ALPINE CAR AUDIO
Rgotogel Gelap.net 36Goal.com
  • Short URL:  http://modifika.si/223806
    www.cliport-audio.com
    1 Wk 3 Days 21 Hrs 51 Mins 49 Secs
    ALPINE CAR AUDIO
    /////ALPINE CDA-117E
    CD RECEIVER / USB AND iPod® CONTROLLER
    Spoiler for Features & Specifications CDA-117E: Show
    Product Information
    Sophisticated Sound Control
    If you like to fine-tune your system sound, this is the model for you. Digital Time Correction lets you compensate for varying speaker distances so you hear all the channels at the same time. You can also customise the sound with a 7-band graphic EQ, 5-band parametric EQ and High Pass Filter control.
    Digital AM/FM Tuner Provides High Performance
    Alpine’s new digital AM/FM tuner finds and locks onto stations with extreme precision and virtually eliminates interference from multipath and adjacent channels. As a result, you enjoy crystal clear radio reception at all times.
    MediaXpander Makes It Sound Better
    iPod and other MP3 players sound good, but not as good as the original because
    the data is compressed. To get you much closer to that pristine sound,
    Alpine developed the MediaXpander. It enhances the frequency ranges
    where the sound is compressed, restoring the original vibrancy.
    Fast Access to USB Music Files
    The CDA-117E provides a high-performance USB 2.0 connection that accepts a wide
    range of USB mass storage devices. Alpine’s Tag Banking feature increases file reading
    speed to three times that of previous models and is also capable of reading
    up to 20,000 songs.
    * iPod is a trademark of Apple Inc., registered in the U.S. and other countries.
    * iPhone is a trademark of Apple Inc., registered in the U.S. and other countries.
    Features&Specifications
    • 50W x 4 High Power Amp
    • CD-R/-RW/MP3/AAC/WMA Playback
    • High Speed USB Connection for iPod/USB sticks
    • Works with iPhone
    • USB cable and iPod / USB adapter Included
    • 6-Channel Digital Time Correction
    • 7-band Graphic EQ or 5-band Parametric EQ
    • HPF Control
    • Digital AM/FM Tuner
    • Auto Volume
    • 24-Bit DAC
    • BioLite Display
    • IMPRINT Ready with PXA-H100
    • Parrot Bluetooth Ready with KCE-400BT
    • Full Speed AUX Input (requires KCE-237B)
    • Remote Control Included
    • Steering Wheel Remote Control Ready
    • Quick Search
    • Ai-NET
    • 2 Illumination Colours Selectable (blue/red)
    /////ALPINE CDA-9887
    IMPRINT CD Receiver/ iPod® Controller
    Spoiler for Features & Specifications CDA-9887: Show
    Features
    ? 4 x 50W High Power Amp
    ? CD-R/-RW/MP3/AAC/WMA Playback
    ? Audyssey MultEQ built in
    ? Full Speed connection for iPod touch, iPod nano and all iPod models with dock connector
    ? BioLite Display
    ? Bluetooth Ready
    ? Full Speed AUX Input
    ? Quick Search
    ? Ai-NET
    ? 4 illumination colors selectable
    ? 3 PreOut (4Volt)
    ? Remote Control Included
    ? IMPRINT Sound Calibration requires KTX-100EQ
    Specifications
    Dimensions
    ? Din Size: 1
    ? Chassis Size (W x H x D) mm: 178mm x 50mm x 162mm
    General
    ? CEA-2006 Power Rating (4Ohm @14.4 V =1% THD+N), S/N 80dBA (Ref: 1W into 4Ohm): 18W x 4
    ? Max Power Output: 50W x 4
    ? Pre Output Voltage (Before Clipping): 4V
    ? Power Requirement: 14.4 (11-16) V.DC
    ? Operating Temperature (°C/ °F): 60 °C (140 °F) to -10 °C (14 °F)
    ? Maximum Mounting Angle: 35° from Horizontal
    /////ALPINE CDA-9886
    USB/iPod Controller/MP3/WMA/AAC Receiver
    Spoiler for Features & Specifications CDA-9886: Show
    Features
    ? 50W x 4 High Power Amp
    ? CD-R/-RW/MP3/WMA/AAC Playback
    ? Full Speed connection for iPod®
    ? Full Speed AUX Input Ready
    ? Quick Search
    ? USB Connection for USB memory devices
    ? IMPRINT Ready (Requires optional PXA-H100
    ? 3 Pre-outs (4 volt)
    ? 2 Pre-ins for PXA-H100
    ? Bluetooth ready
    ? Percentage Search for iPod®
    ? Full Speed iPod® cable included
    ? Remote Control included
    ? BioLite Display
    Specifications
    Dimensions
    ? DIN Size: 1
    ? Chassis Size (W x H x D) mm: 178mm x 50mm x 160mm.
