Hi-end Hertz ML2500.1 - 10" MILLE LINE subwoofer kondisi muluuuus n original
Results 1 to 9 of 9
  • Short URL:  http://modifika.si/216916
    Thumbs up Hi-end Hertz ML2500.1 - 10" MILLE LINE subwoofer kondisi muluuuus n original
    Hi-end Hertz ML2500.1 - 10" MILLE LINE subwoofer kondisi muluuuus n original......
    * Size: 250mm
    * Impedance: 4 Ohm
    * Sensitivity: 95dB/SPL
    * Power Handling: 1200 Watts Max, 600 Watts Continuous
    Product Features
    * 10" inch Hertz MILLE LINE ML2500.1 - 600W RMS/1200W max power subwoofer
    * Mobile voice coil wound on four layers with a special copper-plated aluminium CCAW winding. It insures maximum lightness and thermal and acoustic efficiency.
    * DSS® double spider, for mobile voice coil perfect motion linearity.
    * The exclusive DDS® spiders have constant compliance when excursion increases, keeping the speaker parameters unchanged even at high powers.
    * Double-wave, cloth surround for bursting, full bass.
    * Non-pressed paper cone with water-repellent coating.
    * Anti-resonant alloy basket protected by an exclusive anti-scratch treatment.
    * Forced ventilation circuit with reflex tube for mobile voice coil right cooling and for higher power handling.
    * Lowered bottom plate for mobile voice coil very long excursions.
    * Central “T” pole, for perfectly symmetric field in the gap.
    * Very big magnet for mobile voice coil optimal control.
    Product Description
    The new Hertz ML subwoofers add to the Mille line with their three models, respectively with a 250, 300 and 380 mm diameter and with a power that goes from 1200 W to 1800 W.
    The anti-resonant aluminium basket eliminates any possibile distorsion caused by acoustic compression, thanks to its deep, carved spokes.
    The rubber surround is made with the V-CONE technology which, thanks to the unique exponential curve without dust caps, ensures the ideal sound damping and a distortion-free reproduction. The Coated Foam surround and the Conex spider contribute to the maximum symmetry of the motor assembly contribute remarkably to the linear motion of all moving parts of the subwoofer, support this moving mass even in extreme conditions as those found in competition vehicles.
    The voice coil cooling system is based on a system of radial holes positioned on the center pole and ending at the bottom of the magnet: this solution grants the 30% reduction of the speaker working temperature raising the power handling beyond limits.
    The magnet assembly is provided with an aluminium ring in the air gap which reduces the voice coil inductance modulation at high excursions, for a deeper, tighter, more precise bass.
  2. Bandargua88
    up..................
    up......................
    up...............................
    1 Hr 12 Mins 2 Secs
    mau jual berapa pak?
    pm sent bos yansen,thanks......
    sudirman - cbbur
    3 Days 6 Hrs 33 Mins 7 Secs
    Ini new or used boss..pm harganya thx
    1 Day 5 Hrs 55 Mins 13 Secs
    brapa ni bos,
    ini used tapi masih mulus n ok banget barangnya bos...
    pm sent yach bos,thanks.
  1. Replies: 66
    Last Post: 6th October 2010, 02:19
  2. WTB- Sub Hertz Mille 3000 12"/Pioneer TS-SW1241D
    By h.tommy in forum Speaker - SubWoofer
    Last Post: 30th October 2009, 22:36
  3. Replies: 29
    Last Post: 17th July 2009, 01:45
