Morel HCW 8 MIdbass 8,7" ..LANGKA...!!!
Results 1 to 10 of 13
  • Short URL:  http://modifika.si/215375
    21 Hrs 53 Mins 32 Secs
    Permisi om moderator , mau numpang jual speaker.
    Langsung aja ya mau jual sbb :
    Permisi agan2 semua, mau jual speaker, dari pada tdk dipakai...
    Langsung aja ya mau jual nie barang :
    MOREL HCW 8
    Diameter: 222mm(8.7")
    Power Handling: 170WRMS
    Max.Transient Power: 600W
    Sensitivity (2.83V1M): 91dB
    Frequency Response: 35-3,000Hz
    Impedance: 4Ohm
    Voice Coil: Hexatech Aluminum(hexagonal wire)75mm(3")
    Magnet System: Hybrid(ferrite and neodymium)rear-vented
    Mounting Depth: 67mm(2.63")
    Speac laen :
    Brand Morel
    Model HCW 8
    Description woofer, Auminium voice coi former, Hexatech Auminium ire, DPC Damped Poymer Compositecone, Hybrid, CAR vented magnet system,
    Range / type Woofer
    Typical use Car
    Recomended enclosure
    Production status active 2003
    Nom. diamerer [inch] 8
    Vas [Liters] 34
    Qts 0.5
    Qes 1.95
    Qms 0.4
    Fs [Hz] 43
    Sensitivity [dB] 91
    Max Power [W] 170
    Power definition Nominal 170 W, transient 600 W
    Lower freq [Hz] 35
    Upper freq [Hz] 3000
    Rec. Filter freq [Hz]
    xmax [mm] 4.25
    Moving mass [g] 24.17
    Disp area [m2] 0.0219
    Disp Vol [cm3]
    xdamage [mm]
    Air gap [mm] 6
    Coil height [mm] 14.5
    Coil diameter [mm] 75
    Cms [mm/N] 0.513
    Rms [N*s/m] 3.34
    Magnet weight [gr]
    Magnet height [mm]
    Magnet diameter [mm]
    Magnet material - Hybrid, CAR vented
    Re [ohm] 3.8
    Z [ohm] 4
    L [mH] 0.78
    Bl [Tm] 8
    Magnetic flux [Wb]
    Flux density [T] 0.9
    Outer diam. [mm] 222
    Bolt circle [mm]
    Nr of bolts [Nr]
    Cutout [mm] 192
    Weight [Kg] 0.3
    Height [mm]
    Depth [mm] 67
    Driver volume [Liters]
    Kondisi yg 1 masih original, blm pernah service/repair, yg satu lagi ada gantian bagian yg seperti obat nyamuknya (ga tahu istilah namanya apa) tp suara normal semua, coil masih original
    Salah satu spon ditengah magnet hilang/rusak tp tdk berpengaruh
    Barang LANGKA...
    buat yg Serius aja
    hrga : 1.200.000,-
    08123214422 ( surabaya)
    My Blog : http://audiomobil2nd.blogspot.com/
  2. SbcAgent
    klaten
    pertamax..mantep bro
    2 Wks 6 Days 23 Hrs 25 Mins 59 Secs
    gede banget ya?? 8.7"??
    di panel pintu gak muat dunk??
    PangkaL Paha
    2 Wks 5 Days 41 Mins 5 Secs
    wuikz,, canggih ne
    08123214422
    08123214422
    bantu up bro, jrg denger aplg lht..
    Quote Originally Posted by ViXe View Post
    thanks bro..
    08123214422
    08123214422
  1. wtb midbass dls or morel
    By zenx10 in forum Speaker - SubWoofer
    Last Post: 29th September 2012, 16:27
  2. WTB : Midbass Morel HCW 6.5"
    By johansen in forum Speaker - SubWoofer
    Last Post: 13th July 2012, 12:52
  3. WTS TW & MIDBASS MOREL
    By KEKEPOPPY in forum Speaker - SubWoofer
    Last Post: 8th July 2011, 20:16
  4. WTS->Midbass MOREL HYBRID 5.5"(SOLD)
    By picanto in forum Speaker - SubWoofer
    Last Post: 5th May 2010, 14:05
  5. Replies: 23
    Last Post: 16th November 2009, 04:52
