wts nakamichi cd300.
Results 1 to 10 of 66
  • Short URL:  http://modifika.si/223465
    Jakarta Barat
    6 Mths 1 Wk 2 Days 12 Hrs 7 Mins 20 Secs
    sesuai judul bro mau coba jual nakamichi cd300
    * Manufacturer: Nakamichi America Corporation
    * Part number: CD-300
    * Description: Engineered for multi-format playability including CD, CD-R, CD-RW and MP3, and rich in features, the CD-300 is packed with all that you wish of a premium car stereo. From RDS technology to Nakamichi's signature Rotary Encoder, you'll find listening to your music a more rewarding experience.
    General
    * Product Type Radio / CD / MP3 player
    * Recommended Use Car
    * Form Factor Full-DIN - In-dash unit
    * Width 7 in
    * Depth 2 in
    * Height 6.1 in
    * Weight 3.7 lbs
    * Faceplate Type Detachable
    Audio System
    * Sound Output Mode Stereo
    * Max Output Power / Channel Qty 50 Watts x 4
    * Continuous Power / Channel Qty 30 Watts x 4
    * Built-in Display Fluorescent
    * CD Changer Control Yes
    * Clock Yes (digital)
    * Additional Features ID3 tags support
    Radio
    * Type Radio tuner - AM/FM
    * Tuner Frequency Range AM: 522 - 1620 kHz, FM: 87.5 - 108 MHz
    * Tuning Display Fluorescent display
    * Preset Station Qty 30
    * AM Preset Station Qty 12
    * FM Preset Station Qty 18
    * Signal-To-Noise Ratio 55 dB
    CD System
    * CD system type CD / MP3 player
    * CD system form factor In-dash unit
    * Media load type Slot-load
    * Digital audio standards supported MP3
    * CD system response bandwidth 20 - 20000 Hz
    * Signal-to-noise ratio 80 dB
    * CD system total harmonic distortion 0.3
    * CD system dynamic range 55 dB
    * CD-R compatible Yes
    * CD-RW compatible Yes
    beli dari baru dan kartu garansi masi kosong,blank (jadi headunit nakamichi dicover selama satu tahun ama distributor ya kan?kartu garansi gw masi blank jadi ibaratnya headunit gw masi NOS(new old stock deh)
    ga pernah ada masalah selama gw pake
    ga pernah skip
    ga pernah kena jalanan rusak trus ngehang
    motorized loading cd masi jalan lancar
    layar ga ada blank spot
    lampu nyala smua,detachable ga ada yg patah
    boks,manual book,dus sterofoam aja smuanya lengkap
    ga masalah bajakan atau asli
    kualitas suara nakamichi donkkk
    CUMANN:
    -baca cdnya rada kesendet sendet,bukan masalah cdnya ga bisa diplay mau cd yang mana kalau baru track 1 mah pasti nyala,cmn nanti udah pake misalnya 1 jam mulai keluar noise kayak kresek kresek
    gw udah tanya ada yg bilang optiknya kotor,cobain pake lens cleaner aja cmn gw ga mau ambil resiko kan lens cleaner buat dvd player ntar malah nyangkut kan ga lucu..hehehe,ada juga yang bilang headunitnya dibuka,lensanya kotor jadi dibersihiin(males aja buka segel,wkwkw),ada yg bilang lensanya diservis.
    apapun problemnya,bersihin lensa hu gw dibuka 100rb,servis maksimum 350 rb
    bisa lewat danumuri pake klaim garansi gw yg blank itu cmn gw males ngurusin garansinya musti kirim bon pembelian blah blah blah apa lah,trus kirim HU nya ke ciputat ribet banget menurut gw jadinya jual aja kayak bgini dah.
    gw jual santai,jual juga karena uda dapet HU baru yg ini nganggur,kalau misalnya ga kejual pun gapapa gw simpen aja sayang jualnya beli dari baru soalnya.wkwkwkkwk
    900rb NETT.OBO.
    NO LOWBALLERS,BID AND RUNNERS,SHOOTIN BLANKS.
    083892665075
    Jakarta Barat
    pertamax abis buat beli nakamichi.hahaha
    l AUTO BILD l JAKARTA
    4 Wks 1 Min 25 Secs
    barang bagus nih..hehe
    North sumatera,medan
    1 Mth 1 Wk 4 Days 11 Hrs 21 Mins 46 Secs
    Kasih 800 rb ga bos,lokasi medan.
    Jakarta Barat
    Sebenernya naikkin dikit sih jadi.cmn ga mau deh bro kirim kirim.takutnya pas nyampe di medan ga bisa nyala kan kasus bro..hehehee
    @jaccs:iya bro emang barang bagus.makanya jualnya juga males sebenernya.wuakakak
    Tq ya broo
    Jakarta Barat
    Appp yukkkkk
    tp slama saya transaksi di modcom soal pengiriman brg ga ada mslh bos,itu kalau packing rapi...naek 900 rb bos nyampe medan.
    Jakarta Barat
    Ya kalau packing rapi bos..gw blm perna kirim barang barang elektronik nih pake tiki,ga ngerti cara packing yg rapih lagian ribet bos..lagian ongkirnya aja uda brp duit bro hehe.
    Add bb pin gw aja bro buat ngobrol enaknya gimana nieh..hehehe
    pin:21175F67
    Jakarta Barat
    Aaaappp yukkkkkkkkkkkk
    Yg penting rapi bos,krn dus nya ada kan,jd tinggal masuk in jadi dech,paling byk ongkir nya 60 rb an bos,
  1. nakamichi CD45z dan CD300
    By mikel in forum Diskusi Head Unit & Processor
    Last Post: 7th September 2010, 09:39
  2. Nakamichi CD300
    By tsaichin in forum Head Unit & Processor
    Last Post: 24th August 2010, 12:14
  3. WTS Nakamichi CD300 2nd
    By Dat4D56 in forum Head Unit & Processor
    Last Post: 4th August 2010, 11:52
  4. WTS Nakamichi CD300 2nd
    Last Post: 4th August 2010, 11:44
  5. [WTS] Nakamichi cd300
    By freakmind in forum Head Unit & Processor
    Last Post: 25th May 2010, 23:28
