WTS: Best amp from Soundstream: Soundstream Human Reign Crypt 2 channel 2x450 wrms
Results 1 to 10 of 34
  • Short URL:  http://modifika.si/221941
    1 Wk 2 Days 3 Hrs 17 Mins 28 Secs
    Bantuin teman jual car amp yang merupakan Best Amp from Soundstream:
    Soundstream Human Reign Crypt 2 channel. Hand crafted in the USA.
    Price 10 jt nego.
    No low-ballers please.
    Telp. langsung dg yang punya: 021-92733432.
    Lokasi Jatinegara Jakarta Timur.
    Foto penampakan diambil dari internet. Untuk keterangan lebih lanjut mengenai kondisi mohon hubungi no. telp di atas.
    Penampakan:
    http://img837.imageshack.us/img837/5397/ampshr.jpg
    Description: Soundstream Human Reign Crypt 2 2 Ch Amplifier
    1600 Watt 2 Channel Amplifier
    The Beast is changing. It's not changing heart or mind, but it want to look just a tad more appealing. The changes done to the New Human Reign Crypt are all cosmetic or beneficial. We've moved to a very sleek and stylish heat sink with discrete mount terminals and easy to reach controls on the top side of the amp. A lacquer black finish on the surface and a chrome plated tub make the new style stand out as always but with a more modern look. For improvements, we've added a balanced line input to use with optional BLT- 4 and the frequency counting features included with the unit. There are three units to complete the family of crypts, HR Crypt 2, HR Crypt 4 and HR Crypt 5. The new addition of the HR Crypt 5 will be all you need for smaller system but still gain the advantage of awesome quality the amps are known for.
    Human Reign Features
    Pure Class A circuitry
    Fully regulated MOSFET power supply
    RUBI (Rapid-Use Branched Impulse) Proprietary power supply topology
    STACT (STabilized Apex Current Topology) Reduces power supply stress by 50%
    Auto High Current Matches the amplifier for virtually every load application
    Chassi-sink Semiconductors are situated between the circuit board and heat sink for optimal thermal transfer
    Ultra-Low ESR Capacitance Bank ensures rapid power delivery for dynamic peaks
    Triple Darlington output circuitry
    Hawkins Bass Control Proprietary bass equalization topology
    Harmonic Bass Alignment Produces tighter and more accurate bass
    IDI (Intelligent Distress Indicator) Gives visual indication of amplifier protection status
    Bi-Linear built-in selectable 2-way crossovers for amplifier and line output
    4-Way protection topology - Thermal, DC Offset, Speaker
    Short and Reverse Polarity
    Selectable Balanced line inputs for highest level of noise rejection
    Specifications
    Output Power: 4 ohm: 450 x 2, 2 ohm: 800 x 2
    Bridged: 4 ohm1600 x 1
    THD:<0.02%
    S/N Ratio>90dB
    Damping>500
    Freq. Resp.20-20KHz
    Input Sens..15-5V
    Crossover LPF 24dB:40-160Hz
    Ch 1&2 HPF 12dB:50-500Hz
    Ch 3&4 HPF 12dBN/A
    Ch 5 LPF 24dB:N/A
    Hawkins in Subsonic:13-30Hz
    Hawkins On Position:30-70Hz
    Variable Bass Bosst:0-9dB
    Magazine Review:
    “Auto hifi, Germany’s premier autosound magazine had this to say about the Human Reign amplifiers…
    The American amplifier blacksmiths, Soundstream, have created a monster to stir up the world with their 2 channel amplifier. The Americans have a top-of-the-line amplifier that has gone into the class of excellence.
    They let William Boddy hand design the heatsink – a solid chunk of aluminum with a bronzed finish.
    All the engineering efforts showed well in the laboratory. A signal-to-noise ration of 99dB and a damping factor of 1800 in the bass region are two of the amplifier’s best features. A distortion factor of 0.005% takes second place to nobody.
    According to the laboratory results, impressing in every aspect, we congratulate the amplifier on being in the Reference Class!”
    Link ke test result:
    http://www.audiodesign.de/soundstream/index.htm
    Klik HUMAN REIGN amplifiers. Di halaman ini juga ada test result dalam bentuk pdf file.
    1 Day 19 Hrs 55 Mins 52 Secs
    Mantapppp... Bantu up
    klaten
    Quote Originally Posted by a_ghost View Post
    bantu beli aja bos..buat drive Supremo nya. Wkwkwkwk..btw, jdne pake power apaan neh?
    5 Days 8 Hrs 47 Mins 5 Secs
    mantepssssss
    Thanks bro...
    Boleh banget tuh buat drive Supremo.
    Thanks bro...
    Quote Originally Posted by frostbitez View Post
    mantepssssss
    Halo bro frostbites, thanks ya...
    JAKARTA
    1 Mth 3 Wks 3 Days 15 Hrs 49 Mins 9 Secs
    Bantu sondol buat racun timur dahhhhh..
    @ bro danny: Msh pake PPI promos tuh...menurut installerku sih cukup utk drive supremo tweetnya, dan udah aku test hasilnya wuenakkkkk kl buat kupingku sih, maklum msh nubie :p
    samarinda 0812 548 5788
    1 Day 11 Hrs 8 Mins 15 Secs
    Bisa tt gak bro?
    Quote Originally Posted by mr.nice View Post
    Tenk'u bro, audio gw mah cupu timur...
    Gak brani maen tabung bro, takut meledak, sanggup nya solid state dowang, paling juga korslet...
    Quote Originally Posted by TJ_TJ View Post
    Bisa tt gak bro?
    Bisa langsung telp/sms aja yang punya bro...
GT Radial NGK Busi
  1. [WTS] SOUNDSTREAM SA-164 4 CHANNEL (2ND)
    By dimsaudio in forum Power Amplifier
    Last Post: 26th April 2012, 14:11
  2. Soundstream Human Reign
    By Modic in forum Diskusi Power Amplifier
    Last Post: 21st June 2011, 20:04
  3. Replies: 13
    Last Post: 12th May 2011, 18:40
  4. (wts) soundstream human reign 4 channel
    By tekokak in forum Diskusi Power Amplifier
    Last Post: 6th January 2011, 14:11
  5. WTS Soundstream Human Reigh
    By kowloonaudio in forum Power Amplifier
    Last Post: 9th October 2009, 01:21
