bahan STEALTH VS158, di sini tidak perlu untuk menggunakan bahan VS258 akan tetapi setelah pemasangan VS158 itu langsung dilapisi kembali oleh BX02 berbahan foam dan alumunium sebagai peredam noise, Noise paling banyak dirasakan ada di dekat putaran ban. BX 02 nanti akan kita pasang di mesin dan di plafon. Sebenarnya VS258 juga sudah bisa untuk meredam getaran dan panas tapi tidak bisa di katagorikan sebagai bahan untuk meredam noise. ambil satu paket full satu mbl jatuhnya lebih murah saya kirim lewat Pm ya untuk rincian biaya nya.
Tolong PM harga full package untuk pajero sport...
Apa setelah instalasi selain kesenyapan dalam kabin bertambah apa suara kretek2 khas diesel juga bisa jauh berkurang?
Dan satu lagi pertanyaan.. Kalau pakai full package berat keseluruhan peredam tersebut brp KG ya?
Makasih banyak untuk infonya..
