Hi-end Flagship NAKAMICHI TP1200 + 100MB...........12,5jt
Rgotogel Gelap.net 36Goal.com
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/217399
    Thumbs up Hi-end Flagship NAKAMICHI TP1200 + 100MB...........12,5jt
    NAKAMICHI TP1200
    Fueled by technological progress - and the recognition that early car CD players were far from "perfect" - the quality of car CD reproduction equipment has made enormous strides over the past few years. But when one puts a typical head unit in the signal path between a high-quality CD source unit and the power amplifier, the sonic consequences are enormous. In the pursuit of refined preamplifier performance, Nakamichi engineers have taken several bold steps in the design of the TP-1200...not the least of which is elimination of the traditional cassette player. The TP-1200 also features extensive application of Nakamichi's sophisticated vibration suppression technologies. The result is a tuner/preamplifier that carves out a new concept in car audio and establishes a new standard of performance.
    TWO-PIECE DESIGN FOR TOTAL SEPARATION OF PREAMPLIFIER AND CONTROL CIRCUITRY
    By opting for convenience rather than performance, conventional head units house the preamplifier, tuner, and cassette deck in a single in-dash chassis. The resulting space limitations force various design compromises with attendant loss of sound quality. In distinct contrast, the TP-1200 employs two entirely separate chassis for the preamplifier circuitry and the tuner/control section. This eliminates design constraints and permits a clean and efficient circuit layout. Signal paths are straighter and shorter, minimizing mutual interference.
    • Moreover, by mounting the preamplifier unit in the trunk of the car, the signal route from the CD changer via the preamplifier to the power amplifier can be kept extremely short. With much shorter interconnect cables and far less chance of noise pickup, the integrity of the music signal is fully preserved.
    • The volume, balance, and fader knobs on the in-dash tuner/control unit serve only to create positional microprocessor in the preamplifier unit. The microprocessor in turn governs a high-precision attenuator network within the preamplifier unit. This arrangement, while elaborate, assures both outstanding sonic performance and superb ease of use. 1% tolerance metal film resistors are used in a discrete array to provide 64-step attenuation. Superior control resolution and sound quality are thus assured. The bass, midrange, and treble controls operate on the same principle except for the use of high-precision continuous controls driven by micromotors within the preamplifier unit.
    3-D VISCOUS SUSPENSION FOR EFFECTIVE SUPPRESSION OF VIBRATIONS
    When circuit components are subjected to vibrations - and there are many sources of vibration in a car - the resulting minute oscillations can lead to audible distortion. The TP-1200 preamplifier unit, therefore, employs Nakamichi's proven 3-D Viscous Suspension system. The audio circuit board is fully isolated in all three dimensions by a combination of coil springs and viscous dampers. This configuration effectively absorbs not only floor-transmitted vibrations but also vibrations arriving from the front or rear, the sides, and any obtuse angle. The suspension is further able to deal with a wide range of vibrational frequencies. The TP-1200 even comes with a set of replacement springs so that full suspension effectiveness can be achieved regardless of whether the preamplifier unit is mounted horizontally or vertically.
    UNCOMPROMISED TUNER PERFORMANCE
    The sensitive circuitry of a tuner is also highly vulnerable to mechanical vibrations. For this reason, the tuner circuit board in the TP-1200 tuner/control unit is also isolated via the 3-D Viscous Suspension principle. Add to this the use of an advanced diversity antenna system, and the result is a tuner section with outstanding reception characteristics and superb audio quality. The TP-1200 thus elevates mobile FM listening to an unprecedented level.
    NON-MAGNETIC ALUMINUM CHASSIS CONSTRUCTION FOR LOW ELECTROMAGNETIC DISTORTION
    Magnetic material, such as a conventional steel chassis, can become a source of electromagnetic radiation with deleterious effects on sensitive low-level circuitry. For this reason, the TP-1200 employs massive aluminum alloy chassis for both the preamplifier and tuner/control units. Signal integrity and musical accuracy are thus well preserved. The superior mechanical strength and high internal loss factor of the alloy further aids in the suppression of vibrations.
    OTHER ADVANCED FEATURES
    • Simple, high-performance 3-stage preamplifier circuit topology assures outstanding S/N ratio and extremely low distortion.
    • PWM-type DC-DC converter and multi-regulated power supply prevent interstage interference and deliver clean, stable power at all times.
    • Three inputs (CD, Aux1, Aux2) provide enhanced system configuration versatility.
    • Large concentric rotary control at the center of the front panel enables convenient adjustment of volume, fader, ancd balance adjustments.
    •Three-band tone control provides useful spectral adjustments, optimized for the automotive environment.
    • Seven Disc Select buttons provide one-touch access to any disc stored in a Nakamichi MusicBank™ CD changer.
    • Two dedicated displays for CD changer operation and tuner/clock provide easy-to-read, useful information at a glance.
    • Presets enable programming of up to 14 FM and 7 AM stations.
    • Security feature included for theft prevention.
    TP-1200 SPECIFICATIONS
    FM Tuner
    Frequency Range: 87.5-107.9 MHz in 200 kHz steps or 87.5-108.0 MHz in 50 kHz steps
    Sensitivity: Better than 25 dBf
    50 dB Quieting Sensitivity: Better than 25 dBf
    Signal-to-Noise Ratio: Better than 65 dB
    Stereo Separation: Better than 30 dB at 1 kHz
    Antenna Input: 75 ohms
    AM Tuner
    Frequency Response: 530-1,710 kHz in 10 kHz steps, 522-1,629 kHz in 9 kHz steps, or 531-1,602 kHz in 9kHz steps
    Sensitivity: 32 dB΅
    Preamplifier
    Frequency Response: 5-50,000 Hz ± 3 dB
    Output Level / Impedance: 1 V / 600 ohms
    Total Harmonic Distortion: Less than 0.018%
    Tone Controls:
    Bass : ±8 dB at 20 Hz
    Mid : ±8 dB at 200 Hz
    treble: ±8 dB at 20 kHz
    General
    Power Requirement: 14.4 V DC, negative ground (operable within 10.8 to 15.6 V)
    Current Consumption: 1.5 A max.
    Dimensions (WxHxD):
    Tuner/Control Unit : 178 x 50 x 165 mm
    7 x 1-15/16 x 6-1/2 in.
    Preamplifier Unit : 229 x 65 x 278 mm
    9 x 2-9/16 x 10-15/16 in,
    Approximate Weight
    Tuner/Control Unit : 1.1 kg / 2 lb. 7 oz.
    Preamplifier Unit : 3.3 kg / 7 lb. 4 oz.
    NAKAMICHI 100MB
    Vintage Rare Nakamichi 100Mb 7disc music bank.
    Top of the line.
    Has 1 pair of audio output and 1 coaxial digital output.
    Built in 18 bit DAC.
    The extruded aluminum chassis is designed to avoid electromagnetic from outer enviroment.
    CALL
    081388575788
    up..................
    up...................
    up...............................
  1. Replies: 7
    Last Post: 23rd October 2010, 13:06
  2. WTS:Nakamichi TP1200 limited + 100MB !
    By NeuSounds in forum Head Unit & Processor
    Last Post: 11th August 2010, 02:15
  3. WTS nakamichi TP1200 + 100MB
    By NAKAMICHI in forum Head Unit & Processor
    Last Post: 14th February 2010, 15:38
  4. Replies: 5
    Last Post: 25th January 2010, 14:24
