Vox Amplifier Ting Ting abiss Murahhh!!!
Results 1 to 10 of 21
  • Short URL:  http://modifika.si/222304
    jakarta selatan
    3 Days 2 Hrs 6 Mins 55 Secs
    Power ga jadi pake punya nih jual murah aja dehhh lengkap dengan dus dan garansinya
    VOX AL4075
    Max Output 75w Rms x 4 CH
    Bridge power 185w Rms x 2CH
    THD < 0.15%
    Frequency Response 10Hz - 30Khz
    Signal to noise ratio >90dB
    Sensitivity 20mV-8V
    Dimensions 341mm x 245mm x 65mm
    cukup 975 RB aja Nett ya sudah murah bgt nihh
    For further information please contact
    Mike 0817 917 3357
    1 Day 7 Hrs 49 Mins 42 Secs
    800 bos boleh g?
    jakarta selatan
    Brio3
    The third generation of Brio the Brio 3 now boasts a modified power supply and up-rated power transformer.
    The increased power output (49 watts per channel into 8W) of the Brio 3 greatly improves control and musical performance over its predecessor.
    Rather than having unnecessary gadgets and frills usually found on products in this price range, the Brio 3 utilises the highest quality components to achieve the best sonic performance.
    The output amplifier is built around a pair of Sanken 150w Darlington output transistors and an electronic circuit protects against shorted speakers and reactive loads of 1.7W or less.
    The power supply uses the new generously rated toroidal transformer and 10,000F smoothing capacitors that provide enough current to drive the hardest of loads.
    If excellent sound quality and affordable price is your priority then the Brio 3 may be the ideal amplifier for you.
    Features
    * 49w RMS per channel into 8ohm
    * 5 inputs: Phono, CD, Tuner, Line1 & Tape
    * Rega custom built extruded aluminium case
    * Rega Planar IC phono input
    * Toroidal mains transformer
    * Sanken 150w output transistors
    Review
    http://www.stereophile.com/integrate...3_2717crx.aspx
    http://www.positive-feedback.com/Issue28/rega_brio.htm
    http://www.avguide.com/review/rega-b...ollo-cd-player
    Spoiler for Rega Brio3: Show
    By jlu_mike at 2010-08-19
    Cukup 3.3 juta NETT!!
    Hub Mike 0817 917 3357
    jakarta selatan
    PROFESSIONAL GRADE INSTALLATION KITS FOR EXCEPTIONAL VALUE(3Meter)
    FT” SERIES HIGH VALUE SIGNAL CABLES
    • HIGHLY TRANSPARENT clear outer jacket for enhanced cosmetics
    • BALANCED twisted pair, silver finished conductors enhance noise rejection
    • NICKEL PLATED connectors with split tip for enhanced performance and reliability
    • RIGHT ANGLE CONNECTOR on one end to aid in tough installations
    • TUG-PROOF sealed internal connection for maximum reliability
    • MOLDED Y BLOCK for protection of the conductors in critical split point
    • “PROFESSIONAL GRADE” performance
    Only 229000 Idr Limited Stock, only 2 Pcs!!!(3 Meter)
    http://www.connectionaudison.com
    For Further Information Please Contact
    Mike 0817 917 3357
    jakarta selatan
    upppppppppppppppppppppppppppppppppppp
    jakarta selatan
    upppppppppppppppppppppppppppppppppppppppp
    3 Hrs 51 Mins 48 Secs
    Quote Originally Posted by jlu_mike View Post
    boss.. nawar boleh ?? 600rb dech.. lokasi dimana ??
    TANGERANG
    5 Days 5 Hrs 59 Mins 19 Secs
    Murah banget gan
    jakarta selatan
    Quote Originally Posted by ardhiet View Post
    lokasi pondok bambu jkt timur hrga uad nett bos
    Quote Originally Posted by Blue-X View Post
    Murah banget gan
    sikat gan
    jakarta selatan
MBtech GT Radial
  1. For SALE: Head City type Z 2002 standard ting ting....
    By trinity13 in forum Jual Beli Mesin Lainnya
    Last Post: 8th September 2012, 20:37
  2. jual cylinder head std honda estilo genio non vtec (ting..ting)
    By andremix7 in forum Jual Beli Mesin Lainnya
    Last Post: 18th August 2012, 10:57
  3. Replies: 13
    Last Post: 31st March 2011, 20:33
  4. FS: head standar ferio (P2J) masih perawan ting-ting
    By dJoe in forum Jual Beli Mesin Lainnya
    Last Post: 15th December 2010, 03:00
  5. MERCY 300E'90 automatic TING TING..new pict
    By alhuda in forum Merk Lainnya
    Last Post: 2nd April 2010, 14:37
