(PILIH) speaker split u/ SPL disini
Results 1 to 10 of 56
  • Short URL:  http://modifika.si/219177
    SESUAI judul pilih om Speaker SPLIT yang setau ane ini harganya Range 700rb-1jt
    YANG lumayan lah BUAT SPL yang mana gan, kalo yang bagus 5jt ++
    disini LOW BUDGET, mungkin HIGH budget juga bisa bantu
    1. VENOM - VX 6 DIABLO
    SPEK >> Model : Venom - VX 6Diablo ▪ DIMENSION 6inch WATTS/RMS/MAX 100/150 FREQUENCY RESPONSE 40-10K 25mm SILK DOME TWEETER No POLY KEVLAR CONE RUBBER EDGE 165mm
    2. FUSION - EN CMST1
    SPEK >> Model : Fusion - EN CMST1 ▪ Component Speaker System Set ▪ 6.5"/4"/1" Tweeter ▪ 240Watts ▪ Solid basket chassis protected and detailed in chrome. Stunning sound, stunning looks ▪ Designed for efficiency in sound delivery, featureing a highly charged motor assembly ▪ The encounter tweeter housing diffracts high frequency sound, expanding the sound stage ▪ Incorporating PCB tweeter protection to safeguard your tweeter from unwanted signal clipping
    3. VISONIK - V650XTC
    SPEK >> Model : V650 XTC ▪ 200W RMS ~ 400W Max. ▪ Woofer Specifications :Sensitivity : 93dB @ 1w/1m ▪ Frequency Response : 30Hz - 2kHz ▪ Mounting Depth : 2.75" ▪ Tweeter Specifications : Sensitivity : 92dB 1w / 1m ▪ Frequency Response : 2kHz - 22kHz ▪ Neodymium Magnet Structure ▪ Surface / Flush / Angle
    4. MOHAWK MH - 6.2
    SPEK >> Model : MH - 6.2 ▪ Woofer (in, mm) : 6,5" / 166 ▪ Tweeter (in, mm) : 1.0" / 25 ▪ Max Rec Amp Power (watts PEAK / RMS) : 200 / 100 ▪ Sensitivity (dB 1w / 1m) : 90 +- 2dB ▪ Frequency Response (Hz) : 60 - 20K ▪ Mounting Hole Diameter (in, mm) : 5 5/8" / 143 ▪ Woofer Mounting Depth (in, mm) : 2 3/4" / 70 ▪ Crossover Point (Hz) : 4000 ▪ Crossover Slope (dB / Octave) : 12Hi / 12 Lo ▪ Grilles : Yes
    KALO BOLEH PILIHIN OM, LUMAYAN BUAT JEDAH JEDUG.
    =THX MODCOM=
    :rolleyes:
    UUUUUP UUUUUP
    3 Days 1 Hr 59 Mins 1 Sec
    Btw it harga nya smpe 1jt ya?
    trus mesti buat box nya ?ato cmn split doank bos?hehe tq
    Quote Originally Posted by Daric View Post
    wah ane ngga jualan om, ane juga mau beli, jadi sekalian mau tanya ke mocomers yg cocok buat SPL tuh diantara 4 diatas yang mana?
    ya ane tau sih itu harga barangnya diatas kisara 700-1jt om hehe
    Quote Originally Posted by yusufsinulingga View Post
    Ia om,tuh speaker split doank ya/
    ane tny dl,bru bs kasi saran ehehe
    Ga speaker aja om, itu ada penjelasan dibwh pict, ada tweeter croosover sm speakernya cmiiw
    menurut ane sih ,enak ambil venom ato mohawk aj om,klo harga nya ga selisih jauh gtu kan,ahaha
    btw mw ambil dmn bro ?
    Oh ane sih liat di audiomobil venom yg itu harganya 650rb, mohawk 750rb. Kalo diliat dr spek bagus mana ya
    kurang jelas spek nya bro,
    cba minta web nya deh,masa Venom dkit,mohawk banyak bner,eehehe
    6 Days 3 Mins 2 Secs
    venom aja bro...
  1. Replies: 9
    Last Post: 27th June 2012, 07:34
  2. Speaker JBL 2 way 4", Split ADX, Speaker Oval ALTEC
    By vedi_97 in forum Speaker - SubWoofer
    Last Post: 14th June 2011, 20:22
  3. Replies: 9
    Last Post: 12th July 2010, 16:21
  4. Replies: 131
    Last Post: 1st April 2010, 07:43
  5. Replies: 8
    Last Post: 23rd December 2009, 08:59
