Oli buat Mesin turbo
Page 1 of 5 12345 LastLast
Results 1 to 10 of 48
  • Short URL:  http://modifika.si/2159
    Recommend donk merk & tipe SAE xx W xx, yg bagus untuk mobil turbo itu apa... oh iya catatan mesin mobil gue starlet(GT) 4-EFTE tahun 95...
    di manual sih di recomend :
    Castrol Formula R Synthetic 10W-60 : 5000km intervals (susah nyarinya)
    Mungkin Suhu,guru,master,dosen,dll di modkom bisa kasih yg bagus & murah tentunya hehehe
    siapa sih yang masih mau naik ojek waktu hujan becek? everybody wants to naik mobil, you know!
    POS VETT
    Any synthetic will do. Asal ditanggung asli. Weight antara 10W30 and 20W50.
    10 Mins 39 Secs
    Top One synthetic oil ..
    heuheuhe oli abal2 ya itu hahaha..
    seperti di iklan2..
    20W60 yg di anjurkan o/ toyota untuk starlet GT kok bukan full synth ya, gue cari2 rata2 untuk 20w60 itu semi synth
    satyr
    pake oli TRD aja
    4 Mths 4 Hrs 43 Mins 53 Secs
    Aral, Motul, FK Massimo, TOTAL dan oli2 lain yg ada turbo tested-nya
    Tangerang
    7 Hrs 36 Mins 18 Secs
    Quote Originally Posted by nobuhiko
    ada ya 20w-60? baru denger gw.. merek apa tu?
    yg banyak 20w-50
    20-60 juga saya jarang denger, kalo saya dulu pakai yg 5-40 total full syntetic atau 5-50 Global Petro America full syntetic juga.
    -unknown-
    3.0 Service / Maintenance Guide
    Engine Oil :Castrol Formula R Synthetic 10W-60 : 5000km intervals
    Oil Filter :TRD (Toyota Race Development) Sports oil filter : 5000km intervals - Product code # 90915-SP000
    Transmission Fluid / Oil :Castrol Syntrax 75W/90 Synthetic Manual transmission fluid : 10000km intervals
    Brake and Clutch Fluid :Castrol Super Disc DOT 5.1 Brake fluid : 2000km / annual intervals
    Fuel Filter :OEM (Toyota) standard replacement part # 23300- 19245 : 10000km intervals
    Air Filter Element :OEM Toyota (# 17801 - 11050) : Replace with K&N OEM re-usable Replacement product # 33-2634 (if you dont want pod modification) : at 20000km intervals - K&N re-usable pod filter (filtercharge option) Product # FC-0183 Clean ever 20000km with K&N cleaning kit product # 99-5000
    Turbocharger Oil Feed Pipe :Clean out at 10000km intervals
    Engine Coolant (Radiator) :Castrol Engine Coolant : Replace at 10000km intervals
    Spark Plugs and Leads :NGK "BKR-6EP" Laser Platinum plugs - Magnecor 48326 8mm Leads : Check / replace plugs at 10000km intervals
    dari manual ownernya starlet GT dikasi temen
    Salah ketik harusnya 10/60
    10-60 juga jarang denger
    -unknown-
  1. WTB : mesin mercedes benz turbo disel buat G klass
    By Indragi in forum Engine & Parts
    Last Post: 30th October 2012, 17:37
  2. Replies: 0
    Last Post: 7th August 2011, 00:12
  3. WTA...Karbu buat mesin turbo...
    By ban_simex in forum Diskusi Mesin
    Last Post: 11th January 2010, 10:28
  4. WTB: Turbo buat mesin 4JB1T
    By i-mobile in forum Jual Beli Mesin Lainnya
    Last Post: 19th June 2008, 23:58
  5. Turbo buat mesin 1000cc??
    By Timorblue in forum Diskusi Mesin
    Last Post: 15th March 2007, 20:59
