#PORTFOLIO# Honda Civic Estilo K24 Swap..! 308 HP
Results 1 to 10 of 62
  • Short URL:  http://modifika.si/219559
    1 Wk 3 Days 2 Hrs 57 Mins 1 Sec
    HONDA CIVIC ESTILO 1994 K24A4 Block with K20 Head
    Before :
    Performance Parts & Swap Parts List :
    - K24A4 Short Block
    - K20A2 PRB-1 Cylinder Head
    - 6 Speed Manual Transmission K24 4.3 Final Gear
    - de Auto Motorsport Signature Porting-Polished with 3-Angle Valve Job & Valve Seat Modification
    - INNOVATIVE MOUNTS Swap Mounting Kit 85A
    - HASPORT Axles Swap Kit Level 1
    - BLUEPRINT RACING I-Beam Connecting Rods
    - WISECO Forged Piston Kit Bore 89mm & Compression Ratio 13.7:1
    - ACL Race Series Main & Rod Bearings
    - ERL PERFORMANCE Honda S2000 Modified Oil Pump
    - SUPERTECH Engine Block Guard K24
    - ARP Head Stud Kit
    - COMETIC Head Gasket 0.030" Bore 89mm
    - SUPERTECH Stainless Valves Flat Face & Standard Size
    - SUPERTECH Valve Seals (Viton & Polyacrylic)
    - BISIMOTO Intake Manifold Heat Shield
    - HONDA RRC Intake Manifold Reamered & Match Ported
    - SUPER90 Aluminum Big Bore Throttle Body 74mm
    - CUSTOM Aluminum Suction Pipe
    - VIBRANT Matte Black Silicone Hump Hose 3,00 Inch
    - VIBRANT Aluminum Bellmouth Velocity Stack with 6,00 Inch Filter
    - K&N Cylinder Head Breather Filter 12mm
    - VIBRANT Silicone Vacuum Hose 8mm
    - VIBRANT Silicone Vacuum Hose 10mm
    - P2R Vacuum Manifold Block
    - K-TUNED Adjustable Idle Pulley
    - HYBRID RACING Timing Chain Tensioner
    - WALBRO In-Line Fuel Pump 255L/H
    - AEM Universal Fuel Pressure Regulator
    - EDELBROCK In-Line Fuel Filter 40 Micron
    - JR PROJECT Big Bore Fuel Rail Kit
    - JR PROJECT Aluminum Fuel Tank 40 Liter
    - INJECTOR DYNAMICS Fuel Injector 725cc
    - K-TUNED Swivel & Fittings
    - K-TUNED Fuel Braided Hose
    - NGK Iriway 8 Spark Plug
    - K-TUNED Aluminum Radiator Swap Kit
    - K-TUNED Silicone Radiator Hose Swap Kit
    - ARK DESIGN Water Temperature Sender
    - SKUNK2 Radiator Cap 1.3 Bar
    - MISHIMOTO Low Temp Radiator Fan Switch
    - JR PROJECT Oil Cooler Kit 10 Row - Blue
    - GREDDY Magnetic Oil Drain Bolts
    - EXEDY Hyper Single Series Clutch Kit with Flywheel
    - ARP Flywheel Bolts
    - K-TUNED Race Spec Shifter Cable & Bracket
    - BUDDYCLUB Shifter Box 6-Speed
    - ENERGY SUSPENSION Master Set PU Bushing
    - KSPORT Rear Lower Control Arm
    - KSPORT Custom Spec Drag Race Coilover Kit for K24 on Civic EG
    - BREMBO Max Brake Disc
    - BREMBO Brake Pad Front & Rear
    - PRO RS Brake Line Kit
    - ARK DESIGN Carbon Steel Racing Nut - Short
    - MR. GASKET Battery Relocation Kit
    - ORD Custom Race 4-1 Stainless Header
    - CUSTOM Stainless Exhaust Pipe 2,50 Inch
    - VIBRANT Bottle Style Center Resonator 2,50 Inch
    - DC SPORTS Universal Muffler 3,00 Inch
    - STRI DSD Water Temperature Gauge 60mm Smoke Lens
    - STRI DSD Oil Temperature Gauge 60mm Smoke Lens
    - STRI DSD System Oil Pressure Gauge 60mm Smoke Lens
    - PIVOT Gekko Tachometer 10k RPM
    - HALTECH Platinum Series 1000
    Wiseco Piston & Blueprint Racing ConRod ready to installed
    Block with Wiseco 89mm Bore & 13.7:1 Compression
    Comparison of OEM Valves (Left Side) & Supertech Flat Face Valves (Right Side)
    3 Angled Valve Job Cylinder Head, Ported & Polished with Supertech STD Size - Flat Face Valves
    Reamed & Match Ported HONDA RRC Intake Manifold, Adapter with Super90 74mm Bore
    Got the RRC Intake Manifold, K-Tuned RRC Adapter & Super90 74mm Reamerd & Port Matched, Polishing is next..
    Block Parts Installed, now Clearance Check on the Piston Valve Pocket, Valve Spring Clearance at Maximum Lift, etc
    All set, assemble the K24 Block with K20 Head
    Got the K24/K20 engine installed in Civic EG with Innovative Mounting Swap Kit
    Repaint Process Done with Yellow S2K Color
    Exedy Hyper Single Clutch Kit 6-Puck Installation
    Get the Engine Back in the Newly Painted Civic EG with K-Tuned Radiator Swap Kit, Bisimoto Intake Head Shield Gasket, etc
    Engine Wiring Setup & Installation
    Engine Bay
    Dyno Tune @RS Tuning
    POWER = 308,1 HP @8000 RPM
    TORQUE = 305.4 Nm @7000 RPM
    Dyno Tuning Report Sheet Power & Torque
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    2 Mths 4 Wks 18 Hrs 50 Mins 31 Secs
    seremmmm euy ES tilonya om badri....... hehehe
    BJAmodified Bandung
    6 Days 18 Hrs 39 Mins 17 Secs
    Total abis brp tuh yah?
    Quote Originally Posted by RETROtuning View Post
    blm itung total nya bos.. hehehe
    CP : Coki Siboro
    Quote Originally Posted by moibotz View Post
    masih lebih serem muka nya di badri kali dim...!
    CP : Coki Siboro
    BJAmodified Bandung
    update dong bos
    update dong bos
    sabar ya bos.. hehehe
    CP : Coki Siboro
    BJAmodified Bandung
    He2 penasaran
    He2 penasaran
    kalo ini sih kerjaan lama sih.. jadi pasti panjang bener jalan nya..
    CP : Coki Siboro
  11. 20th February 2011, 11:25
    Reason
    spam
  12. #10
    SYD-AUS
    3 Wks 5 Days 4 Hrs 36 Mins 42 Secs
    udah kelar nih cok??
Venom 300x250 GT Radial
  1. Replies: 198
    Last Post: 18th April 2014, 13:49
  2. #PORTFOLIO# Honda Civic Estilo D16 SOHC VTEC 216HP
    By coki.de auto in forum de Auto Motorsport
    Last Post: 27th February 2013, 18:07
