http://www.sony-asia.com/productcategory/incar-entertainment
SONY XAV-60
2-Din WVGA 6.1" Touch-Screen AV Centre
Entertainment on tap
Transform your mobile music system with the XAV-60 motorized double DIN A/V Center. A vibrant 6.1" WVGA TFT touch screen display9 provides incredible picture quality and control, while USB 1-wire delivers full access to iPhoneŽ, iPodŽ, or other digital music players. The XAV-60 delivers 52 watts of peak power to all four speakers and EQ7 stage 2 lets you adjust the mix for a dynamic sound experience. Innovative features such as ZAPPIN™, SensMe™ and Passenger Control make is easy to access and control your entire music collection.
Spoiler for Features & Specifications SONY XAV-60: Show
Features&Specifications
Video
? Panel Type : TFT Active Matrix
? Picture Modes : Normal, Wide, Full and Zoom
? Resolution : 800 x 480
Capability
? CD : Yes (DVD/CD-R/RW)
Video Features
? Color System : PAL / NTSC / SECAM / M-PAL
? Display Technology : 6.1" TFT Active Matrix LCD Color Monitor
? Picture Mode : Normal, Wide, Full and Zoom
Tuner
? FM Usable Sensitivity : 10 dBf
? Frequency Response : FM: 20-15,000 Hz
? S/N Ratio : 70 dB (mono)
? Selectivity : 75 dB at 400 kHz
? Stereo Separation : 40 dB at 1 KHz
Display
? Aspect Ratio : 17:9
Weights and Measurements
? Dimensions (Approx.) : 178 x 100 x 173mm
? Weight (Approx.) : 2.2Kg
General
? Color : Black
? Disc Capacity : 1
Amplifier Section
? Max power output : 52 watts x 4 at 4 ohms
? Speaker Impedance : 4-8 Ohms
Convenience
? Tilt Range : 30°
Inputs and Outputs
? 12V Trigger Output(s) : Power antenna Amplifier turn on
? Antenna Terminal(s) : Aerial Input Terminal
? Audio In : Sony Bus audio/controll terminal
? Audio/Video Input(s) : AUX1 audio/video, AUX2 audio/video and rear camera with reverse input trigger
? Digital Audio Input(s) : -Ability to use all forms of USB devices may vary as not all devices are compatible. This unit can be connected to the following Apple products, update your device with the latest software before you use it. -iPod Nano 1st generation* -iPod Nano 2nd generation (aluminum) -iPod Nano 3rd generation (video) -iPod 5th generation (video)* -iPod Classic -iPod Touch -iPhone When you connect iPod Nano1st generation or iPod 5th generation, Passenger Control is not available. -This unit is compliant with MSC (Mass Storage Class) and MTP (Media Transfer Protocol) type USB devices compliant with the USB standard. -This unit cannot recognize USB devices via a USB hub. If you have any questions or problems concerning your unit that are not covered in this manual, consult your nearest Sony dealer.
? Infrared Port : Wireless remote
? Input(s) : USB, Sony BUS input, remote control terminal and parking brake input.
? RCA Audio Output(s) : Front, Rear, and Subwoofer RCA pre-amp outputs
? Remote Jack : Optional wired remote terminal
? USB Port(s) : Rear USB - Full Speed
Audio Features
? Level Control : Aux inputs: -8dB ~ +18dB
? Current Drain : 3 - 8 amps
? Input Power : 12 V DC car battery (negative ground (earth))
? Input Voltage : 12 V DC car battery (negative ground)
? Output Power : 52W x4 High Power - 17 watts per channel minimum continuous average power into 4 Ohms, 4 channels driven from 20 Hz to 20 kHz with no more than 5% total harmonic distortion.
Audio
? Band : AM / FM
? Digital-to-Analog Converter : 24bit
? Format(s) Supported : DVD, CD, CD-R / CD-RW (MP3/WMA/AAC/JPEG/MPEG-4 files)1
? Frequency Response : DVD / CD: 10-20,000 Hz
? Harmonic Distortion : DVD/CD Player: 0.01%
? Preout Impedance : 220 ohms
? Preout Voltage : 2 volt
? S/N Ratio : Audio Power: CEA2006 S/N 82 dBA
? Signal-to-Noise Ratio (dB) : DVD/CD Player: 120dB
? Station Preset(s) : 18 FM / 12 AM
? Tone Control(s) : EQ7: 7 band EQ
+/- 6 dB at: 63 Hz, 160 Hz, 400 Hz, 1 kHz, 2.5 kHz, 6.3 kHz and 16 kHz.