    General
    ? Power Requirement 14.4 V DC (11-16 V allowable)
    ? Pre Output Voltage (Before Clipping): 2V
    ? Operating Temperature ( °C): 60 °C to -10 °C
    ? Maximum Power Output 50 W × 4
    ? Maximum Pre-Output Voltage 4 V/10 k ohms
    ? Bass +14/-14 dB at 100 Hz
    ? Treble ±14 dB at 10 kHz
    ? Weight 1.6 kg (3 lbs. 8 oz)
    /////ALPINE CDA-105
    Spoiler for Features & Specifications CDA-105: Show
    Features
    USB Connection (on backside)
    Ai-NET Connection
    Quick Search
    CD Changer Control
    Display
    2 Line LCD Dot Matrix Display
    White pixels Display
    iPod®
    iPod® 5G
    iPod® nano 1G - 4G
    iPod® classic
    iPod® touch 1G - 2G
    iPhone® and iPhone® 3G
    Quick Search
    Search music by:
    Album, Artist,Song,
    Playlist, Genre,
    Audio book, Composer
    Alphabet/Percent Skip
    Audio
    MP3/WMA Playback
    AAC Playback
    MTP Ready
    24-Bit DAC
    High Pass Filter
    Treble Center Freq. Cont.
    Bass Center Freq. Cont.
    Subwoofer Level Control
    Size and weigh
    Height: 50mm (1DIN)
    Width: 178mm (1DIN)
    Depth: 156mm
    Weight: 1.5kg
    Outputs
    Amp: 4 x 50W MAX
    3 PreOuts (2 PreIns)
    Power Antenna
    Remote On Signal
    AUDIO VIDEO
    IVA-W502E
    2 DIN Mobile Multimedia Station
    Spoiler for Features & Specifications IVA-W502E: Show
    Features
    * 7" WVGA Touch Screen display
    * 50W x 4 High Power Amp
    * DVD-R/-RW/MP3/AAC/WMA/DivX Playback
    * USB Connection for iPod
    * iPod Video Content Play back
    * 3 Preouts / 2 Preins for PXA-H100
    * IMPRINT Ready (Requires PXA-H100)
    * Bluetooth Ready with audio streaming
    * 24 Bit DAC
    * Visual Enhancement System
    * Remote Control Ready
    * 1 AUX input/ 1 AUX output
    * DVD-Audio 2ch down-mix
    Specifications
    Dimensions
    * Din Size: 2
    * Chassis Size (W x H x D) mm: 178mm x100mm x 160.5mm
    Monitor Section
    * Screen Size: 7.0"
    * LCD Type: Transparent type TN LCD
    * Operation System: TFT active matrix
    * Number of Picture Elements: 1,152,000 pcs. (800 × 3 × 480)
    * Effective Number of Picture Elements: 99% or more
    * Illumination System: LED
    General
    * Power Requirement: 14.4 V DC(11-16 V allowable)
    * Operating temperature: +32°F to +113°F(0°C to + 45°C)
    * Maximum Power Output: 50 W × 4 Output Voltage: 2,000 mV/10k ohms
    * Bass: ±14 dB at 60 Hz
    * Treble: ±14 dB at 10 kHz
    * Weight: 2.7 kg (5 lbs. 15 oz)
    * Audio output level Preout (Front, Rear): 2V/10k ohms (max.) Preout
    (Subwoofer): 2V/10k ohms (max.)
