C2K-2.0X - Zapco Competition 2 Ch. 400 Watt Amplifier kondisi muluuuus,lgkp dus buku
  • Short URL:  http://modifika.si/220925
    Thumbs up C2K-2.0X - Zapco Competition 2 Ch. 400 Watt Amplifier kondisi muluuuus,lgkp dus buku
    C2K-2.0X - Zapco Competition 2 Ch. 400 Watt Amplifier kondisi muluuuus,lgkp dus buku n symbilink......2,9jt
    NEW PRICE : US$ 841.99
    Stereo, 4 ohms: 2x50 Watts
    Stereo, 2 ohms: 2x100 Watts
    Stereo, 1 ohms: 2x200 Watts
    Bridged, 4 ohms: 1x200 Watts
    Bridged, 2 ohms: 1x400 Watts
    T.H.D. + Noise: <0.02%
    Frequency Response: 20Hz - 20kHz; +0 dB/-0.35 dB
    S/N Ratio: >100dB
    Transient Distortion: <0.01%
    Slew Rate: >26V/uS
    Damping Factor: >900
    Input Sensitivity: 1-4 Volts or 4-16 Volts
    Dimensions: 13.5"L x 8.75"W x 2.375"H
    -Chassis design allows infinite customization options by replacing slide-in trim panels to personalize any installation
    -SymbiLink¬トᄁ Balanced Technology provides up to 16 volts
    of balanced input for the cleanest, quietest signal possible
    -Pre-clip and output clip indicators to maximize performance settings
    -Symmetrical, discrete power amplifier circuitry
    -Fuse, short circuit, high temperature, DC offset, and over voltage protection
    -Dual color LED for power and protection indications
    -25-amp High Current Bi-Polar output devices
    -50-amp MOSFET switching devices
    -Optically isolated power supply
    -Gate Drive Boost maximizes power supply efficiency and improves overall performance
    -Very high damping for excellent speaker control
    -Surface Mount Technology w/1% resistors,
    precision capacitors, and massive ground planes
    -High Current design allows 2 ohm mono loads for
    use as a bass amp with low Z woofer systems
    -Four layer PC board with heavy 2 oz copper
    -Variable electronic crossovers (Input & Aux Out)
    -Pass-through output
    -Sub-sonic filter for speaker protection
    -Switch for use as stereo, single L ch. or R ch. bridge
    -L+R sum mono for use as a bass amp
    -Dual cooling fans allow any mounting position
    call
    081388575788
    klaten
    mantaff bos Chris...
    thanks yach bos danny..........
    up................
GT Radial NGK Busi
  1. Replies: 11
    Last Post: 1st October 2010, 07:49
  2. Replies: 17
    Last Post: 14th March 2010, 00:33
