NORDOST Blue Heaven Interconnect (60cm,100cm dan 200cm)
Results 1 to 6 of 6
  • Short URL:  http://modifika.si/221410
    Smile NORDOST Blue Heaven Interconnect (60cm,100cm dan 200cm)
    NORDOST Blue Heaven Interconnect w/ NEUTRIK PROFI Connector (FACTORY TERMINATED).......
    Made in USA
    Length that available :
    60 cm (1 pair)
    100 cm (1 pair)
    200 cm (2 pairs)
    Blue Heaven Interconnect consists of thirty separate 99.99999% OFC conductors, plated with silver in a flat array micro-litz construction. Blue Heaven interconnects reveal the depth, beauty and intimacy of music. Subtle and refined, yet detailed, they bring a new sense of realism to recorded music.
    Blue Heaven interconnects are terminated with Nordost''s MoonGlo RCA phono-plugs. The connector is made from hard, gold-plated brass for exceptional corrosion resistance and utilizes FEP for its internal insulation. This plug uses a spring loaded collar which makes the ground connection before the signal, preventing damage to your loudspeakers should the amplifier be left on inadvertently when unplugging or plugging in your cables.
    "Music is well ordered and involving. Blue Heaven thrives on dynamic bass power and presents the sound of instruments with a natural clarity. It isn’t cheap, but in a high quality system, the rewards outweigh the expense."
    Hi-Fi Sound and Vision
    "If you are planning to purchase cables in, or anywhere near this price range (up as well as down) Nordost Blue Heaven is strongly recommended for audition."
    Dave Davies, Hi Fi+ Issue 6
    SPECIFICATIONS
    INSULATION: Extruded FEP
    CONDUCTOR: 30 x round micro-litz
    MATERIAL: 50 microns silver plated 99.99999% OFC
    CAPACITANCE: 8.1pF/ft
    INDUCTANCE: 0.14uH/ft
    PROPAGATION DELAY: 93% speed of light
    Price List of Nordost Blue Heaven Interconnect :
    60 cm $204.00
    100 cm $229.00
    200 cm $354.00
    CALL
    081388575788
    2 Wks 5 Days 1 Hr 5 Mins 45 Secs
    makin ganazzz aja kabelnya,,,
    mantapzzz,,,
    Hahaha,bisa aja nich bos rudy...
    Thanks yach bos...
    3 Wks 3 Days 21 Hrs 49 Mins 57 Secs
    up buat kabel nordost nya...
    1 Day 3 Hrs 27 Mins 31 Secs
    Boss, boleh tolong di PM harga cable yg 1M and 2M
    thanks yach bro....
    pm sent bos ole,thanks........
  1. [WTS] kabel digital interconnect shaman by nordost
    By nsr150 in forum Cables & Interconnects
    Last Post: 12th April 2013, 03:12
  2. NORDOST BLUE HEAVEN 1M PAIR KONDISI SANGAT BAGUS
    By studio-xx in forum Cables & Interconnects
    Last Post: 27th September 2012, 11:56
  3. [WTS] Nordost Blue Heaven Rev II speaker cable
    By vickyz in forum Cables & Interconnects
    Last Post: 25th August 2011, 04:32
  4. Dijual Nordost Spekaer Kabel dan Interconnect
    By arie77 in forum Cables & Interconnects
    Last Post: 23rd June 2010, 13:16
  5. FS : Tabung kapsul SCOTT M5500 60cm 150rb..SOLD
    Last Post: 8th December 2009, 09:27
