1 Pair of Image Dynamics IDQ31 EQ's kondisi muluus..(sold,thanks modcom...)
  • Short URL:  http://modifika.si/223062
    1 Pair of Image Dynamics IDQ31 EQ's kondisi muluus......sold
    Equalizer
    Bands 1 X 31 ISO Spacing from 20hz to 20khz
    Type Constant Q
    Accuracy 3% center frequency
    Range +/- 6db or +/- 12db switchable
    Inputs
    Type Active balanced or unbalanced
    Connectors XLR, 1/4 TRS, RCA
    Impedance 20k ohms balanced, 15k unbalanced
    Maximum level +22dbm (level control at center)
    Outputs
    Type Active balanced, unbalanced
    Impedance <150 ohms
    Power Requirements +12 volts, 1 Amp, negative ground
    Dimensions 1.75 high, 19 wide, 8.5 deep
    Weight 5 lbs.
    call
    081282357888
    3 Wks 1 Day 19 Hrs 30 Mins 47 Secs
    UP UP UP.....
    thanks yach bos andry.......
MBtech GT Radial
  1. Pair of A/D/S AS10 Legendary Subwofer kondisi muluus..............
    Last Post: 30th November 2011, 00:01
  2. FS : Image Dynamics CDPROMH NEW (Per Pair)
    By oliezt in forum Speaker - SubWoofer
    Last Post: 29th October 2011, 16:50
