- H.P - Liqui Moly Diesel Purge
Results 1 to 10 of 55
  • Short URL:  http://modifika.si/218225
    Phone: 08179845168 - Klender Jakarta
    4 Days 23 Hrs 46 Mins 8 Secs
    LIQUI MOLY DIESEL PURGE
    Removes deposits on injection nozzles and in the combustion chamber. Increases the cetane rating. Eliminates engine operationproblems such as knocking in idle and provides round and quiet engine running. Protects the entire fuel system from corrosion. Optimizex the emission test values. Can also be used as a preventative measure. Clean engines need less fuel and reduce emissions.
    Area of use
    For all diesel engines both with and without diesel particulate filters. Preventative during every inspection, after repairs on the fuel system or to solve problems. Turbochargers tested. Perfectly compatible with all conventional diesel and biodiesel fuels.
    How to use
    Unclip the fuel pipe and immerse the end in the Diesel Purge Tank. Feed the fuel return pipe into the Diesel Purge Tank. Start the engine and allow the engine to run at different speeds with the Diesel Purge unmixed. After the cleaning process, assemble the vehicle’s system. In extreme cases, repeat the cleaning procedure if necessary.
    Untuk harga boleh contact ke 08179845168
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Pertamax plus plus..
    Uuuuuuuuuuuuuupppppp
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Uuuuuuuuuuuuuuupppppppppp.......
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Naek dulu lagi yaaaa....
    Thanks...
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Uuuuuuuppppp...
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    23 Hrs 39 Mins 27 Secs
    Bisa untuk Innova diesel ?
    Bisa sekalian pake di tempat ?
    Tolong PM netnya.
    Thx
    Bisa kok..
    Harga dikirim via PM yaa..
    Uuuuuuuuuuppppp dulu yaaa...
    Thanks..
    Uuuuuuuuuuuuuupppppppppp ......
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
GT Radial MBtech
  1. JUAL : LIQUI MOLY DIESEL PURGE
    By std aja de in forum Jual Beli Mesin Lainnya
    Last Post: 18th October 2012, 23:21
  2. - H.P - Liqui Moly CERATEC
    By Hydra Performance in forum Jual Beli Mesin Lainnya
    Last Post: 9th November 2011, 13:30
  3. Ask : Liqui Moly
    By std aja de in forum Diskusi Mesin
    Last Post: 19th November 2008, 07:53