    * AUX OUT: 1.2V/10k ohms
    * Ai-NET: 850 mV
    IVA-W202E
    2-DIN DVD/CD/MP3/WMA Receiver/AV Head Unit
    Features
    ? 6.5" QVGA PulseTouch Display
    ? DVD+-R/+-RW/MP3/AAC/WMA Playback
    ? Full Speed Connection for all iPod models with dock connector
    ? 24-Bit DAC
    ? DVD-Audio 2Ch. down-mix
    ? Bluetooth Ready with Audio Streaming
    ? Quick Search
    ? Ai-NET
    ? 3 PreOuts
    ? Remote Control Ready
    ? 1 AUX input / 1 Aux output
    ? Rear camera Input
    Specifications
    Dimensions
    ? Din Size: 2
    ? Chassis Size (W x H x D) mm: 178mm x100mm x 165mm x100mm x 165mm
    Monitor Section
    ? Screen Size: 6.5"
    ? LCD Type: Transparent type TN LCD
    ? Operation System: TFT active matrix
    ? Number of Picture Elements: 280,800 pcs. (400 x 3 x 234)
    ? Effective Number of Picture Elements: 99% or more
    ? Illumination System: Cold cathode fluorescent tube pcs. (400 x 3 x 234)
    General
    ? Power Requirement: 14.4 V DC(11-16 V allowable)
    ? Operating temperature: +32°F to +113°F (0°C to + 45°C)
    ? Maximum Power Output: 50 W x 4
    ? Output Voltage: 2,000 mV/10 k ohms
    ? Bass: ±14 dB at 60 Hz
    ? Treble: ±14 dB at 10 kHz
    ? Weight: 3.0 kg (6 lbs. 9 oz)
    ? Audio output level:
    Preout (Front, Rear): 2 V/10 k ohms (max.)
    Preout (Subwoofer): 2 V/10 k ohms (max.)
    ? AUX OUT: 1.2 V/10 k ohms
    ? Ai-NET: 850 mV
    IVA-D106E
    1 Din Mobile Media Station
    Spoiler for Features & Specifications IVA-D106E: Show
    Features
    ? 4 x 50w High Power Amp
    ? 7" QVGA Tuch Screen Display
    ? DVD-R/RW/MP3/AAC/WMA/DivX
    ? IMPRINT Ready (PXA-H100)
    ? Full Speed Connection for iPod
    ? iPod Video content Playback
    ? 24 Bit DAC
    ? Bluetooth ready
    ? Ai-Net
    ? Visual EQ
    ? 3 Preouts
    ? 2 Preins for PXA-H100
    ? Rear Camera Input
    Specifications
    Dimensions
    ? Din Size: 1
    ? Chassis Size (W x H x D) mm: 178mm x50mm x 165mm
    Monitor Section
    ? Screen Size LCD: 7.0"
    ? Type Operation System: Transparent type TN LCD TFT active matrix
    ? Number of Picture Elements: 336,960 pixels (1440 x 234)
    General
    ? Operating temperature 0°C to +45°C
    ? Maximum Power Output 50 W x 4
    ? Output Voltage 2V/10k ohms
    ? Bass ± 14 dB at 100 Hz
    ? Treble ± 14 dB at 10 kHz
    ? Weight 2.6 kg
    ? Audio output level Preout (Front, Rear):
    2V/10k ohms (max.) Preout (Subwoofer): 2V/10k ohms (max.)
    ? AUX OUT: 1.3V/10k ohms
    ? Ai-NET: 850 mV
    DVD PLAYER
    DVA-9861E
    DVD Receiver / iPod® Controller
    Spoiler for Features & Specifications DVA-9861E: Show
    Features
    ? 50W x 4 High Power Amplifier (Micro Dynamics ™)
    ? CD Changer Control Function
    ? Data Download (Setting the Wallpaper)
    ? Flip Down Face
    ? Media Playback (DVD Video, DVD-Audio, DVD-VR, VCD, CD-DA, MP3/WMA)
    ? Rotary Encoder Volume Control (Pop-up Rotary Knob)
    ? Black Face w/Blue illumination Buttons
    ? 3 PreOuts (4V PreOut)
    ? 4V PreOut with DC-DC Converter
    ? Bluetooth® Ready
    ? MM Driver Ready (Hard Disc Drive Ready)
    ? TDS Amp and Processor Control Capabilities
    ? Optical Output
    ? Built-in Dolby Digital /DTS Decoder (2-Channel Mix Down)
    ? Fader & Balance Controls Clock
    ? Detachable Trim Plate
    ? Anti-Theft Detachable Front Panel
    ? BlackOut Display
    ? Power Antenna Lead
    ? Remote-on Lead
    ? Audio Interrupt In Audio Mute
    ? Wireless Remote Control Included
    Specifications
    Dimensions
    ? DIN Size: 1
    General
    ? CEA-2006 Power Rating (4Ohm @ 14.4 V =1% THD+N), S/N 80dBA (Ref: 1W into 4Ohm): 18W x 4
    ? Max Power Output: 50W x 4 <
    ? Operating Temperature ( °C/ °F): 60° C (140° F) to -10° C (14° F)
    ? Maximum Mounting Angle: 30° from Horizontal
    PROCESSOR
    PXA-H100
    IMPRINT Sound Processor
    Spoiler for Product Information PXA-H100: Show
    PXA-H100
    The Music You Expect to Hear
    You love music and you know good sound when you hear it. When you play your music on an audio system, you expect to be able to hear it with all the power, clarity and subtle expressive nuances of the original. Unfortunately, nothing dashes those expectations more thoroughly than the sonic environment of the car.