? Tuner Frequency Range : FM:Tuner Frequency Range(MHz): 87.5-107.9, MW:Tuner Frequency Range(kHz): 530-1710
? Tuner Type : SSIR-EXA
? Volume Control : Tel/Nav Attenuation Circuitry
? Wow and Flutter : Below measurable limit
Convenience Features
? CD Text Display : CD and MP3 / WMA data displayed
? Illumination : White Key Illumination
? On-Screen Clock : 12H
Spoiler for Video SONY XAV-60: Show
Video SONY XAV-70BT
BORKED
SONY XAV-60/XAV-70BT Key Features Intro
BORKED
SONY MEX-DV1600U
Slot-In LCD Display DVD/VCD/CD/MP3/AAC Player with Frontal USB, 1-Wire Technology for iPod and Walkman Connecivity and Direct Video Streaming
DVD/VCD/MP3 Player
DVD/CD/VCD/MP3 Player with FM Stereo, Quick-BrowZer and USB function.
Spoiler for Features & Specifications SONY MEX-DV1600U: Show
? 52W x 4
? Time Alignment
? Pre-Out x 3 (Front + Rear + Sub)
? Direct Video Streaming
? Video Out x 1(Rear)
? Video In x 1 (Mini Jack iPod only)
? Frontal Aux-In
? 1- Wire
- USB Direct Connection (Front)
- iPod Direct Connection
(requires RC-200IPV)
- Walkman Direct Connection
? Giga-Content Management
- List
- ZAPPIN
? Tuner
- Automatic Tuner
- FM18/AM12
- BTM (Best Tuning Memory)
SONY CDX-GT980UI
Motorised Flip-Out FL Display CD/MP3/WMA/AAC/ Player with Rear USB and 1-Wire Technology for iPod and Walkman Connectivity
iPod and USB Compatible In-Car Head Unit
MP3/WMA/AAC player with rear USB, iPod Control Feature, ZAPPIN™ and Quick-BrowZer.
For more than 60 years, Sony products have been created in accordance with an ambitious set of performance and design ideals to provide the most enjoyable experience possible.
Read about the specific technical highlights of this model here:
Spoiler for Features & Specifications SONY CDX-GT980UI: Show
General
? Pre Out Output Level (V) 4
? Pre Out Impedance (ohms) 220
? Maximum Output Power (4?, 1kHz) (W) 52
? Dimensions (W x H x D) 178 × 50 x 190mm
? Mounting Dimensions (W x H x D) 182 × 53 x 163mm
? Accessories RM–X176 Wireless Card Remote (Incl.)
Display Panel
? Display Device FL Dot
? Panel Finish Colour Black
? Key Illumination Blue / Red / Green
Tuner
? Preset FM18 / AM12
? FM: Tuning Range (MHz) 87.5-107.9, 87.5-108.0
? MW: Tuning Range (kHZ) 531-1602, 530-1710
? FM: Usable Sensitivity (75?) (dBf) 10
? FM: Intermediate Frequency (MHz) 150KHz
? FM: Selectivity (400kHz) (dB) 75
? FM: S/N Ratio (Mono) (dB) 70
? FM: Channel Separation (dB) 40
? FM: Frequency Response (Hz) 20-15k
CD Deck
? CD-Text Display / Scroll Yes
? Multi Session MP3 / WMA / AAC
? Frequency Response (Hz, dB) 10-20k, +/-1dB
? S/N Ratio (dB) 120
Ampilifier
? S-MOSFET Output Power 52W x 4
? D/A Converter 24 bit
? Pre Out x 2
? Sub Out Yes
? Aux-In Rear
? USB Rear
? Dynamic Soundstage Organiser 2 (DSO2) Yes
? EQ3 Parametric
? Bass Treble Low / Mid / High
? Repeat One, Album, Artist, Playlist, Genre, Podcast
? Shuffle Genre, Album, Artist, Playlist, All, Podcast
? Pause Yes
? Resume Play Yes
? CODEC (for iPod) MP3, AAC
? List Browsing (Folders / Files) Yes
? Passenger Control Yes
? ZAPPIN™ Yes
USB
? Repeat Off / Track / Folder
? Shuffle Off / Folder / Device
? Pause Yes
? Resume Play Yes
? CODEC (for USB) MP3, WMA, AAC
? List Browsing (Folders/Files) Yes
? ZAPPIN™ Yes
iPhone, iPod, iPod classic, iPod nano, and iPod touch are trademarks of Apple Inc., registered in the U.S. and other countries.
SONY CDX-GT690UI
Flip-Down LCD Display CD/MP3/WMA Player with Frontal USB and 1-Wire Technology for iPod and Walkman Connectivity
CD/MP3/WMA/AAC/Tuner player with front USB, iPod Control Feature,
ZAPPIN™, Quick-BrowZer and DM+ Advanced.
ZAPPIN™, Quick-BrowZer, DM+ Advanced
Front USB, iPod Control Feature
Frontal Aux-In
52W x 4
Pre-Out x 2
Spoiler for Features & Specifications SONY CDX-GT690UI: Show
General
? Pre Out Output Level (V) : 2
? Pre Out Impedance (ohms): 220
? Maximum Output Power (4?, 1kHz) (W) : 52
? Dimensions (W x H x D) : 178 × 50 × 182mm
? Mounting Dimensions (W x H x D) : 182 × 53 x 162mm
? Weight (kg) : Approx. 1.3 kg
? Accessories : RM–X151 Wireless Card Remote (Incl.)
