soooooooold
Unit only n remote original,mulus no hard scratch,no repaint
foto dr googling,
Keunggulan seri top Hk ini ,bisa main Thx
bbrpa review yg bisa dipertanggung jawabkan :
http://www.audioreview.com/mfr/harma...2_2718crx.aspx
http://www.hometheatermag.com/receivers/150/
This review is from: Harman Kardon AVR8000 Audio/Video Receiver (Electronics)
This was the last of HKs truly high quality recievers. It just takes a quick look to see the amazing quality put into this powerhouse. ALL GOLD plated connections, torodial transformer the size of your head, almost 70 lbs!! THX ultra certification. Ultra clean power: 0.07% THD at full rated power 110w/ch with an inaudble distortion rate of 3% at over 270watts/ch all five channels driven...hard - due to its high current design. Basically, your speakers will either blow up or you will damage them severely before you hear distrotion from this reciever. Help other customers find the most helpful reviews
Was this review helpful to you?
All I can say is this amp sounds better than every other amp I have owned. It is powerfull, it can be turned way up and still sounds good. It is heavy and that means one thing, transformer. If you have an amp that is advertised at 120 watts per channel, like my old Pioneer, and it weighs about 16 pounds, it is no matter what going to produce clean power. The transformer in this HK is 35 pounds of its weight alone. If you can find on of these old gems, grab it.
SUmber nya:
http://www.amazon.com/Harman-Kardon-...owViewpoints=1
SPec global:
Formats supported: Dolby Digital 5.1; THX Surround EX; DTS 5.1; DTS ES Matrix and Discrete; DTS Neo:6; Dolby Pro-Logic; Dolby Pro-Logic II; THX Ultra processing; Logic 7
Connections: Inputs - eight line audio inputs; eight digital - five optical, four electrical; three component video (assignable); eight-channel audio inputs; pre-main centre & front effects inputs. Outputs - four A/V (composite, S-video, audio) & two audio only; two optical digital; two electrical digital; component video; preamp outputs for all channels; RS232C
Features: THX Ultra receiver rated at 5 x 110W per channel; 20Hz-20kHz hms, 0.07% THD; MP3 & HDCD decoders; EzSet auto level set; Tuner with 30 presets; coded programmable backlit remote with second handset for Zone 2
Dimensions: 440(w) x 196(h) x 519(d) mm
Weight: 24.1kg
"Harmon Kardon AVR-8500" Specifications
Audio Inputs 10 The number of audio input points the Home Cinema Receiver possesses.
Brand Harmon Kardon The manufacturer of the Home Cinema Receiver
Model AVR-8500 The individual model name and number of the Home Cinema Receiver
Power Output (per channel) [COLOR="rgb(255, 140, 0)"]110 Watts[/COLOR] The volume of sound, in Watts, generated by the Home Cinema Receiver.
Surround Formats Dolby Digital, Dolby Pro-Logic II, DTS, THX The sound package which is substantiated by this system.
S-Video Compatabilty Yes A lead which transmits video and sound signals and ensures connectivity with other appliances.
Video Inputs 13 The total amount of input facilities this Home Cinema Receiver possesses.
Spoiler for testi: Show
Quote Originally Posted by irwantoro View Post
Kemaren ambil 1 set nih sama boss ini.
Barang nya keren, kualitas yahud. Ga salah pilih Marantz deh....
Recommended Seller !!! :thumbup::thumbup::thumbup:
Makasih bos buat jemput-antar dari/ke Tol nya ya....
Quote Originally Posted by kang_kasep_tea View Post
moRning gan . . . TSS-750 nya dah dicoba neh ..... tengkyu gan . . .
walau barang 2nd tp suara masi bole dah, lecet2 . . . namanya 2nd, btw tengkyu bonus stand nya sayang cmn 1 pasang coba klo dua pasang . . . mantap tuh, heheh....
tinggal nyari wall-mount nya euy . . . blum dapet neh,ada yg jual g ?? hehe . . .
RECOMENDED SELLER AGAN YG SATU INI !!!! TENGKYU GAN . . .
Quote Originally Posted by murc View Post
barangnya mantap surantap semua nih... ga nahannn... NAbung yang giat ahhhh... :ngacir:
Quote Originally Posted by Mille Petrozza View Post
Mendingan beli paket,pasti dapet bonus dari bos ini,gue beli Receiver JBL dapet bonus DVD Player,asik ngga tuh? cuma syaratnya musti tunggu bulan 2,baru bonus dikeluarin.
:ilovekaskus:ilovekaskus
Quote Originally Posted by obhnusantara View Post
Bantu up buat si boss, ayo buat yg pengen bikin ht dirumah dengan budget dibawah 10jt sikat saja :maho
Quote Originally Posted by michaelghost View Post
Gileeeeee barangnya mantap2 dan murah
Quote Originally Posted by biliie13 View Post
wah siboos ganteng
laris manis yah boss
btw pernah beli ama boss ini
pelayanannya cakep
fast delevery
orangnya juga ganteng
hehehehe
Quote Originally Posted by yudineng View Post
udah saya nya ngaret tapi tetep sabar nunggu
barang bagus banget kaya baru, btw koleksinya serem serem euuyy alias keren keren
:recsel:recsel:recsel:recsel:recsel:recsel
Quote Originally Posted by k123456789 View Post
Consonance sdh kuterima n kucoba....
Barang mulus tak ada lecet sama sekali...peli peli gut punya deh....
Utk kualitas suaranya jg bener2 bening....blom pernah dgr suara sejernih ini pdhl pake receiver denon yg plg murah hehehe
Yah sy dptkan sesuai dgn omongan si agan.....puas deh pokoknya.....
:recsel:recsel
Langsung aja call kalo minat gan,,,,,,sapa cepat dapat ya...