    Poor Acoustics in the Car
    The car interior is full of materials that actively distort and degrade the sound. Windows amplify and reflect high frequencies. Seat and dashboard coverings change certain frequencies. Carpets absorb and suppress mid frequencies. These problems are far too complex to be solved by simple equalisation. In addition, since the speakers are located at different distances from the listeners, the sound stage created in the car is unbalanced and asymmetrical.
    The Technology behind IMPRINT Sound
    Behind the innovative IMPRINT Sound processing is a key technology called MultEQ. It analyses the acoustic characteristics of your car interior, and then creates a set of equalisation filters to correct for frequency response and time delay problems for each speaker in your car. MultEQ applies processing to over 500 specific frequencies in the audio spectrum, correcting the sound to perfectly match your listening environment with incredible precision. The result is that everyone in the car hears the music with superb clarity and imaging.
    Features
    ? Works with all IMPRINT Ready Head Units
    ? Audyssey MultEQ Sound Optimisation
    ? 24-Bit DAC
    ? 6 Channel Digital Time Correction
    ? 5 Band Parametric EQ
    ? 7 Band Graphic EQ
    ? Media Xpander
    ? 3 PreOuts (4volt)
    ? 3 way/2 way crossover
    ? Subwoofer phase selector
    ? Ai-NET
    ? IMPRINT Sound Calibration requires KTX-H100
    ACCESORIES
    KCE-422i
    Full Speed Connection Cable for iPod®
    Spoiler for Product Information KCE-422i: Show
    KCE-422i
    Now you can maximize your in-car iPod® experience! Just one simple cable that goes directly into the all Alpine Full Speed Connection for iPod® compatible head units. With no additional box required, directly connect your iPod® for full control, full sound at full speed with an easy-to-use search interface. You have control right from the head unit at full speed. Enhanced features include faster data transmission for quick and easy file navigation, as well as full-tag artist, album, song, genre, podcast, and composer information displayed directly on the head unit, all while charging the iPod® battery (available on the CDE-9870, CDE-9873, CDE-9881, CDA-9883, CDA-9885, CDA-9887, iDA-X001, IVA-D105, IVA-W205). Alpine's exclusive Percentage Search allow you to toggle quickly through your Playlist, Arist, or Album on your iPod®. Use "Mix All" to shuffle your music. Alpine Full Speed connectivity offers an improved integrated solution that supercharges your music!
    * The unit can be used with the following iPod® versions.
    Fourth generation iiPod®: Ver. 3.1.1
    Fifth generation iPod: Ver. 1.1.2
    iPod photo: Ver. 1.2.1
    iPod mini: Ver. 1.4.1
    iPod nano: Ver. 1.2
    * The unit cannot be used with software versions earlier than “2006- 06-28”. For details about “iPod® Software Update,” refer to the iPod Instruction Manual.
    Product available @ Cliport Car Audio
    For more information please contact our workshop
    Cliport Car Audio Division
    Adress : Jl. Sumbawa No 60 (BANDUNG)
    Office Number : (022) 73404522
    Rikky : 081221420030/08987872040
    BB PIN : 2303B068
    Customer Support@Cliport Car Audio
    YM : cliportaudio_cs
    Bintaro sektor 7
    1 Day 6 Hrs 24 Mins 11 Secs
    Smile
    Tolong PM harga cda 9887... makasih boz...
  1. FS : Jual Full Set Audio, Alpine (HU+PXA+RUX) dll
    By speed lovers in forum Head Unit & Processor
    Last Post: 10th November 2011, 06:43
  2. Replies: 22
    Last Post: 2nd January 2011, 11:05
  3. Replies: 13
    Last Post: 27th December 2010, 16:25
  4. WTA - Audio Rush HU Alpine
    By buncid in forum Diskusi Speaker
    Last Post: 16th July 2010, 00:58
  5. Settingan Audio utk HU Alpine
    By gremer in forum Diskusi Head Unit & Processor
    Last Post: 7th December 2007, 11:23