Display Panel
? Display Device : LCD Display
? Panel Finish Colour : Dark Titanium
? Key Illumination : Blue / Green
Tuner
? Preset : FM18 / AM12
? FM: Tuning Range (MHz) : 87.5-107.9, 87.5-108.0
? MW: Tuning Range (kHZ) : 531-1602, 530-1710
? FM: Usable Sensitivity (75?) (dBf) : 10
? FM: Intermediate Frequency (MHz) : 150KHz
? FM: Selectivity (400kHz) (dB) : 75
? FM: S/N Ratio (Mono) (dB) : 70
? FM: Channel Separation (dB) : 40
? FM: Frequency Response (Hz) : 20-15k
CD Deck
? CD-Text Display / Scroll : Yes
? Multi Session : MP3 / WMA / AAC
? Frequency Response (Hz, dB): 10-20k, +/-1dB
? S/N Ratio (dB) : 120
Ampilifier
? S-MOSFET Output Power : 52W x 4
? Pre Out : x 2
? Sub Out : Yes
? Aux-In : Frontal Aux-In
? USB : Front
? Dynamic Soundstage Organiser 2 (DSO2): Yes
? EQ3 :Stage 2 (3-Band Equalizer / 7 Modes)
? Bass Treble : Low / Mid / High
? Repeat : Track, Album, Artist, Playlist, Genre, Podcast
? Shuffle : Genre, Album, Artist, Playlist, Device, Podcast
? Pause : Yes
? Resume Play : Yes
? CODEC (for iPod) : MP3, AAC
? List Browsing (Folders / Files) : Yes
? Passenger Control : Yes
? ZAPPIN™ : Yes
USB
? Repeat : Off / Track / Album
? Shuffle : Off / Album / Device
? Pause : Yes
? Resume Play : Yes
? CODEC (for USB) : MP3, WMA, AAC
? List Browsing (Folders/Files) : Yes
? ZAPPIN™ : Yes
SONY WX-GT78UI
Slot-In LCD Display CD/MP3/WMA/AAC Player with Frontal USB and Aux-In Connectivity
Spoiler for Features & Specifications SONY WX-GT78UI: Show
In Car CD Player
MP3/WMA/AAC player with front USB, iPod Control Feature, ZAPPIN™ and Quick-BrowZer.
* S-MOSFET Output Power: 52W x 4
* 24bit DAC
* Pre Out x 2
* Frontal Aux-In
* Preset FM18 / AM12
* EQ3 Stage2 (3-Band Equalizer/7 Modes)
SONY CDX-GT490US
In-Car CD/MP3/WMA/AAC/Tuner Player
Slot-In CD/MP3/WMA/AAC/Tuner player with front USB, ZAPPIN™, Quick-BrowZer and DM+ Advanced.
Front USB
Frontal Aux-In
52W x 4
Pre-Out: Front + Rear/Sub switchable
Spoiler for Features & Specifications SONY CDX-GT490US: Show
General
? Pre Out Impedance (ohms) : 220
? Dimensions (W x H x D) : 178 × 50 × 179mm
? Mounting Dimensions (W x H x D) : 182 × 53 × 162mm
? Weight (kg) : Approx. 1.2 kg
Display Panel
? Panel Type : Slot-In
? Panel Finish Colour : Silver
? Key Illumination : Red
Tuner
CD Deck
? Frequency Response (Hz, dB) : 10-20k, +/-1dB
Ampilifier
? Pre Out : Front + Rear/Sub switchable
? USB : Front
? EQ3 : Stage 2 (3-Band Equalizer / 7 Modes)
? Bass Treble: Low / Mid / High
USB
? Pause : Yes
? Resume Play : Yes
? ZAPPIN™ : Yes
SONY CDX-GT290S
Slot-In LCD Display CD/MP3/WMA/AAC Player with Frontal Aux-In Connectivity
In-Car CD/MP3/WMA/Tuner Player
Slot-in CD/MP3/WMA/Tuner player with Frontal Aux-In.
Frontal Aux-In
52W x 4
Pre-Out: Rear/Sub Switchable
Spoiler for Features & Specifications SONY CDX-GT290S: Show
General
Display Panel
Tuner
CD Deck
Ampilifier
? USB : Front
Product available @ Cliport Car Audio
For more information please contact our workshop
Cliport Car Audio Division
Adress : Jl. Sumbawa No 60 (BANDUNG)
Office Number : (022) 73404522
Mobile Phone : 081221420030/08987872040
BB PIN : 2303B068
Customer Support@Cliport Car Audio
YM : cliportaudio_cs
